| CoreRSystems |
 CoreRSystems L Plate Warrior
| Vincent |
 Vincent Banned
| davebike |
 davebike World Chat Champion
 Posted: 06:43 - 18 Jul 2014 Post subject: |
Could be fuel as said
But oil! has the oil and oil filter been changed ?
Bikes the stand long periods or do very low mileages have lot of problems ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
| bodger |
 bodger Nova Slayer
 Posted: 07:14 - 18 Jul 2014 Post subject: |
Surprised the mechanic thought it might be coil at fault as there are two on the bandit I believe.
Maybe one could be faulty be surely the other would still operate two of the cylinders and it wouldnt cut out completely.
I used to have a Honda that would give similar symptoms as yours when the CDI was on its last legs.
Hope its something more simple like fuel starvation.  |
| Bezzer |
 Bezzer World Chat Champion
| CoreRSystems |
 Posted: 14:44 - 18 Jul 2014 Post subject: |
Sounds like classic symptoms of a blocked fuel tank breather. Air has to go back into the tank as fuel comes out or a vacuum will form and no more fuel can come out. If that breather is blocked, it'll run on what petrol can come outthen stop. After a while, the vacuum disappears again (because it's rarely a complete blockage) and fuel flow resumes.
They will usually idle indefinately because they only sip fuel at idle. The harder and faster you ride, the quicker it'll happen.
Try it with the fuel cap open. If the problem goes away, that's your problem. If you were to open the filler cap just after it happens, you'd get a sucking in of air. In an extreme case, you may not actually be able to open the cap at all until the vacuum equalises.
I seriously doubt it's even possible to overheat a bandit 12 engine in 2 miles. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Bezzer |
| CoreRSystems |
| Robby |
 Robby Dirty Old Man
| Bezzer |
| Bezzer |
| Ariel Badger |
 Ariel Badger Super Spammer
| gavbriggs |
 gavbriggs Crazy Courier
The last post was made 11 years, 224 days ago. Instead of replying here, would creating a new thread be more useful? |
