Who to believe..
Stay Hazed
PostPosted: 12:59 - 13 Jul 2014    Post subject: Who to believe.. Reply with quote
Just joined the forum but browsed for a while.
I know absolutely nothing about bikes, mechanics in general. I have owned a Honda XR 125 for the last 3 months, had no problems with it other than a few minor things which i've always just taken to the garage down the road. This is where my possible problems are. I really should learn the basics, but as of now I don't know anything. The bike shop I usually use was closed yesterday so I went to an alternative as my chain was very loose.
The one I usually use, is an independent mechanic who owns the business himself and it's only him that works there.
The one I used yesterday was also an independent garage it seemed, but are a dealer for Peugeot, Sinnis, WK and the likes.
He informed me that when I'd had my tyres changed a few weeks ago, the rear wheel hadn't correctly been put on and was coming loose.
My problem is, who do I believe? My bike is due MOT next month and garage 1 that I usually use has said he'll go over the bike for free, run it to the MOT etc for free, the only thing I'll need to pay for is the MOT cost itself and any work that needs doing. Garage 2 does MOT on site and he said he'd also go over the bike for free but as with the first I'd need to pay for work if any.
TLDR, who do I trust with my bike? Sorry if anything doesn't make sense, just let me know and I'll try to explain.
SL.
yen_powell
PostPosted: 13:01 - 13 Jul 2014    Post subject: Reply with quote
Picture of back wheel from both sides and from behind.
XT1200Z and a DR350 in bits
Stay Hazed
PostPosted: 13:04 - 13 Jul 2014    Post subject: Reply with quote
The guy who done the chain said he's sorted it now so won't this be irrelevant? Will get one if needed!
Boxing
PostPosted: 13:17 - 13 Jul 2014    Post subject: Reply with quote
Is your chain still loose?
If not, then maybe garage #2 was in fact correct.
The only other explanation I have for this is if A) you messed with the rear wheel nuts (I doubt) or B) Someone tried to steal your rear wheel. If the chances of them are slim, then garage #1 messed up, with something potentially life threatening, therefore I'd never go back. Thumbs Up
Although I and a few others on this forum don't trust mechanics, and IF they have to work on my bike I'll watch them like a hawk. Usually I'll just do it all myself. Plenty of help on the internet. YouTube helps with near enough everything. Thumbs Up
P.S Them garages are counting on something to go wrong during the MOT. To make money. Go and MOT it yourself. If you're insured you can ride it to the MOT station perfectly legally as long as you're booked in. You don't need tax to go and MOT it, just insurance and you can ride it down. Thumbs Up £28-£30 for a MOT.
Teflon-Mike
tl;dr
PostPosted: 14:33 - 13 Jul 2014    Post subject: Reply with quote
Confucius say; Man with clock always know time; man with two clocks, never sure.
Buy a Haynes Manual and some spanners; sod the clock, spend time with your bike. It's all part of the fun.
PostPosted: 14:59 - 13 Jul 2014    Post subject: Reply with quote
That. Just because garage #2 spotted garage #1's screw up doesn't mean that their £2.68 an hour apprentice will do any better.
There is a use-it-or-lose-it argument to be made with garages, but if they're twunting up the easy stuff, would you want to trust them with anything tricky anyway?
You wouldn't take a pushbike to Halfrauds to get the chain oiled, you don't need a garage to do basic maintenance, particularly on a 125.
Wonko The Sane
PostPosted: 15:37 - 13 Jul 2014    Post subject: Reply with quote
I agree with above, doing things yourself and being sure is enjoyable, being knocked off my bike was probably the best thing that's happened for me with biking.
The only thing I had been doing myself was to adjust the chain tension and keep it lubed.
this weekend I have changed my oil, oil filter and oil cooler (the latter due to a leak, it's not routine)
best tool aquired? an off cut of carpet, makes it more comfortable sat on the floor taking my time and making sure I know how each step should be.
would have sorted my brakes too if I the retaining pin hadn't seized.
Stay Hazed
PostPosted: 16:51 - 13 Jul 2014    Post subject: Reply with quote
It's no longer loose, that issue is fixed. My only problem with taking it for MOT myself, is that it needs the rear brake light looking at as it doesn't work when pressing the pedal, I need a number plate light. I don't know of anything else. Would the best possible outcome be, to get the bike Pre MOT checked a week or two before hand?
In regards to the other comments, I'll definitely invest the £20 odd quid for the Haynes manual, unless someone has a downloadable version knocking around that I can print off? Honda XR 125 2005 plate, L4 I think it is.
Best regards all and many thanks for the replies.
Stay Hazed
PostPosted: 16:52 - 13 Jul 2014    Post subject: Reply with quote
Also, in regards to the spanners post from Teflon Mike, is there a sort of 'starter' set sold anywhere as I literally have nothing! It cost me £120 for a full service a month ago, so having to get that done again would be almost certainly near the cost of a set of spanners/tools I guess?
Kind regards
Benjums
PostPosted: 17:48 - 13 Jul 2014    Post subject: Reply with quote
Have you not got any mates who are into bikes and handy with spanners? Failing that your parents mates. Who can go over things with you? The other option is to see if there is a friendly bcfer near you, who won't mind showing you the ropes for some beer tokens or a crate of beer?
I was the same as you, as in I didn't have a clue on mechanics but luckily I have a few mates who have been over my shoulder watching and explaining.
Shaft
PostPosted: 19:06 - 13 Jul 2014    Post subject: Reply with quote
Kind regards
This is on offer again..........
https://www.halfords.com/motoring/garage-equipment/socket-sets/halfords-advanced-professional-200-piece-socket-and-ratchet-spanner-set
Loadsa tools!
I've got that for messing about at home, it's good stuff.
TUG
PostPosted: 04:17 - 14 Jul 2014    Post subject: Reply with quote
I got more than enough as an apprentice, it wasn't £2.68 more like £6+ and that was over 5 years ago! Cool
Haz ER-5, innit!
yen_powell
PostPosted: 04:57 - 14 Jul 2014    Post subject: Reply with quote
Vincent wrote:
I started at £11.00 a week which would pay for fuel for the week in my moped, a fiver keep for my Mum and still go out a couple of nights and buy fags Shocked
The 20s were marvellous weren't they. Very Happy
Andy9934
PostPosted: 10:05 - 14 Jul 2014    Post subject: Reply with quote
This is really easy to adjust yourself on a lot of bikes Smile
Surrey
Honda Varadero XL125
Formerly known as
P.
PostPosted: 10:23 - 14 Jul 2014    Post subject: Reply with quote
Where abouts in the country are you S_L?
Stay Hazed
PostPosted: 17:22 - 16 Jul 2014    Post subject: Reply with quote
Worcestershire, sir.
Commuter_Tim
PostPosted: 18:07 - 16 Jul 2014    Post subject: Reply with quote
Hehe, he called Paddy "Sir" Very Happy
I ride a Bandit 600... badly.
Formerly known as
P.
PostPosted: 19:16 - 16 Jul 2014    Post subject: Reply with quote
As it should be.
Shame, if you were local I've torn 2 of those down... 1 stolen Shifty Laughing Usually most bikers can take a quick look and advise the actual problems, some even see them before they happen Shocked
Cashhead
PostPosted: 08:56 - 17 Jul 2014    Post subject: Reply with quote
Where abouts in Worcestershire, I've used Streffords (in Worcester) before with no issues, having said that it was only for an MOT and a new tyre!
Cashhead
PostPosted: 08:58 - 17 Jul 2014    Post subject: Reply with quote
Also I'm fairly handy with spanners, however pretty busy with a baby on the way but I'm sure I could find some time if you need a hand, I live out near Inkberrow between Worcester and Stratford.
Stay Hazed
PostPosted: 09:22 - 17 Jul 2014    Post subject: Reply with quote
Inkberrow is close, as I'm in Redditch Thumbs Up
Cashhead
PostPosted: 17:55 - 17 Jul 2014    Post subject: Reply with quote
It really is, feel free to drop me a PM if you need a hand!
The last post was made 11 years, 216 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 128.57 Kb
