Project "Get Bonny riding to the BCF BBQ" - sv650
c_dug
PostPosted: 10:01 - 13 Jul 2014    Post subject: Project "Get Bonny riding to the BCF BBQ" - sv650 Reply with quote
Having issues with the SV that bonny is supposed to be borrowing this Friday for the BBQ.
It hadn't been run for a month or three, the battery was a gonner but I knew that already. We hooked it up with jump leads to my divvy and it fired up right away with no issues. Ran nicely.
Once it was running we disconnected the jump leads but it died straight away.
Since it died it hasn't started once, the SV battery is the same as the one fitted to the k5 gsxr1000, so we pinched the one out of the_godfathers bike to see if it made a difference but there was no change.
I dont have a spark plug spanner narrow enough to remove the plugs from the SV, but I tested both leads with a plug from my divvy and got no sparks from either cylinder. Unless there is something about the divvys spark plugs that means they wouldnt spark from the SV coils, im guessing there is an electronic issue somewhere along the line?
Any suggestions of what to check next?
P.
PostPosted: 10:08 - 13 Jul 2014    Post subject: Reply with quote
What happens with the gsxr battery attached? Spins over nice and fast but no sparking?
c_dug
PostPosted: 10:41 - 13 Jul 2014    Post subject: Reply with quote
Yep exactly that.
Hetzer
It sounds like you might have blown the coils.
P.
PostPosted: 10:44 - 13 Jul 2014    Post subject: Reply with quote
If you can get over to Maidstone sharpish you can have the coils of my SV purely for the bbq, they are from the race bike so I will need them back, but possible there is an issue there somewhere other than the coils.
Remove tank/airbox and check wiring.
PostPosted: 10:48 - 13 Jul 2014    Post subject: Reply with quote
Kill switch circuit?
The kill switch stops the engine by grounding it out before it gets to the spark plug.
Check to see if there's power getting in to the coils.
Have you checked the fuses?
nowhere.elysium
The Pork Lord
PostPosted: 11:03 - 13 Jul 2014    Post subject: Re: Project "Get Bonny riding to the BCF BBQ" - sv Reply with quote
I should have. D'you want me to run it over to you?
c_dug
PostPosted: 11:22 - 13 Jul 2014    Post subject: Reply with quote
Theres no way I can get to maidstone today, busy all day. My plan is to book a day off this week and run through whatever is suggested in this thread.
Dead coils would be an issue, how would they have been killed though? How do I test them?
G, we did think about the killswitch, but with it flicked the engine doesnt even crank over. So I figured that if the switch was at fault the engine wouldnt even be spinning up.
Gerry, if there is no reason the sv coils shouldn't spark my divvy plugs then I think removing the sv plugs isnt necessary? Thanks for the offer though. Also I still have the milliput here for you.
PostPosted: 11:24 - 13 Jul 2014    Post subject: Reply with quote
Note that it may just be a relay/connection further down the line, rather than the kill switch it's self which is causing the problem.
Have you got a mulitmeter there?
Hetzer
PostPosted: 11:25 - 13 Jul 2014    Post subject: Reply with quote
It sounds like all you did between the engine running and it then refusing to start was to try and run it without the battery (thus directly from the alternator). I have no idea how or why that would blow the coils but the clue seems to be in there. Or maybe just a fuse? Neutral
c_dug
PostPosted: 11:31 - 13 Jul 2014    Post subject: Reply with quote
I have a fairly decent multimeter here so should be able to test what is needed, if I know what to do!
nowhere.elysium
The Pork Lord
PostPosted: 12:16 - 13 Jul 2014    Post subject: Reply with quote
OK. I'd be looking at the ignition fuse, the kill switch part of the switchgear, and the state of the coils. I can't remember the appropriate impedance values off the top of my head, but I do have a printed copy of the factory service manual somewhere. Let me have a dig around.
nowhere.elysium
The Pork Lord
PostPosted: 12:44 - 13 Jul 2014    Post subject: Reply with quote
Did you want me to run the service manuals up to you? I can pick up the milliput in the process.
Shaft
PostPosted: 12:47 - 13 Jul 2014    Post subject: Re: Project "Get Bonny riding to the BCF BBQ" - sv Reply with quote
That could be the clue.
If the battery was so dead it wouldn't take a charge, as you disconnect the jump leads, the charging system spikes (it's now seeing it's own system, instead of the system on the donor) and with no capacity in the battery, all that power has to go somewhere.
Could be coils, could be ECU, could be ignition.
Multimeter everything.
c_dug
PostPosted: 13:08 - 13 Jul 2014    Post subject: Re: Project "Get Bonny riding to the BCF BBQ" - sv Reply with quote
How do I test them? Plain continuity test or something more complicated? If the latter what do I need to do?
There are a couple of breakers around London so getting spares on the day should be easy enough if I can identify the problem quickly.
Shaft
PostPosted: 13:34 - 13 Jul 2014    Post subject: Reply with quote
If you can get that service manual from Gerry, there's probably a test procedure for the various parts of the ignition circuit, along with specific values.
Failing that, start with a good battery, check the main fuse, then test for continuity until you find the part with power going in and none coming out.
PostPosted: 13:46 - 13 Jul 2014    Post subject: Reply with quote
https://www.dropbox.com/s/r9qgbwqz4wbva6m/1st%20Gen%20Service%20Manual.zip
jjdugen
PostPosted: 17:44 - 13 Jul 2014    Post subject: Reply with quote
I'm going with the ECU being fried too, not a good idea to run without a battery !
c_dug
PostPosted: 18:42 - 13 Jul 2014    Post subject: Reply with quote
Well, Mr. Elysium popped over earlier and had a look.
The coils are fine, the reg/rec is fine, generator is fine.
Looking more likely to be the CDI.
nowhere.elysium
The Pork Lord
PostPosted: 18:53 - 13 Jul 2014    Post subject: Reply with quote
I'm still suspicious of that sidestand switch.
Shaft
PostPosted: 19:00 - 13 Jul 2014    Post subject: Reply with quote
Doesn't the sidestand switch behave the same as the kill, ie it won't turn over if it's engaged?
c_dug
PostPosted: 19:12 - 13 Jul 2014    Post subject: Reply with quote
Thinking about it though would the sidestand switch make any difference in Neutral? Surely it would start and then cut out as soon as it was put in gear if it was the switch at play?
I've done some google-fu and it seems swapping the cdi is really the only way of testing it properly so I suppose I'll stump up for a unit from a breakers if thats the only way.
Annoyingly for such a common bike I dont know any curvey SV owners near by to play swapsies with!
P.
PostPosted: 20:29 - 13 Jul 2014    Post subject: Reply with quote
I have one you are welcome to buy afraid you will need to drop to Maidstone and pick up sir. Can try starting my bike with yours before travelling back too.
c_dug
PostPosted: 20:35 - 13 Jul 2014    Post subject: Reply with quote
From a curvey? How much and can you do a week day this Week?
c_dug
PostPosted: 20:47 - 13 Jul 2014    Post subject: Reply with quote
In fact I can pop down one evening so weekday isn't that important, maybe pm me order whatever. Thumbs Up
The last post was made 11 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 130.89 Kb
