Solar Panel & Other non mains trickle chargers
Solar panel trickle charger?
That'll do it
37%
 37%  [ 3 ]
Never gonna work
25%
 25%  [ 2 ]
Solar who? Sun does what now?
37%
 37%  [ 3 ]
Total Votes : 8
Rogue_Shadow
PostPosted: 00:10 - 23 Jul 2014    Post subject: Solar Panel & Other non mains trickle chargers Reply with quote
Hello BCF
This could of gone in the Geek Zone section, but hey'o.
I've recently moved out & will be storing my bike in a shed in the near future. As I don't use my bike to commute, there is risk for the battery to lose charge or not keep at optimal charge. In a perfect world I would simply connect up a mains trickle charger, however with the shed being away from any mains power and no chance of running an extension lead I was thinking of other options.
Does anyone have any ideas how to trickle charge a battery without mains power, i'm not after a battery charger or something that will return a battery from the dead.
Would a solar panel trickle charger system fit the bill?
I've seen a few on ebay/ maplins & other gadget shops, but didn't know if they work well or safe to use.
( Shed inferno's need not apply )
Any help would be appreciated Thumbs Up
Itchy
PostPosted: 00:48 - 23 Jul 2014    Post subject: Reply with quote
A big one will do it, but a small one not a chance. I had an A4 sized one it ended up killing a battery.
You know you can remove the battery from the bike and take it inside right?
CaNsA
PostPosted: 01:42 - 23 Jul 2014    Post subject: Reply with quote
With the added bonus of the battery not getting buggered when the weather gets super cold Thumbs Up
@ Rogue_Shadow
Click and read
doggone
PostPosted: 07:48 - 23 Jul 2014    Post subject: Reply with quote
Will be better than nothing, a bit unreliable though and most so when you really need it. Like in Winter.
I use a 4watt one on a mini-digger and it keeps it topped up.
That battery is a good bit bigger than any bike.
If a battery is flat you will never get it to charge up with one though.
Llama-Farmer
PostPosted: 09:55 - 23 Jul 2014    Post subject: Reply with quote
I'd just get a big enough extension lead to use an Optimate in the shed once a week... or remove the battery from the bike and Optimate it in the house instead.
Solar powered trickle chargers are never particularly brilliant, they have to be big to work well. And in a shed it's going to be in the shade or indirect light a lot as well, rather than in direct sunlight.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
PostPosted: 12:35 - 23 Jul 2014    Post subject: Re: Solar Panel & Other non mains trickle chargers Reply with quote
What's your budget?
A cheapish solar panel on ebay designed for motor-home and so on with a £10 pwm controller should do the trick.
You'll need it on the shed roof, presuming it gets direct sunlight.
The last panel I got was a 235w 24v one for £80; unused but not sold as new.
That's overkill for your needs - 30w or so I reckon should be about right. The maplins ones tend to be too low power to be useful.
PostPosted: 20:19 - 23 Jul 2014    Post subject: Reply with quote
They will have been charging batteries. However, they do tend to be noisy.
They are often used in combination with solar - hoping that if you don't have sunny days, there will probably be some wind.
Charging a bike battery doesn't need much, so personally I'd stick to solar as it's simpler due to no moving parts and so on.
Rogue_Shadow
PostPosted: 21:29 - 23 Jul 2014    Post subject: Reply with quote
Thanks for your feedback guys
Yes Cansa, KISS again
However taking the battery out or running an extension cable to the shed is not simple. It's hassel Laughing
Sticking a solar panel in the window of the shed or even on the roof, would be far more convienient that the above.
Like I mentioned, this is not to charge the battery from flat. It's something that will be connected up occasionally after a ride, knowing it maybe a week or so till I ride again.
I'll have a gander when I'm closer to getting a shed, but it seems a viable option. I was just worried about damaging The battery or the charging system bursting into flames Laughing
PostPosted: 21:55 - 23 Jul 2014    Post subject: Re: Solar Panel & Other non mains trickle chargers Reply with quote
£25 panel:
www.ebay.co.uk/itm/251131513443
£3.70 PWM unit:
www.ebay.co.uk/itm/221494053775
Bit of wiring, couple of connectors and a fuse (incase water makes a short circuit or something) and it should be sorted well enough to keep a bike battery topped up.
Without the controller* you can have the battery discharge through the panel. I wouldn't go less than 20w, which is only a little over 1a - but that should be enough to keep it topped up I reckon.
(*And I've got no idea if it's actually good enough - my 20a one cost me a tenner posted from the UK and has done me fine, so a £3.70 3a one from china doesn't seem unreasonable.)
bikersupermot...
PostPosted: 13:42 - 26 Jul 2014    Post subject: Reply with quote
iv got a 20w polycrystalline panel - had it 7years now ( they were really expensive then! ) - its connected to a charge controller which is then permanently connectly to my van battery - never had a flat since.
tinybikes
iooi
PostPosted: 16:12 - 26 Jul 2014    Post subject: Reply with quote
Rogue_Shadow wrote:
It's something that will be connected up occasionally after a ride, knowing it maybe a week or so till I ride again. :
Well unless the bike is going to be stood for months...
KISS
Says don't bother
A decent battery should hold its charge for months at least. Only worry would be if you have a alarm on the bike.
My last divvy started after 12 months in the garage of not being used.
Rogue_Shadow
PostPosted: 22:06 - 26 Jul 2014    Post subject: Reply with quote
My SV wouldn't start after 3 weeks Laughing
The last post was made 12 years, 96 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.64 - MySQL Queries: 15 - Page Size: 81.71 Kb
