XJ600 pre Diversion Cafe Racer Project
parkinmj
PostPosted: 12:27 - 19 Jul 2014    Post subject: XJ600 pre Diversion Cafe Racer Project Reply with quote
I have recently been given a running 1991 Yamaha XJ600 which immediately screamed Cafe Racer project to me,
The frame will be stripped , cleaned, and powder coated, the engine will have the same treatment and a refresh. but i want the thing to handle well so Im thinking an R6 5EB front end and Swing arm allowing me to run a 120/70 on the front and a 180/60 or 180/55 on the rear.
Does anybody know of where i can find out the steering stem dimensions for the XJ AND THE R6 and if it would be a straight forward swap or would it need the stems swapping over etc?
Parkin
biker_bob
PostPosted: 17:23 - 19 Jul 2014    Post subject: Reply with quote
Have you looked up the bearings for both of them? Comparing the bearings on-line should be easy enough to do and will let you know if it's possible at least.
Bob
jjdugen
PostPosted: 18:36 - 19 Jul 2014    Post subject: Reply with quote
https://www.clubchopper.com/forums/metric-chopper-talk/77043-jap-bikes-fork-tube-sizes-neck-bearings-axle-diameters.html
There y' go.
sidewinder
PostPosted: 20:44 - 19 Jul 2014    Post subject: Re: XJ600 pre Diversion Cafe Racer Project Reply with quote
These guys do this type of conversion all the time
https://www.xjrider.com/
sidewinder
sickpup
Old Timer
PostPosted: 07:24 - 20 Jul 2014    Post subject: Reply with quote
How are you going to space out the front sprocket?
temeluchus
PostPosted: 13:10 - 20 Jul 2014    Post subject: Reply with quote
i think the xj600 only has a 2.75-3.00" wide rear rim. Be fun getting such a wide rear to work assuming the swinger will even fit.
Moo.
PostPosted: 19:07 - 20 Jul 2014    Post subject: Reply with quote
As sidewinder said, its its the same dimensions as the never XJ600 diversion it would open options up..
Here are the common FZR600 and YZF600 swaps for the 600 diversion..
https://xjrider.com/viewtopic.php?f=11&t=881
https://xjrider.com/viewtopic.php?f=11&t=1842
A2 Passed 18/6/10
parkinmj
PostPosted: 11:45 - 21 Jul 2014    Post subject: Reply with quote
Cheers for all the replies,
I'm thinking of chopping the back end and mounting a different sub frame and rear end, not decided which yet, but i never thought about the swing arm catching :S
Thanks for all the links too Smile i will keep you all updated.
cheers
Parkin
sickpup
Old Timer
PostPosted: 14:38 - 21 Jul 2014    Post subject: Reply with quote
How about my point of the chain cutting through the frame?
The last post was made 11 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 68 Kb
