Thundercat clutch
el_oso
PostPosted: 17:07 - 23 Jul 2014    Post subject: Thundercat clutch Reply with quote
First off, what sort of mileage should you expect from a clutch? I'm quite easy going on the clutch. I don't tend to launch the bike quickly away from sets of traffic lights or clutch up wheelies.
In recent weeks the clutch/gear change seems to have changed quite dramatically. I've installed a brand new cable as the last one had started to fray. There still seems to be a lot of free play at the lever end with very little clutch 'feel', it seems like it's either on or off. Before I drain the oil and check the thickness of the friction plates does something like this sound like a worn out clutch?
Duke 390
Car: Jeep Wrangler 4.0L
base
PostPosted: 19:23 - 23 Jul 2014    Post subject: Reply with quote
I am not really sure what set up the thunder cat has but expect much the same as the fzr 600 does the cable go into the sprocket side of the bike? have you readjusted the mechanism the cable goes into?
also alot of times you can get away with leaving a bike on the side stand and take the clutch cover off without draining oil
el_oso
PostPosted: 12:38 - 24 Jul 2014    Post subject: Reply with quote
you can adjust the mechanism? I've not noticed this.
When I replaced the clutch cable I did take the sprocket cover off and scraped all the crud away and then cleaned with paraffin. It's now looking clean and shiny. Will have a look at the mechanism this weekend if I get time.
Duke 390
The last post was made 12 years, 85 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.8 - MySQL Queries: 13 - Page Size: 39.36 Kb
