DTR 125 can anyone help
leedo55
PostPosted: 22:30 - 19 Jul 2014    Post subject: DTR 125 can anyone help Reply with quote
got an 03 dtr about a month ago.
bike kicks over 1st kick with the choke on but idles at around 5000 revs, turn the choke of and it dies unless i rev the knackers off it.
1st off i stripped the carb and cleaned it all out, checked the jets all clean, tried adjusting the needle all ways. fiddle mixture srew and makes no diffrence.
checked air filter and all pipes are nipped up nicely not sucking in air anywhere.
checked the reeds also there fine.
fitted a new iridium sparkplug
then bit the bullet and bought a new carb off ebay and fitted it today, i put a 260 main jet in the new carb old one was 210 as i heard people saying when running full dep system i should change jets.
bike still no different, kicks over with the choke on idles at 5000 then dies soon as choke comes off.
now have the bike stripped down in my fathers garage and where at a loss at what to do next.
any help would be great.
thanks
Boxing
PostPosted: 22:40 - 19 Jul 2014    Post subject: Reply with quote
How many miles has it done?
Did it work fine when you bought it?
leedo55
PostPosted: 23:06 - 19 Jul 2014    Post subject: Reply with quote
cant remember exacly what the mileage is would have to have a look tomorrow.
when i 1st bought it i managed to ride it around the doors a bit but it would cut out as soon as i came to a junction unless i sat revving the knackers off it to keep it ticking over.
andy_uk
PostPosted: 23:30 - 19 Jul 2014    Post subject: Reply with quote
Check the compression...
leedo55
PostPosted: 23:36 - 19 Jul 2014    Post subject: Reply with quote
i dont have the gear to check the compression myself can you point me in the right direction on ebay to what i need to do this then i will try to get the gear tomorrow
leedo55
PostPosted: 23:39 - 19 Jul 2014    Post subject: Reply with quote
never mind found it easy enough will get a compression tester tomorrow, what am i looking at if the pressure is wrong? rebore?
andy_uk
PostPosted: 00:29 - 20 Jul 2014    Post subject: Reply with quote
Possibly just new rings (or piston & rings). You won't know until you lift the barrel (cylinder) off.
leedo55
PostPosted: 17:15 - 20 Jul 2014    Post subject: Reply with quote
checked compression today its 120 from cold
leedo55
PostPosted: 22:38 - 20 Jul 2014    Post subject: Reply with quote
the mileage is 13566
leedo55
PostPosted: 22:42 - 20 Jul 2014    Post subject: Reply with quote
what did happen is i was flat out it was doing the clock and the needle was just bouncing around the 80 it bogged out and nearly threw me over the handle bars then took off again, i have heard this could of scortched the barrell.
what do you lads think?
Boxing
PostPosted: 01:59 - 21 Jul 2014    Post subject: Reply with quote
And you didn't get a refund? Thinking Or is this the first ride after the purchase?
leedo55
PostPosted: 21:07 - 21 Jul 2014    Post subject: Reply with quote
ok got mine sorted it was the seal behind the crankcase it was sucking in air if anyone can now help with the other i have on for my mate that would be great
The last post was made 11 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 69.19 Kb
