Charging Nimh batteries
PostPosted: 14:13 - 17 Jul 2014    Post subject: Charging Nimh batteries Reply with quote
Hi all, I have NiMh batteries in my RC car.
2 to power the servos/radio gear 6v 1200 mAh
1 to power the starter 7.2v 2000mAh
Both came with 'dumb' chargers and as I understand it these batteries don't like being overcharged.
What is the best way to keep them topped up?
Options seem to be either run them all down then give them a full charge. (this would require me buying another 7.2v battery to save it running out when I need it). Or buying a better charger that will charge both batteries smartly.
I wondered if they are another way I could do it without spending money. Could a multimeter tell me how much charge they have left?
DrSnoosnoo
PostPosted: 14:40 - 17 Jul 2014    Post subject: Reply with quote
I used to Airsoft quite a lot and had the NiMH batteries and I bought a "smart charger" that had the setting to quick charge upto 4A (not sure of the unit) and once it was fully charged it would automatically set itself to trickle and the LED would flash telling me to take it off.
I too heard that it's best to run these down rather than charging to top them up. To do this I just plugged the battery into the charger without plugging it to the mains to power the fan.
Not sure if this is helpful or not.
This is very similar to my old charger.
mudcow007
PostPosted: 09:51 - 18 Jul 2014    Post subject: Reply with quote
why no just use lipo batteries?
im using nanotechs in my plane which seem pretty sweet
PostPosted: 10:56 - 18 Jul 2014    Post subject: Reply with quote
Because I have NiMh.
Aff
PostPosted: 11:03 - 18 Jul 2014    Post subject: Reply with quote
Just buy an iMax B6, then you can upgrade to Lithium at some point in the future.
Electric Bike Project
Aff
Actually, I might have one lying around that you can have, I will have a look.
Aff
PostPosted: 15:31 - 18 Jul 2014    Post subject: Reply with quote
OK found it. You will have to pinch an IEC power cord from somewhere.
If you want it PM me your address.
PostPosted: 15:54 - 18 Jul 2014    Post subject: Reply with quote
Wicked, I assume this is a smart charger or some kind?
What does it need? IEC power cord? Kettle lead?
Do I simply find a way to hook the batteries up to this and it sorts them out?
Cheers,
Chris
mudcow007
PostPosted: 16:00 - 18 Jul 2014    Post subject: Reply with quote
Cheers,
Chris
yep iec = kettle lead
Aff
PostPosted: 16:33 - 18 Jul 2014    Post subject: Reply with quote
Yea, will charge pretty much any sort of battery:
https://www.hobbyking.co.uk/hobbyking/store/__6478__IMAX_B6_AC_Charger_Discharger_1_6_Cells_GENUINE_.html
Yep it needs an IEC C5
https://www.powercord-china.com/Clkj_Images/upfile/bigpic/Power-cord-Laptop-iec-c5-2.jpg
Pretty much, hook it up, tell it what you're charging and it does it's thing.
PostPosted: 17:23 - 18 Jul 2014    Post subject: Reply with quote
Wicked I think I have one from an old laptop charger. Thumbs Up I will PM my address. Thumbs Up Thanks a lot.
PostPosted: 17:39 - 18 Jul 2014    Post subject: Reply with quote
Is this charger simple to use?
i.e. Connect the battery and it sorts it all out or do I have to program it in some way?
Aff
PostPosted: 17:53 - 18 Jul 2014    Post subject: Reply with quote
You pretty much just choose the type of cell you are charging, how many you are charging and what current you want to charge at. Then press go.
PostPosted: 13:47 - 27 Jul 2014    Post subject: Reply with quote
Charger arriver and is great, can everyone Karma Aff who not only gave me the charger but would take any cash for postage Thumbs Up Good man Thumbs Up
PostPosted: 23:48 - 27 Jul 2014    Post subject: Reply with quote
Dang, I bought that exact charger about a month ago and had to pay those nasty people at Amazon for it Razz.
So, just to confirm, out of interest - for NiMH batteries I just set the amps and let it do it's stuff?
I was initially using it for Lipos, for which you choose the configuration (voltage) and so on, but was a little worried about how good the NiMH bit knows about when it's done?
(The Traxxas came with NiMH which seem ok, though may still get LiPo to work with it.)
PostPosted: 10:34 - 28 Jul 2014    Post subject: Reply with quote
I was worried about that too, it appears to work well. I saved programs for each of them, I have one where I set it to 7.2v, 0.3a and 2000mAh and the other to 6v, 0.3a and 1600mAh. I then just run these on the Auto setting. If you leave the Battery it charges them when done will say full, show you how long it took and how many mA it pumped in.
If you want to switch from manual to auto, you have to press and hold the 2 arrow buttons (couldn't find that written in the manual.) and to start it you have to press and hold the power button.
PostPosted: 21:02 - 28 Jul 2014    Post subject: Reply with quote
Ta; think I must have a different version.
Mine doesn't have a voltage or mah setting for NiMH, which was partly what worried me.
For lipo you set the number of cells (and thus voltage).
There's also a global time limit and mah limit which can be set.
I think mine is in 'auto' setting by default. It did actually come up saying 'full' yesterday, so guess it knows what it's doing!
The last post was made 12 years, 56 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 101.71 Kb
