No fuel going to carb...
Mac999
PostPosted: 20:37 - 20 Jul 2014    Post subject: No fuel going to carb... Reply with quote
Hi guys I've just brought another dtr 125 03 reg.. Basically only did 60,
I made sow adjustments and cleaned out the carb
But...
I was getting the over flow problem so I managed to get this sorted by pressing on the clip in the float
But now I'm not getting any fuel into the carb, if I stick some petrol into the spark plug it fires up straight away
Any ideas pls
mudcow007
PostPosted: 06:42 - 21 Jul 2014    Post subject: Reply with quote
you have basically shut the valve on the float so no fuel is getting to the bowl
re-adjust the "clip" on the float an you should be onto a winner
pdg
PostPosted: 09:36 - 21 Jul 2014    Post subject: Reply with quote
There's a fairly important thing called 'float height'...
Seems you either weren't aware of it or completely ignored it. If it's wrong, you'll never get the fuelling right, however many 'sow adjustments' you attempt to make.
The specified float height will be in the workshop manual, usually accompanied by instructions on how to set it.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
The last post was made 11 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 3.06 - MySQL Queries: 13 - Page Size: 35.15 Kb
