Gpz900R piston heights
marc_cowley
PostPosted: 19:48 - 15 Jul 2014    Post subject: Gpz900R piston heights Reply with quote
This is a bit of a strange one, have recently purchased a gpz 900R, it was a non runner when i brought it but went ahead anyway as the bodywork and everything else is very tidy on it, anywho, checked compression, all cylinders around 60-70psi, which i know is way too low, by about half to get it to run, checked all valve clearances, all adjusted, still the same, pulled the cyl head off, then was greeted by 4 pistons all sitting 4mm below the top of the block, that isnt right, pull the block off, conrods all look fine and measure ok compared to a spare one. does anybody know of a crank that could have been incorrectly fitted that has a shorter throw. thanks!
Chaly Cf70
Gpz900R
The last post was made 11 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 27.53 Kb
