| biker_bob |
 biker_bob Derestricted Danger
 Posted: 16:57 - 16 Jul 2014 Post subject: honda H100 MB100 crank timing |
Hi great hive mind.
Anyone know how to time up the crank on a H100 engine?
On the left hand end is a cog with a mark.
On the case is a mark.
On the end of the crank there is meant to be a mark.
You guessed it, I took of the cog without noticing that the mark on the end of the crank is not there.
Anyone know if the missing mark would align at TDC or may be BDC or some other angle?
If it make any difference to bike is a H100a but I think the engine remained the same really through the life of the H100 series and MB100's as well
Any help much appreciated.
Bob |
| Pete. |
 Pete. Super Spammer
 Posted: 17:18 - 16 Jul 2014 Post subject: |
Stick up a photo of what you have. Trying to figure out what the cog on the crank is for, can't be oil pump or water pump coz they don't need timing. Does it have a balancer? ____________________ a.k.a 'Geri'
| biker_bob |
 Posted: 18:17 - 16 Jul 2014 Post subject: |
It's the main drive for the bike. It goes to a balancer shaft and the clutch.
Thinking about what you've said...
It only really cares about the balancer shaft as far as timing goes. The ignition timing is run from the other end of the shaft.
I hadn't though about that.
This simplifies the question I guess. I presume the balancer should be the opposite side to the piston? EG. with the piston at TDC the balance weight should be pointing in the direction of BDC.
Darn! I need to take it all apart again to see where the balance weight is in relation to it's marks
Thanks for the thought provoking question Pete. |
| trisers |
 trisers Scooby Slapper
| biker_bob |
| dansp1 |
 dansp1 Nitrous Nuisance
| biker_bob |
The last post was made 11 years, 217 days ago. Instead of replying here, would creating a new thread be more useful? |
