| AzzA1990 |
 AzzA1990 Nova Slayer
 Posted: 13:14 - 17 Jul 2014 Post subject: Fitting a new clutch question / advice needed |
Hi guys
I have just fitted a new set of EBC clutch plates & springs into my bike i have been reading the haynes manual for my bike and it's telling to to replace the circlip that holds on the clutch basket / hub for a new one so i have just brought a couple of circlips however i can't seem to find the exact same size, the original circlip that i am replacing does look like it's been in the bike a while
My concern is that the original circlip sits in the groove it needs to clip in but it moves freely around the groove
The new circlip seems to be about 1mm smaller and sits and clips in the groove nicely but it is very tight around the shaft and does not move freely, does this sound ok or a bit dodgy?
Hope i have made sense
Here are a couple of pictures (sorry about the poor quality) |
| gavcarter |
 gavcarter Could Be A Chat Bot
| Vincent |
 Vincent Banned
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 17:31 - 17 Jul 2014 Post subject: |
Get the right original part or fit the tight one . they do go loose but there's usually enough metal on the circlip and recess on the g box shaft to hold the clutch basket.
I once had a clutch basket come off it damaged the sidecasing/clutch operating arm.......because I fitted the old circlip............after removing it with a big screwdriver. Reccomend using circlip pliers NOT long nose electricians pliers that happen to fit the circlip holes. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| AzzA1990 |
| unitynotsocri... |
 Posted: 18:12 - 17 Jul 2014 Post subject: |
David Silver spares......do it right or pay up for loads more when the clutch flies off and hits the casing. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| biker_bob |
 biker_bob Derestricted Danger
 Posted: 18:53 - 17 Jul 2014 Post subject: |
The part you are looking for is...
https://www.cmsnl.com/honda-h100s-1988-england_model3444/circlip-17-mm_90601001000/#.U8gabpRdVvQ
In opposition to everyone else the circlip on my H100a is also a loose fit and it's been on and off loads of times (3 times this week and removal No. 4 tomorrow). Yes it's not a good fit, yes I have circlip pliers, yes I'll be using it again. I'm not too sure how big an isse it would really be if it drops off as most of it is all held in place by the actuator anyway.
What the others say is correct though. I'm just loath to spend the time waiting for a new one to arrive when the 'H' is my only transport to work.
Bob |
| Vincent |
 Vincent Banned
The last post was made 11 years, 222 days ago. Instead of replying here, would creating a new thread be more useful? |
