Electrical question, wires.
iMark
PostPosted: 15:21 - 11 Jul 2014    Post subject: Electrical question, wires. Reply with quote
If I want to connect a device that is 12v @20-30 amp
(air compressor horn Twisted Evil)
5 amp wire
Rated for Side Tail and interior lights, Car Stereos and Aerials, & Car Alarms
8amp wire
Rated for Brake and Hazard Lights, Rear Fog Lights & Electric Windows
17 amp
Rated for High Output Headlights, Halogen Fog Lamps, Rear Screen Heaters & Wiper Motors
Halfords site also says 27 amp is rated for Charging Cable for battery feed and ammeter circuits which will be over kill.
Electrics isn't my thing Sad but I was thinking the standard wiring would burn out on that kind of horn compared to the standard horns.
K8 GSXR 1000
Aff
PostPosted: 15:28 - 11 Jul 2014    Post subject: Reply with quote
Just use some 12AWG (about 3.3mm²) wire straight from the battery, with fuse and relay where appropriate.
Electric Bike Project
PostPosted: 15:39 - 11 Jul 2014    Post subject: Reply with quote
20-30A is a LOT of current for a motorcycle to be producing on top of the normal load.
Pretty much what the entire rest of the bike with all the lights and acessories turned on will be drawing.
Did you mean 20-30 WATTS rather than AMPS.
A 30W device would be drawing 2.5A. About the same as two brake light bulbs.
iMark
PostPosted: 15:45 - 11 Jul 2014    Post subject: Reply with quote
Not a clue Stinkwheel, I'm not very savy when it comes to electrics haha... the ad says 12v@20-30a
https://i.imgur.com/9T5hJJr.png
They recommend using a 20-30 amp fuse but is that before or after the relay? haha Smile
K8 GSXR 1000
Aff
PostPosted: 15:47 - 11 Jul 2014    Post subject: Reply with quote
Those compressor horns do pull quite a lot. Think its normally about 15-20A. If they are stating 30A its probably so you don't go blowing fuses all the time with the inrush current.
A standard bike horn can draw near 5A depending on the type.
davebike
PostPosted: 15:58 - 11 Jul 2014    Post subject: Reply with quote
Running current is 10/12amps but start up is best part of 30amps
You will meed think 25/30 amp wire straight from the battery with a 30amp fuse close to the battery with a 30 amp relay the coil run by the original horn wires
The earth connection also need to be high 30amp rated wire
All connectors need to be good
I run a similar horn myself
Dave
NC750Xdct + others at work !
davebike1@gmail.com
iMark
Thinking
Might just stick with the normal snail horns, just need to piggy back wires from one to the other if I get dual... much easier Laughing
K8 GSXR 1000
Tamsin
PostPosted: 20:17 - 11 Jul 2014    Post subject: Reply with quote
360W horn, wowzers!
Stephenniall
PostPosted: 00:56 - 12 Jul 2014    Post subject: Reply with quote
I run a horn very similar (If not the same) to the air horns above.
I have a 30A Relay wired from the battery, to the OEM Horn circuit.
You will break something just wiring it directly to the normal horn circuit.
I have had the horns on for over 2 months now on this bike, and over 6 months on the scooter I had previously, with no 'ill effects'
I wired them in using the wiring diagram I found online below .
https://www.modernvespa.com/pix/uploads/stebel_on_gtv_medium_352_821.jpg
Yes It's for a Vespa, but is standard to most Japanese motorcycles. The only real time that wiring diagram will not work is with AC systems, or Positive Earth (If they made any bikes with positive earths!)
The last post was made 11 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 62.17 Kb
