JT or DID.
gbrand42
PostPosted: 14:07 - 13 Jul 2014    Post subject: Reply with quote
I would go with the DID, only cause I have no experience of the other one. DID are known to be good quality as far as I know.
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
Hugh Farking Cant
PostPosted: 15:03 - 13 Jul 2014    Post subject: Reply with quote
I believe JT have only recently started to market their own chains.
From another forum; the box is labelled " Taiwanese made".
The quality is unknown at present.
Remember; Someone on here always has a blacker cat.
sidewinder
PostPosted: 15:13 - 13 Jul 2014    Post subject: Reply with quote
Did is your best bet.cant see the black coating on the jt staying on that long... Thumbs Up
andys675
PostPosted: 20:59 - 13 Jul 2014    Post subject: Reply with quote
JT is short for JOMTHAI ASAHI Co of thailand
not bad sprockets, but not sure how good their chain may or may not be
buy the DID, or take a chance on the JT? don't think so
Wull
PostPosted: 05:11 - 14 Jul 2014    Post subject: Reply with quote
DID all day long,its all I ever buy and I've recently replaced the cheap shite that was on my 9r as it couldn't hack it,apparently it was recently done but I'm not so sure.
Best going with the tired and tested and you can't go wrong with the DID.
"Scooters are for men who want to ride motorcycles but prefer to feel the wind on their vaginas"
PostPosted: 09:40 - 14 Jul 2014    Post subject: Reply with quote
Why ask if you're not interested in the advice given?
Eddie Hitler
PostPosted: 09:45 - 14 Jul 2014    Post subject: Reply with quote
Another vote for DID, everyday thrashing for over a year and I have barely adjusted it.
I echo Ste.. good luck with using JT.
Hugh Farking Cant
PostPosted: 10:05 - 14 Jul 2014    Post subject: Reply with quote
BodyGuard wrote:
I've ordered the JT Kit 1 now all as I need is a grinder.
And a welder !
bladerunner
PostPosted: 10:42 - 14 Jul 2014    Post subject: Reply with quote
Jeezus your still on that feked front sprocket....I'd love to see a pic of what it looks Luke now!
gbrand42
PostPosted: 11:14 - 14 Jul 2014    Post subject: Reply with quote
Cause his Latin name is Bellus Endus
hmmmnz
PostPosted: 16:08 - 14 Jul 2014    Post subject: Reply with quote
jt have a pretty awesome rep for their sprockets,
im not sure if did even make sprockets??
but when you buy a chain and sprocket set from wemoto you get a did chain and jt sprockets,
as for jt chains, as far as i can tell they are non o-ring chains, so probably not that good,
the humans are dead
I kick arse for the lord
Wull
PostPosted: 18:17 - 14 Jul 2014    Post subject: Reply with quote
BodyGuard wrote:
Order cancelled I have seen this overkill?
Not bad,the sprockets will be either jt or similar but the chain will be a good quality DID one so top quality.
I just paid £90 for my DID chain but its a 530.
Wull
Are you going to fit them yourself?
Wull
PostPosted: 20:35 - 14 Jul 2014    Post subject: Reply with quote
BodyGuard wrote:
Depends if I can get on a job on a building site within the next month to steal a grinder.
Could you not borrow one?
I'd recommend buying a proper chain tool,all you'll need to do is grind one of the pins flush with the side plate and the tool can do the rest.....works a treat.
Is the chain on the Bike just now fitted with a clip link or is it a rivet one?
Fisty
PostPosted: 21:56 - 14 Jul 2014    Post subject: Reply with quote
With your mechanical dyslexia I suspect you will lose a finger before the sprocket is off.
Fatter and faster than Fret
lihp
PostPosted: 22:17 - 14 Jul 2014    Post subject: Reply with quote
What's the point, quicker just to cut through the chain, it's not like it will be reused.
pdg
PostPosted: 22:18 - 14 Jul 2014    Post subject: Re: JT or DID. Reply with quote
BodyGuard wrote:
JT Heavy duty sprocket kit 1
DID Heavy duty chain and sprocket set
My chain is soon due to be replaced I've already recycled both sprockets so they will need to be replaced too.
Which is the better buy?
https://cdn1.horror-shop.com/out/pictures/generated/product/1/350_600_75/15109.jpg
This chain is the best one for you, you fucking mong.
Fuck off, cunt.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
Wull
PostPosted: 04:57 - 15 Jul 2014    Post subject: Reply with quote
Tbh its 6 two 3's.........
orac
PostPosted: 07:57 - 15 Jul 2014    Post subject: Reply with quote
i am yet to hear anything bad about the JT chains, a buddy ofmine sells them in shop were he works - hes not had any comlaint yet
The last post was made 12 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 125.53 Kb
