| london_biker |
 london_biker Derestricted Danger
| Howling TerrorOutOfOffice |
 Posted: 17:55 - 25 Jul 2014 Post subject: |
First things first get a new battery. They don't last long without some sort of maintenance charge and I'd hazard a guess that it wasn't kept on a trickle charger.
Next up...Did you store it with a brimmed tank of fuel. Airgaps allow condensation to form inside the tank. Water is heavier than fuel..you can guess the rest.
Inspect condition of the airfilter.
Plugs. whip them out and give them a gentle clean.
Your business.... but you'd get more cash back than the £25 you spend on the MOT. ____________________ Diabolical homemade music Bandcamp and Soundcloud
Last edited by Howling TerrorOutOfOffice on 17:58 - 25 Jul 2014; edited 1 time in total |
| base |
 base Trackday Trickster
| orac |
 orac World Chat Champion
 Posted: 18:18 - 25 Jul 2014 Post subject: |
how long is a piece of string,
all you have said, is it wont start, does it, if so does it crank fast like it should or a slow laboured crank.
have you even inspected the carbs, did you use new fuel (modern fuel only normally last about 6 months of storage in normal fuel tanks).
do you have spark, do the lights works. the list kinda goes on for fault finding why the thing wont start, and how to get something running, well that will depend on your machanical abilities, or lack of. ____________________ Current rides - 2016 Triumph Street Triple Rx, 1994 Suzuki Bandit 400 VM, TGB 204 Classic 125cc
"with nothing left to lose, there is everything to gain. It's not the size of the dog in the fight, it's the size of the fight in the dog" |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 18:24 - 25 Jul 2014 Post subject: |
Before spending any money, go through the checklist first.
Does it turn over?
If yes, then does it spark?
If yes, then are the plugs getting wet?
If the answer to any of these questions is no, then go through the process of elimination.
If it's not turning over, is it down to a dead battery, a random earth in the loom or a knackered starter solenoid? Check the battery voltage - if that's good, then try shorting the solenoid, see if that forces the engine to turn over. If it doesn't, then there's a chance that solenoid is shagged.
If it turns over just fine, pull one of the plugs, touch it to the engine, see if it sparks. If it doesn't, then check the impedance of the coils, and also the state of the HT leads - check them for continuity. If you're not getting continuity, try unscrewing the plug cap snipping off the last 5-8mm off the lead, then screwing the plug cap back on to it.
If it's sparking, but not catching, see if the plugs are getting wet when you've turned over the engine for a while. If they're not, then there's a chance that the carbs are gummed up. Personally, I wouldn't want to strip the carbs without good reason. I've been down that path, and it's even less fun than it sounds.
Judging by your username, you're in London, which means that you're relatively proximate to me. I can lend a hand, should it be required. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| london_biker |
| london_biker |
The last post was made 12 years, 80 days ago. Instead of replying here, would creating a new thread be more useful? |
