| silent |
 silent Scooby Slapper
| mchaggis |
 mchaggis World Chat Champion
 Posted: 18:38 - 14 Jan 2005 Post subject: |
It sounds a bit like putting the throttle slide in back to front, so the main needle jet is wide open, hence it's a pain to start, then it goes to the limiter. If the carburettor's clean and there aren't any blocked jets, then I'd personally try making sure that it was all put back together properly and starting it again. It's possible that taking the tank off has swilled about muck in the bottom, which has got stuck in a jet.
Just my  ____________________ I must not be a troll...
Mmmm, Guinness
| silent |
| simon1221 |
 simon1221 World Chat Champion
 Posted: 19:16 - 14 Jan 2005 Post subject: |
i rekon youve blocked up part of your carb, so that it runs very lean (less fuel:air), that would explain why it only runs with the choke as it may be close to the correct mixture settings,
try running it for a while, or bump starting it with the choke to try to push the muck through, or just take the carb apart and clean it, try checking the fuel filters as well if you can be bothered for large flakes of muck restricting petrol flow
the throttle slide is the bit inside the carb that controls how much fuel and air is going through, it is controlled by the throttle cable, i am guessing that that is what he means  ____________________ DNA50 (sorry) ->> TZR125l >> GPZ500S |
| Frost |
 Frost World Chat Champion
 Posted: 19:29 - 14 Jan 2005 Post subject: |
Did you adjust the slack in your throttle cable? If you backed too much slack off it then it might be trying to tick oer at 400rpm or something silly. once you back the choke off and no longer have that increasing the revs it dies.
Start it with the choke on, blip the throttle till its warm, back the choke off whilst revving the bike. if you find it runs with you revving it but dies when you stop, take some slack out of the throttle cable.
| simon1221 |
 Posted: 19:36 - 14 Jan 2005 Post subject: |
Isnt that just the same as adjusting the idle speed screw, and i thought there was supposed to be a few mm of play in the throttle grip anyway  ____________________ DNA50 (sorry) ->> TZR125l >> GPZ500S |
 Posted: 02:43 - 15 Jan 2005 Post subject: |
It will have CV carbs, the cable attaches to a little lever which allows the throttle valves to be sucked open by the engine, he won't have been inside the carbs themselves to fiddle with the cable.
Maybe trapped the throttle cable under the tank or some bodywork when you put them back on?
Obstructed fuel tank breather?(does it do it with the fuel cap open?)
Check the vaccuum hose is still attached to both the carb manifold and the fuel tap. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| sickpup |
 sickpup Old Timer
| silent |
 Posted: 15:40 - 16 Jan 2005 Post subject: |
Vaccuum thing is simple. I asume your bike has a vaccuum fuel tap (most modern jap bikes do).
Just in front of the carbs on the inlet stub (between the carb and the engine) you will see a small hole in the top of the casting, one for each carb. Most of these will be blanked off with a screw and usually have a little rubber boot over the hole, they are used to balance the carburettors by attaching vaccuum guages to each hole and measuring how much air is being sucked through the carb.
One of these holes should have a bit of rubber fuel line attached to it, the other end of which should attach to the fuel tap, this is the vaccuum hoise I was referring to. When the engine is running, suction is applied to this hose which opens a diaphragm in the fuel tap allowing petrol to run out of it.
If this had become damaged/ detached then not enough fuel would run into the carbs to keep the engine running (in theory none would run out, in practice these taps are often a bit leaky anyway). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| silent |
The last post was made 21 years, 164 days ago. Instead of replying here, would creating a new thread be more useful? |
