| simonplatt |
 simonplatt Two Stroke Sniffer
| CaNsA |
 CaNsA Super Spammer
| killerbanjo |
 killerbanjo Renault 5 Driver
 Posted: 15:58 - 12 Jul 2014 Post subject: |
Sounds like your steering stem is loose. Try taking off the top yolk and tightening the stem. Don't over tighten it though or you might damage the roller bearings  |
| CaNsA |
 CaNsA Super Spammer
| lihp |
 lihp World Chat Champion
| Nobby the Bastard |
| CaNsA |
 CaNsA Super Spammer
| Nobby the Bastard |
| CaNsA |
 CaNsA Super Spammer
| Nobby the Bastard |
| lihp |
| Ste |
 Ste Not Work Safe
 Posted: 19:07 - 12 Jul 2014 Post subject: |
The headstock is the piece of metal that goes from the bottom yoke and through the frame, it's not exactly adjustable!
I assume you're meaning the bearings, which can be tightened without removing either yoke. |
| lihp |
| YBR Ric |
 YBR Ric Spanner Monkey
 Posted: 19:28 - 12 Jul 2014 Post subject: |
DON'T FORGET to slacken the top yoke bolts before adjusting the steering head bearings or something will get damaged  |
| gavcarter |
 gavcarter Could Be A Chat Bot
 Posted: 23:13 - 12 Jul 2014 Post subject: |
| YBR Ric wrote: | DON'T FORGET to slacken the top yoke bolts before adjusting the steering head bearings or something will get damaged  |
Not until you try and tighten the top yoke back down
If you cant pick your way through the replies, then here is what to do.
first gain access to the headstock area ( remove fairings, clocks etc what ever will be in the way )
get the front end in the air, when stuck i have used the centre stand, and ratchet straps to a drain cover to pull back of bike down over.
Next slowly tighten the upper bearing retainer down. This will be similar to this one
https://www.hvccycle.com/images/HVC20092.JPG
Dont over tighten just nip it up, keep checking front end can turn nicely as you tighten it.
General rule is to get it as tight as possible without affecting the steering, so keep going until the steering feels just slightly stiff than back it off very slightly.
It may have a second nut similar to the one above to lock into place. Lock them together if it does.
If it does not, loosen top yoke from the forks, and it should budge, wiggle, tap with hammer handle, down the stem and fork legs to sit back flush on top of the bearing retainers.
Tighten yoke nut down as there will now be a slight gap under this and the top yoke.
Re-tighten fork clamps on top yoke.
Measure how much fork leg is protruding the top of yoke, just to be sure you haven't knocked one leg further down the bottom yoke ( not likely but has been known )
Double check steering, and check stem for movement, push front wheel back and forth, the "knock" should have gone now, also pay particular attention to the straight position.
when turning form right to left and back again the steering should no go light or stiffen up as it passes central ( straight ahead ) if it does your bearing, or the bearing races are fooked and will want replacing quite soon.
Best of luck, hope Ive explained everything in English  |
| gavcarter |
| gavcarter |
| simonplatt |
| pdg |
 pdg World Chat Champion
The last post was made 12 years, 80 days ago. Instead of replying here, would creating a new thread be more useful? |
