| Nipedley |
 Nipedley Scooby Slapper
 Posted: 12:27 - 20 Jul 2014 Post subject: GPZ500 - Valve Clearances, timing wrong ? |
Hey guys,
My friend noticed his gpz500 had a rocker cover bolt broken off inside one of the cam caps (neither of us the guilty party) so I said I'd take the cam cap out and get it sorted for him, and while I'm in there do the valve clearances. I've done clearances before but only on a shimmed bike where these are locknut and adjuster
Question no. 1 - While following the Haynes manual to check the clearances, I set it to the T mark however the cam lobes on cylinder 1 are not pointing up at that point like the Haynes manual says they should be. I'm quite confused about this. I have attached photos of the bike at position T with the cam lobes pointing down, forgive the bad photos it was very sunny (!) Is the timing wrong or should I be doing Cylinder 1 from a different mark? The bike was running fine and strong so I can't imagine the timing could be out that much and be running surely? Setting the bike at mark C as listed in Haynes for Cylinder 2 is fine, the cam lobes are pointing up as they should be
Question no. 2 - Should I set the clearances to the higher end or the lower end of the limits? Haynes says intake is 0.13 to 0.18mm and exhaust 0.18 to 0.23mm
Many thanks guys  |
| Nipedley |
| Nipedley |
 Posted: 14:07 - 20 Jul 2014 Post subject: |
Thanks Keith,
I figured it had to be something like that because the engine runs fine and very well
Any idea on whether to aim to get the clearances closer to the higher or lower end of the spectrum (if any need adjusting)?
Many thanks guys  |
 Posted: 14:12 - 20 Jul 2014 Post subject: |
Screw and locknut valves normally widen a bit with wear so if a choice from the tight end of the clearance to the lose end I would go for the tight end. But not something I would worry about too much and would probably just go for the middle setting.
With screw and locknut it is easy enough to adjust them (90% of the work is getting at the valves which you have done to check them anyway).
| blurredman |
 Posted: 19:00 - 20 Jul 2014 Post subject: |
These valves are fiddley. When I last tried to do them on mine it was a little frustrating.
Taking the oil line off allows easier access. Though, remember to put it back on before putting it back together! And give it a good few cranks on the motor before starting. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 51k. |
 Posted: 21:29 - 20 Jul 2014 Post subject: |
Bent feeler guages makes it a whole lot easier.
Get a set of feeler guages, clamp the tips as a bundle in a vice (not too tightly, just enough to hold them) and put a 45 degree bend in them. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 11 years, 225 days ago. Instead of replying here, would creating a new thread be more useful? |
