Accidently got WD40 on Brake Disc
TheArchitect
PostPosted: 12:22 - 21 Jul 2014    Post subject: Accidently got WD40 on Brake Disc Reply with quote
As part of my post wash ritual I was WD40ing various bits of the bike and I accidently got some on my rear brake disc.
Wiped it off straight away but this morning I'm sure the rear brake felt weaker. Could be paranoia mind.
Is this a problem I should address asap? Will my rear pads get damaged?
GSXR 600 K6 - Stolen
MT09 - Almost stolen
Snodvan
PostPosted: 12:25 - 21 Jul 2014    Post subject: Reply with quote
Done this. In my experience it is dodgy for a day but then wears off with a bit of heavy braking on a quiet road somewhere.
Snod
04 (UK Reg) BMW F650cs, but really 02 first Reg in Holland
Aff
PostPosted: 12:27 - 21 Jul 2014    Post subject: Reply with quote
Just use the brake a bit and you will burn it off in no time.
Electric Bike Project
TheArchitect
PostPosted: 12:29 - 21 Jul 2014    Post subject: Reply with quote
Phew! Thanks for confirming. Thumbs Up
TheArchitect
PostPosted: 12:43 - 21 Jul 2014    Post subject: Reply with quote
_Iain_ wrote:
I'd be inclined to spray the disc with brake cleaner & replace the pads.
Once pads are contaminated with oil they're never quite the same, given the cost is minimal and the risk is high if they should fail I'd swap em out.
But then that's just me Thumbs Up
Thought of this just to be on the safe side. I've got a can of brake cleaner spray somewhere at home so will spray the disc. Really want to avoid dismantling anything as I'm a bit of a retard when it comes to fixing things.
PostPosted: 12:45 - 21 Jul 2014    Post subject: Reply with quote
If it's soaked into the pads then that's not so great and the 'by the book' way of sorting it would be to replace the pads like Iain says.
But it's the back brake so I'd say fuck it and just carry on. Razz
Llama-Farmer
PostPosted: 20:02 - 21 Jul 2014    Post subject: Reply with quote
I'd take the pads out, give them a good clean on the friction surface with brake cleaner, and then wipe the disc down too, then just a bit of decent moderate to heavy rear braking.
As long as the pads didn't get drenched they should be ok... although technically you ought to replace them. Maybe if they've only got a few mm left you might wanna replace them anyway.
But as Ste said, it's the rear brake... nowhere near as crucial for slowing down as front brake so should be ok... may just need to put more pressure on with your right leg to get the same bite.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
Wull
PostPosted: 21:21 - 21 Jul 2014    Post subject: Reply with quote
I wouldn't worry about it mainly because the majority of bikers don't even use their rear brake.
I use mine all the time and I've never had any prolonged effects from wd40 contamination......rear brake still works a treat.
"Scooters are for men who want to ride motorcycles but prefer to feel the wind on their vaginas"
Llama-Farmer
PostPosted: 21:39 - 21 Jul 2014    Post subject: Reply with quote
I noticed this a lot when watching Mod1 tests.
I could understand if they were all self-taught and on 125s, but these were all people doing DAS on things like ER5s etc so had been taught by instructors.
One of the key things drilled into me by mine was always to use the rear brake when going slow, particularly when turning.
Slaloms, figure of 8s etc were so much easier when I was using the rear brake, kept the bike much tighter and lines much neater.
As a result it's become second nature to use the rear brake for stuff like that and I've had to replace rear pads but not the front pads (and the rear pads were already much newer than the fronts when I got the bike)
PostPosted: 22:49 - 21 Jul 2014    Post subject: Reply with quote
Ever hit a patch of diesel in the wet? Did you change your pads?
TUG
PostPosted: 02:15 - 22 Jul 2014    Post subject: Reply with quote
Brake cleaner and a thorough clean will be fine, although if it was me, I'd replace the pads, they cost nothing.
Haz ER-5, innit!
Llama-Farmer
PostPosted: 02:57 - 22 Jul 2014    Post subject: Reply with quote
I imagine you'd need a hell of a lot of diesel and standing water to splash enough onto the pads for it to be an issue.
PostPosted: 04:48 - 22 Jul 2014    Post subject: Reply with quote
Or for it to happen many times, as if you were riding all year round in all weathers. It's not just diesel, it's all water-borne contaminants from the road and there's a lot of them.
pdg
PostPosted: 09:15 - 22 Jul 2014    Post subject: Reply with quote
I'd like some free brake pads, where do you get them for nothing?
(Bit of a strange attitude considering your thread concerning a whole bike that cost roughly the same as 7 sets of branded pads...... Wink )
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
orac
PostPosted: 09:25 - 22 Jul 2014    Post subject: Reply with quote
get the brake properly hot and it will just burn off and all will be fine.
I use WD40 for cleaning my chain, it not uncommon to get some of the disc the (over spray). noramlly after cleaning the chain i will give the bike a least rinse offre-lube chain, wait 20 mins and go for a ride to making sure i get the rear brake hot and the correct feeling comes back
EazyDuz
PostPosted: 09:35 - 22 Jul 2014    Post subject: Reply with quote
Easiest way is to accelerate while lightly on the brake to heat it up
Llama-Farmer
PostPosted: 09:40 - 22 Jul 2014    Post subject: Reply with quote
Does WD40 not cause the rubber o-rings (or x-rings etc) to perish?!
evoboy
PostPosted: 10:26 - 22 Jul 2014    Post subject: Reply with quote
Ride it and apply the brake.
I wouldnt be worried about changing the pads. Only if you have drowned them in wd40 for a long period of time would I consider it.
I've had people come in with pads SOAKED in fork oil from leaking fork seals. They are most definitely for the bin.
APT Motorcycles
orac
PostPosted: 11:22 - 22 Jul 2014    Post subject: Reply with quote
nope, mine are all still in tact 2 year and more than 10k miles later. WD40 is relativly benign which is part of the reason its useless for anything more than gentle cleaning. it wont even touch the build up behind the the front sprocket cover. its doesn't even thing about brake dust.
shereen
PostPosted: 11:27 - 22 Jul 2014    Post subject: Reply with quote
The best way to sort this is to MTFU Thumbs Up
HTH
PostPosted: 11:29 - 22 Jul 2014    Post subject: Reply with quote
Changing the pads is overkill IMO, its probably all in your head.
You got a bit of it on your disc right? I really wouldn't worry.
TheArchitect
PostPosted: 12:44 - 22 Jul 2014    Post subject: Reply with quote
Yeh just some overspray really so wasn't a direct blast of it.
Anyway, this mornings ride felt a lot better, brakes are back to normal and bite well. Could be because I used the back brake a lot more on way home last night to get more heat and friction through them.
jeddy11
PostPosted: 15:31 - 22 Jul 2014    Post subject: Reply with quote
As stated many times in the workshop areas WD40 is a solvent and not a lubricant and should not be used as a lubricant or rust inhibitor just as a water disperser.
So if that is true your pads should be fine..
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
Aff
PostPosted: 15:34 - 22 Jul 2014    Post subject: Reply with quote
It does have a bit of oil in it.
The last post was made 11 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 132.84 Kb
