Removing brake pads
AcID ZeR0
PostPosted: 00:43 - 15 Jan 2005    Post subject: Removing brake pads Reply with quote
I'm half way through my first attempt of cleaning my brakes. Recently they've degraded and one piston wont move very freely causing it to rub gently on my brake disc.
I've got the caliper off but how to the brake pads come out they seem to be held in somehow?
mchaggis
PostPosted: 00:47 - 15 Jan 2005    Post subject: Reply with quote
Marjay wrote:
First you need to loosen the pad pins which should be visible on the back edge of the calliper. Next, remove the calliper bolts which hold your calliper onto your fork legs. Ok now ease the calliper off of the disc, being careful not to twist, bend or otherwise damage the brake hoses. Now get a piece of string and tie the calliper so that the brake hoses are not under any tension (to the mudguard or something). Now remove the pad pins and catch the pads as they drop out of the bottom of the calliper.
https://www.bikechatforums.com/viewtopic.php?t=19435
Any use?
Or am I just stating the obvious which you've already looked at? Embarassed
I must not be a troll...
Mmmm, Guinness
AcID ZeR0
PostPosted: 01:21 - 15 Jan 2005    Post subject: Reply with quote
That does help but the problem or issue rather is more specific to how the pads are fitted, at the back on the calliper there is a metal bar which the pads are attached to with a spacer in the middle I don't know how to get that metal bar out.
Guest
PostPosted: 04:33 - 15 Jan 2005    Post subject: Reply with quote
What bike? Then we can find a pic and give better advice Wink
AcID ZeR0
PostPosted: 15:24 - 15 Jan 2005    Post subject: Reply with quote
It's a brembo caliper.
I can't find a picture but to describe it there is a hole at the end of the caliper where there is a bar going across it. The brake pads are mounted through the bar there is a tiny clip at the end of the bar like a paper clip but removing that does nothing in the way of removing the bar.
cagiva gezzer
PostPosted: 15:35 - 15 Jan 2005    Post subject: Reply with quote
Like this?
A good twat with a hammer and punch gets mine out. Or, grip the end with mole grips and try rotating it. There is nothing holding them in, so its just a case of finding a method of pushing them out.
If its not like mine, check as it might be threaded in....
AcID ZeR0
PostPosted: 15:40 - 15 Jan 2005    Post subject: Reply with quote
Yeah that's them I think, So what do i try to remove the actuall pads or the metal bar at the back?
cagiva gezzer
PostPosted: 15:53 - 15 Jan 2005    Post subject: Reply with quote
The bar. Can't remember which way it goes, but its just a case of forcing it out. The end that the "paper clip" thingy was attached passes through the caliper body. Try a hammer and punch.
AcID ZeR0
PostPosted: 19:42 - 15 Jan 2005    Post subject: Reply with quote
Cheers mate thanks to you I've finally been able to clean my brakes out. Very Happy
The last post was made 21 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.86 - MySQL Queries: 13 - Page Size: 59.43 Kb
