| eddie011 |
 eddie011 Two Stroke Sniffer
| Efes123 |
 Efes123 World Chat Champion
 Posted: 11:16 - 24 Jul 2014 Post subject: |
You could just have a screwed battery that's not holding a charge. Or it could be your rec/reg is fried, but I seriously doubt it wired wrongly.
Check the battery with a multimeter with ig off, on, running, and reving ____________________ Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD |
| RhynoCZ |
 RhynoCZ Super Spammer
| P.addy |
 P.addy Red Rocket
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 14:30 - 25 Jul 2014 Post subject: |
Reg/regulator problem or , if fitted a ballast resistor that's used to dump excess electricity. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 16:17 - 25 Jul 2014 Post subject: |
It sounds to me, like a fukken-shrunk battery.
Batteries loose charge capacity with age and heavy use. They get 'smaller' in effect.
Bigger batteries on bigger bikes are bigger, physically, and in charge capacity, but they still work at the same volts; so getting 12v on the terminals doesn't tell you how much charge capacity they have or whether the battery is 'good' or not.
If the electrical equipment uses more electric than the generator can supply, difference has to come from the battery. Only if the generator is making more power than equipment is using, will the battery charge.
It's possible, you have an AC-Direct lighting system; which powers the lamps directly off un-rectified AC current from the generator; that does make lamps dim and bright with revs, especially if a higher wattage bulb's been fitted; but if that doesn't happen when you have charged the battery, implies you have regulated DC lighting. AND fact that lights are behaving like AC-Direct, brighting and dimming with engine revs, implies that there's probably nothing wrong with your reg-rect; lights are getting power, so genny is making it, and it is getting to the battery, (which is probably 'robbing' a fair bit, if it's kerfuckered, acting as a resistor, taking amps, not providing them) and what's making it to the lights is just not enough to keep-em lit.
But tells you even if battery were good, at lower revs; battery will be powering lights, not the engine....
So, if you do lots of short journeys at slower speeds, short shifting, never reving the engine over maybe 3,000rpm, and you have the head-lamp constantly on, even in day-light... good chance that the light is taking almost all of its power out of the battery, and the generator is never making enough 'spare' to top it back up.
And if the battery is old, and harder used, the 'reserve' the battery has to keep making up the difference will be getting ever smaller and smaller, until the battery simply doesn't hold ANY charge... and you get what you have seen.
As suggested, try a new battery. A good battery, probably only has a 2-3 year life anyway; and this is most likely cause of problem you are seeing.
BUT, heavy load on the battery, using Day-Time-Running-Lights, and not revving the engine to give it a chance to charge, is likely to be making the problem appear. And if its electric start, and you are doing shorter journeys, not giving genny chance to put charge back in the battery between starts, could be even worse.
And; if using Day-Time-Running-Lights for 'conspicuous'... if you can turn them off... do so. Using the side-light in day-light can still provide desired conspicuity, lighting up the head-lamp bowl. And give the bike a chance to charge; use the revs more, ride for response around town, dont make work for yourself, short shifting up too many gears when you dont need to, demanding more unnecessary down shifts when you dont need them, and keeping revs low and choking generators chances to charge the battery; Use the Revs... and take it out for a good thrashing once a week; good half hour or hour long blast on country roads, get the speeds up, and give the genny a chance to make some spare amps to keep battery topped up; circulate some oil and wash fuel through the main jets 'Blow out the Cob-webs' as we say. Bikes actually likely to appreciate it. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 12 years, 65 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 54.54 Kb
