The effect of exhaust on compression
thekeeper199
PostPosted: 20:12 - 11 Jul 2014    Post subject: The effect of exhaust on compression Reply with quote
Hi, holes in the exhaust muffler effect the engine compression?
mjn51
PostPosted: 20:18 - 11 Jul 2014    Post subject: Reply with quote
No ,but holes in the piston do
Nobby the Bastard
Harley Gaydar
PostPosted: 20:18 - 11 Jul 2014    Post subject: Re: The effect of exhaust on compression Reply with quote
No.
BTW it's affect, not effect.
Triumph Sprint ST 1050
thekeeper199
PostPosted: 20:46 - 11 Jul 2014    Post subject: Reply with quote
Klx250 previous owner had drilled holes in the muffler for noise
Btw how can i know the good compression test result for that specific bike? I mean what is a bad compression.
RhynoCZ
PostPosted: 20:53 - 11 Jul 2014    Post subject: Reply with quote
Bad compression is no compression. Thumbs Up
Find the manual and read it.
Dalemac
PostPosted: 22:02 - 11 Jul 2014    Post subject: Reply with quote
I think you are getting confused with compression and back pressure.
https://en.wikipedia.org/wiki/Back_pressure
YBR125 -> GPZ500S -> SL1000
Sload
PostPosted: 22:07 - 11 Jul 2014    Post subject: Reply with quote
https://www.veryuseful.com/mustang/tech/engine/exhaustScavenging.pdf
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
Ariel Badger
PostPosted: 23:13 - 11 Jul 2014    Post subject: Reply with quote
Exhaust can affect performance but it does not alter compression ratio
thekeeper199
PostPosted: 23:33 - 11 Jul 2014    Post subject: Reply with quote
thanks for the replies.. i understand.
my model have the auto compression release..
means the compression ratio should be lower?
Dalemac
PostPosted: 23:36 - 11 Jul 2014    Post subject: Reply with quote
OK, what is making you think you have issues with compression?
The only thing you have mentioned is some holes in the exhaust. This will affect only exhaust back pressure and not compression.
thekeeper199
PostPosted: 23:44 - 11 Jul 2014    Post subject: Reply with quote
cause according to the mechanic i have 70PSI and he did mention "auto compression release"
Dalemac
PostPosted: 23:55 - 11 Jul 2014    Post subject: Reply with quote
Right. That is meaningless unless you know what RPM the test was ran at.
Auto compression release just reduces the amount off compression until the pistons are moving quick enough to start. The valve then closes, the spark plugs kick in, and your engine starts.
If the bike starts easily and runs well, your compression is good enough.
If not, you will want to think about replacing the piston rings and at least checking the valves are sealing properly.
It has absolutely nothing to do with the holes in your exhaust.
thekeeper199
PostPosted: 00:47 - 12 Jul 2014    Post subject: Reply with quote
okay. thanks for the explanation. basically on cold weather bike starts then stalls 1 - 2 times then runs fine. on normal days it starts fine.. does this consider as bad start?
thekeeper199
PostPosted: 10:00 - 12 Jul 2014    Post subject: Reply with quote
this is the EFI model so choke is auto...
gsxfdumb This post is not being displayed because the poster is banned. Unhide this post / all posts.
The last post was made 11 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 95.54 Kb
