| bikernoobie |
 bikernoobie Two Stroke Sniffer
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 18:27 - 22 Jul 2014 Post subject: |
The plug is there, cos honda in their infinite wisdom, and after a couple of gazzillion computer modeling runs, on their million dollar super-computers, by highly paid, highly educated engineers... decided it should be.
IF, the thing would be SO much better without it... they wouldn't have fitted it.
As to the air-filter... if you have to ask how to change one... then you SURE as fuck shouldn't be trying to make performance altering modifications to your motorcycle.
As for power... power is rate of energy transfer... energy is coming from your petrol... so if you get any more power, you are going to use more petrol, aren't you?
Meanwhile; formula for power in an engine; Power = cylinder displacement x Cylinder Pressure x Engine revs.
Only way to get more power without reving the thing more highly, or boring the thing out, is to cram more 'charge' in the cylinder to make a bigger bang and get more pressure. This is not governed by the air-filter. all that does is stop grit getting into the engine.
So, leave the thing alone, enjoy the reliability and ecconomy the thing has as standard... cos, bottom line, is, its a 15bhp learner-legal. You could double that power, and it would still be a pretty slow bike. And very unlikely even a very serious program of considered tuning, probably including a turbo, would get that big a gain. so if you want more power than the thing has... buy a bigger bike, that has it as standard... and enjoy the reliability that comes with it. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| biker_bob |
 biker_bob Derestricted Danger
| Dave M |
 Dave M Scooby Slapper
| Teflon-Mike |
 Teflon-Mike tl;dr
| Commuter_Tim |
 Commuter_Tim World Chat Champion
| bikernoobie |
| ferrisio |
 ferrisio Scooby Slapper
| biker_bob |
| andyscooter |
 andyscooter World Chat Champion
| _Iain_ |
 _Iain_ Banned
 Posted: 09:10 - 23 Jul 2014 Post subject: |
Have you considered welding the sprocket on? ____________________ Please be aware that the above post may be full of complete nonsense.
| wr6133 |
 wr6133 World Chat Champion
 Posted: 10:50 - 23 Jul 2014 Post subject: |
Unless the current airbox design is so bad it is enormously restrictive you won't gain by adding a cone filter. Also if you do you will need to rejet the carb, as has been said already the engine works on a mix of fuel/air so if you increase the amount of air you will need to increase the amount of fuel too with bigger jets. If you don't do that you will likely lose power as the bike will run way to lean.
Positioning of the filter also can be a bugger with cones, this photo is my old 250 with cones on
https://i1249.photobucket.com/albums/hh504/wr6133/LPIC4843_zpsa3463208.jpg
Now a bit of rain was all good but see how exposed they are? When we had that heavy rain and flooding earlier this year a number of times I was hitting large puddles, the things got wet and the bike would cough and splutter then stop. So if you ride all year in crap weather take that in to consideration. You can get protective cover type things for the cones but then you have basically created an airbox so what was the point in them initially.
The vara is the same engine as the 125 shadow? If it is I think there are bore kits out there to make it bigger displacement (170cc if I remember correctly) that would be the most realistic way to see a tangible power gain. |
| map |
 map Mr Calendar
 Posted: 12:21 - 23 Jul 2014 Post subject: |
I'm in the leave it as standard camp.
I really don't know why people decide they know better, especially for 125s, after the manufacturer has designed a bike, taking into account all the variables and coming up with the compromise of handling, power, efficiency, comfort, mpg, etc. (it's all a compromise). See also Tef's post above.
No don't get me wrong. I applaud engineering modifications, turbos and the like. Except there you're really creating a new model not envisaged by the manufacturer. They're hardly little tweaks.
Then again some bikes benefit from certain mods like better brakes. e.g. guy who worked here put a Kawasaki (don't know which) front end on some Harley or other. Now that's an upgrade imo  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Teflon-Mike |
 Teflon-Mike tl;dr
| pdg |
 pdg World Chat Champion
 Posted: 15:55 - 23 Jul 2014 Post subject: |
Leave it alone, if you fuck with it then it'll sound shit, it'll be shit, it'll break and you'll look like a cunt.
| biker_bob wrote: | No such thing as free power. Improving the power will make the MPG worse normally.
Changing the air filter will probably make it more noisy as you'll get air box sucking noise added on to the normal noises. It will also, most likely, reduce the power and MPG.
An engine needs the right mixture of fuel and air to work at it's optimum. Increasing both will increase power (within limits), increasing just one will naff up the mixture and reduce power and MPG. |
A very little bit of what you have written is correct, the rest is balls...
Either:
A - you have no fucking clue what you are really on about and stole some sentences from a google search.
or
B - you have no fucking clue how to get across what you know because google doesn't write it for you.
Personally, I'm going for A+B = bodyguard's brother.
For a start, you are saying buggering up the air/fuel mixture will reduce the MPG - so it makes it better? That's what reducing the MPG means.
I have lost the will to carry on, so I'll repeat - OP, leave it the fuck alone...
One last thing:
| BodyGuard wrote: | anything at all |
Fuck off, cunt. ____________________ Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you. |
| pdg |
| biker_bob |
 Posted: 16:59 - 23 Jul 2014 Post subject: |
| pdg wrote: | Leave it alone, if you fuck with it then it'll sound shit, it'll be shit, it'll break and you'll look like a cunt.
Either:
or
One last thing:
Fuck off, cunt. |
I see you're thinking that reducing the number of miles you do per gallon is a good thing then? Do you work for Shell or BP I wonder?
So glad to see that you've lost the will to carry on, the world will be a better place. |
| Quornholio |
 Quornholio World Chat Champion
 Posted: 17:04 - 23 Jul 2014 Post subject: |
| biker_bob wrote: | | pdg wrote: | Leave it alone, if you fuck with it then it'll sound shit, it'll be shit, it'll break and you'll look like a cunt.
Either:
or
One last thing:
Fuck off, cunt. |
I see he quoted what you said, and then asked if YOU thought that was a good thing. ____________________ https://i.imgur.com/fMrhZnH.jpg?1
Everyone give this dood green karma pls --> https://www.bikechatforums.com/viewtopic.php?p=4045389#4045389
XxXxX |
| biker_bob |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 18:31 - 23 Jul 2014 Post subject: |
| pdg wrote: | (Tef, you are a special case and don't count for the purposes of this situation  ) |
Why thank-you.. but, think you'll find there are fair few special cases like me, not just in real life, but on this forum.
Meanwhile... CHILL-OUT man!.... Bikernoobie is an over eager school-boy, hardly old enough to shave, with a head full of ideas, lapping up learning like an alcoholic under the drip-tray in the tap-room, and making about as much sense of what he's getting! WR's advice of a big-bore is almost 'sensible' compared to suggestion of air-filters and air-box drain plugs, while Biker_bob's sort of got the answers I'd give, with as much ambiguity and less verbosity. While you might as well stop telling BunnyGuard to fuck off... it's quite obvious by now he's not going to...... and now Smiler's got a licence, we could do with a new Forum Gimp to abuse... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Quornholio |
 Posted: 20:09 - 23 Jul 2014 Post subject: |
| Teflon-Mike wrote: | | pdg wrote: | (Tef, you are a special case and don't count for the purposes of this situation  ) |
Meanwhile... CHILL-OUT man!.... Bikernoobie is an over eager school-boy, hardly old enough to shave, with a head full of ideas, lapping up learning like an alcoholic under the drip-tray in the tap-room, and making about as much sense of what he's getting! WR's advice of a big-bore is almost 'sensible' compared to suggestion of air-filters and air-box drain plugs, while Biker_bob's sort of got the answers I'd give, with as much ambiguity and less verbosity. While you might as well stop telling BunnyGuard to fuck off... it's quite obvious by now he's not going to...... and now Smiler's got a licence, we could do with a new Forum Gimp to abuse... |
Yeah! Have you got a CB to sell him? ____________________ https://i.imgur.com/fMrhZnH.jpg?1
XxXxX |
| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 20:44 - 23 Jul 2014 Post subject: |
Having looked into boring out, skimming and exhaust systems to make my varadero go faster instead of selling and getting something bigger (had passed my tests) I found out a couple of things;
The exhaust system has been designed to be a restrictor, the exhaust from the rear cylinder is much thinner than the front, no after market exhaust actually increases the performance as the manufacturers are all worried of putting a bike over the power limit and having it come back to bite them, after market exhausts might make it feel to rev a bit more or be louder but that's your lot
upping the compression was decided to be likely to be problematic on something that's meant to be my daily transport so idea abandoned.
altering air / fueling - the varadero revs nicely and smoothly through the rev range, being able to pull away in 2nd with only a slight bit of throttle and steady use of the clutch and my instructor didn't realise I'd not been using 1st to set off on the brake practice runs!
altering the air or fuelling you risk upsetting this happy little engine's well balanced and willing performance, possibly introducing flat spots in the rev range where the bike doesn't pull quite so well at points in the rev-range which isn't great on a 125.
so this leaves the gearing,
put a 1tooth smaller sprocket on and you'll accelerate faster to, say 50mph than you currently do but at the expense of top speed
put a 1 tooth larger sprocket on and you'll be a bit slower accelerating and be changing gear a bit later but you'll have a higher top speed.
with regards to bungs, plugs and blanking plates in the air box, my ZZR that I have now has 4 of them, it won't run properly without them in place - they are there so that you can get a screwdriver in at the right angle to remove the air box from the carbs. ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
| pdg |
| pdg |
The last post was made 12 years, 62 days ago. Instead of replying here, would creating a new thread be more useful? |
