Really in need of some input on this one
UpcomingChris
PostPosted: 13:52 - 24 Jul 2014    Post subject: Really in need of some input on this one Reply with quote
So i have a CG125, It's been sitting for quite a few months, The other day i tried getting it going and failed, It was not even sparking, so i put it away, Yesterday i went to have another go, and it was sparking, i got it running and took it for a little spin, it was perfect, Today i go down to go and take it for a MOT and again there's not even a spark, I tried bump starting it and it ticked over for about 5 seconds, revved it a few times and then it just died down to nothing, After it almost bumped and did tick over i figured it must be sparking, But when i tested it there was no spark, Absolutely nothing has changed since yesterday and I'm completely confused about what's going on, Any help is greatly appreciated.
It's a Honda CG125, 98 - 00 model, Kick only, nothing fancy on it
P.
PostPosted: 13:54 - 24 Jul 2014    Post subject: Reply with quote
Have you tried a new spark plug.
Remove the cap which sits on the spark plug, usually unscrews, trim a few mm of the cable off, then screw it back on... needs a little bit of force to do so.
Retry. Would probably give the battery a charge.
UpcomingChris
PostPosted: 13:56 - 24 Jul 2014    Post subject: Reply with quote
Forgot to mention, It's a fairly new spark plug and a new Coil, and the battery had a full charge yestrday, The bike was even kicking over yesterday without the battery!
P.
PostPosted: 14:37 - 24 Jul 2014    Post subject: Reply with quote
I'd try that then. Thumbs Up
UpcomingChris
PostPosted: 14:38 - 24 Jul 2014    Post subject: Reply with quote
I've never actually thought of that and that makes sense, Thanks alot!, I'll report back Smile
UpcomingChris
PostPosted: 17:13 - 27 Jul 2014    Post subject: Reply with quote
Im literally at a dead end here. I tried what you suggested. I checked every connection everywhere on the bike I could find, tried different spark plugs and leads / caps. The electrics are perfect. Just no spark. I've tried everything I could possibly think of. I stood there
for ages just looking at it to check if I missed anything. And nothong. Absolutly no sign of a spark. What could cause this to just happen over night? It was running perfectly the day before... I just dont get it.
Could it be tje CDI or whatever it's called?
andy_uk
PostPosted: 17:18 - 27 Jul 2014    Post subject: Reply with quote
Have you checked the kill switch, in case it's intermittently making/breaking the connection?
UpcomingChris
PostPosted: 17:39 - 27 Jul 2014    Post subject: Reply with quote
As far as I'm aware it doesn't have a kill switch as such. It's a 98-00 model and has it incorporated into the ignition or something. But I've literally had the headlamp open checking every connection. Nothing looks out of place.
Ichy
PostPosted: 18:26 - 27 Jul 2014    Post subject: Reply with quote
Have you checked the coil connections? fuses? You will need to get a multimeter on it to check for continuity. Only other thing I can think of is a faulty ignition switch or generator.
PostPosted: 19:01 - 27 Jul 2014    Post subject: Reply with quote
Check for power at the coil when the ignition is on. No power = problem with coil power feed. Power = problem with coil, lead, plug or CDi/pickup.
Make double sure the battery connections are clean and tight.
UpcomingChris
PostPosted: 19:43 - 27 Jul 2014    Post subject: Reply with quote
checked literally everything. What do you mean by generator?
mattsmith95
PostPosted: 21:32 - 27 Jul 2014    Post subject: Reply with quote
Could be the ignition switch....sounds unlikely but I've had a faulty switch a while back.
UpcomingChris
PostPosted: 06:38 - 28 Jul 2014    Post subject: Reply with quote
Coil power feed?, What exactly is that, the 2 cables leading to the coil?, I've tried numerous coils / Caps and Plugs and still nothing, It even kicked over without the battery in place the day before, so i can't see a issue with the battery causing it, since all the electrics are runnig fine anyway. What is really bugging me is how it was running fine, and in the space of 12 hours or so having nothing changed there's absolutly no sign of a spark, but everything else is fine, As i've said i've checked every connection i can find, cleaned connections, Checked for lose connections, and everything seems fine. Sad
mudcow007
PostPosted: 10:00 - 28 Jul 2014    Post subject: Reply with quote
when i was having issues with the spark on my CG
i took the coil off an tested it on my bench, connecting it direct to a battery an run a wire to the tip of the plug an see if it sparks
if it does, the problem is on the bike an not the coil
PostPosted: 16:39 - 28 Jul 2014    Post subject: Reply with quote
You can wreck a good coil testing it like that.
stevo as b4
PostPosted: 17:22 - 28 Jul 2014    Post subject: Reply with quote
I had a real dumb blonde moment helping my mate try to get his CG125 running after he'd bought it, and done some work.
He ordered a new battery and we spent ages checking the wiring, plug, coil etc etc bump starting and the rest, before realising it was a 6v battery we'd fitted not a 12volt like it had before! Embarassed
Bunny Lingus
PostPosted: 20:01 - 28 Jul 2014    Post subject: Reply with quote
Your ignition switch ends in a plastic connector block. Disconnect the block & try & start the bike. You wont have any dash lights & your headlamp may or may not work but the engine should start. You say you have a spare spark plug? With the ignition switch still disconnected connect the plug to the HT lead & make sure the business end is touching the engine block or fins but don't hold it on with your hand unless you like electric shocks. Kick it. You should see fat blueish sparks. If not repeat with the block connected. If still not, unscrew the HT cap & push a nail or screw a screw into the lead & earth that to the motor. Kick it. Examine your coil & make sure the earth (green wire) has not come adrift.
Still no spark? Examine the wires that come out of the left hand side crank case. These are the wires that run from your geny to your CDI. Look for damage to the insulation. Any bare wire making contact? Examine the block connector that the wires go to. Disconnect it & look for melted plastic. If good, spray some WD40 in & around the block & reconnect. Try starting it again.
No good? Examine your CDI block connector & hit that with some WD. There is also a plastic envelope containing a widget, check & spray its block. If you still ain't firing then its time to break out a multimeter & run some tests but concentrate on your ignition switch & main ignition wire 'cos you may have a short. My CG engine is electric start. Is yours? If yes, check the fuse under the left hand panel... Good luck. Ok, just checked... Kick only. Where are you? Maybe someone near you can help by swapping out your coil &/or CDI.
Bunny Lingus & The Flipside Faggots
zapmole
PostPosted: 20:33 - 28 Jul 2014    Post subject: Reply with quote
How big is the spark plug gap, I had a problem it's mine recently thinking I had a good gap but turns out it was far too big brought it in a bit sparking perfect now
Honda CG 125 red 1991
zapmole
PostPosted: 20:38 - 28 Jul 2014    Post subject: Reply with quote
UpcomingChris
PostPosted: 07:11 - 29 Jul 2014    Post subject: Reply with quote
I've tried a combination of plugs / Caps / Coils that all worked on my friends bike. How would i know if the CDI was buggered?, Would a busted CDI cause this kind of issue?, Is it something that can just stop overnight?. Also, Could it be a bad earth somewhere?, I've checked up and down and i can't see anything that would suggest it, but I'm not actually too sure where the earths are on a 98-00 CG125 model. Also, you say to check the cables that come out of the left hand side crank case, Where exactly are these wires?, Not too sure what ones you're referring to.
And also you say the ignition ends in a connector block, Where about would this be located?.
I'll try everything you suggested probably later today, i appreciate the help, Sorry for the questions, I'm not the most Mechanically minded of people!
mudcow007
PostPosted: 07:42 - 29 Jul 2014    Post subject: Reply with quote
ohh Embarassed i did not know that...
worked on my CG though
Robby
Dirty Old Man
PostPosted: 08:05 - 29 Jul 2014    Post subject: Reply with quote
Alternative idea, water in the carb.
I'm assuming UpcomingChris is a bit of a mechanical noob, so may be making some of the basic mistakes in fault finding. When looking for a spark on a kick-start only bike, you need to be doing it somewhere dark. Whilst we always say you should be looking for a fat, blue spark something like that is likely to only make a weak looking orange spark when you're kicking it over and trying to look at the plug. If you do that in any kind of light, you might not even see it.
If the carb is full of water then it may occasionally run for a few seconds, but mostly just fail. Hold a small container under the carb and open the screw on the bottom of the float bowl. Let it drain for about 20 seconds, then close the screw and inspect the contents of the container. If there is a layer of clear or dirty liquid at the bottom, or some drops that don't mix into the petrol, you have water in there. Now the water is drained out of the carb, try starting it again.
If there is no water, have a good look at your fuses, or just replace them anyway. I don't know if your bike has modern blade fuses, or old style round glass fuses, but I have more than once come across silly problems with poor contacts on old style glass fuses. It looks ok, it works sometimes, but the fuse itself has a poor connection. New fuses fixes the problem cheaply.
Of course, before doing any fault finding, make sure that the battery is fully charged.
UpcomingChris
PostPosted: 08:22 - 29 Jul 2014    Post subject: Reply with quote
I am a bit of a noob when it comes to this sort of thing. I've done my best to see the spark, I've had 2-3 people helping me and they're also convinced there's no spark, I've done it before and spotted a faint spark, It's in a fairly shadowed area so it's not too difficult to spot.
It's a freshly charged battery, If the carb was full of water (Which i don't see how since it's been locked away dry for a few months), that wouldn't stop it from sparking would it?, It was running fine the day before, and in the space of about 12 hours it's a dead spark again, and nothing has changed. And if the fuse was gone wouldn't that not allow the electrics to function?, Everything else on the bike is perfect
Bunny Lingus
PostPosted: 16:09 - 29 Jul 2014    Post subject: Reply with quote
https://i24.photobucket.com/albums/c4/bunnylingusandtheflipsidefaggots/20140729_163443_zps33a78f39.jpg
https://i24.photobucket.com/albums/c4/bunnylingusandtheflipsidefaggots/20140729_163506_zps84ad077b.jpg
Ignore the photos for now 'cos I wanna eliminate the ignition switch first...
Ok. Your ignition switch goes to a block connector similar to the ones pictured. Underneath the bit you put your key into is a black wire. Actually that's a lie, beneath the black stuff are four or five wires. One is black, one is red don't worry about the others for now. All these wires go to a white (or black) connector block. You just need to disconnect the block & it pulls into two pieces. One bit goes to the key switch & the other goes to the loom. Inside the block are pins & slots. I can't show you that 'cos mine is hot wired & that is what you're about to do to yours. The block that goes to the loom should be slots. Your mission Jim, should you choose to accept it, is to connect the black wire to the red wire by sticking a short bit of wire - one end into the red slot & the other into the black slot. Your ignition is now hot wired & your neutral light should light up.
Kick your bike over. It should fire up if it was your switch that was faulty. Try that & get back to us. Make sure that it is the black wire you connect to the red wire & not the black & white wire...
UpcomingChris
PostPosted: 06:56 - 30 Jul 2014    Post subject: Reply with quote
Thanks!, i'll give this a try probably later on today and report back
The last post was made 11 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 138.76 Kb
