Super unleaded fuel?
mikesaa309 This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
PostPosted: 17:59 - 25 Jul 2014    Post subject: Reply with quote
Do you mean super unleaded, as in just one with a higher octane rating, or do you mean Optimax / Vpower / whatever they call it this week?
Higher octane rated fuel on its own will do you stuff all good. Bandit it set up for far lower octane fuel than standard unleaded I think
As an aside, out of amusement I did try it on my 1200 Bandit (which does run a higher compression ratio than standard) when doing top speed runs. Made no difference.
smithyithy
PostPosted: 18:11 - 25 Jul 2014    Post subject: Reply with quote
Placebo.
EazyDuz
PostPosted: 19:11 - 25 Jul 2014    Post subject: Reply with quote
Some fuels have better cleaning additives in them (so they say). I don't believe it though
orac
PostPosted: 19:18 - 25 Jul 2014    Post subject: Reply with quote
the octane rating is a measure of resistnace to ignition, or more importantly pre-iginition. the 1200 bandits run a fairly low compression ratio so i would not expect to see much of an improvement.
the higher compression ratio and the more accuratly controlled the ignition timing is the greater the affect og the super unleaded
i know it cars but the same sort of idea will apply to bikes
https://www.youtube.com/watch?v=gQghB4asSnI
DRZ4Hunned
PostPosted: 19:25 - 25 Jul 2014    Post subject: Reply with quote
They all come from the same refinery.
EazyDuz
PostPosted: 19:31 - 25 Jul 2014    Post subject: Reply with quote
Please link proof of that statement
Irn-Bru
PostPosted: 19:34 - 25 Jul 2014    Post subject: Reply with quote
I've tried it in all my bikes, never made any difference at all. Petrol is expensive enough as it is, it would have to make my bike feel much quicker, or increase MPG noticeably for me to bother with it.
PostPosted: 19:45 - 25 Jul 2014    Post subject: Reply with quote
It shouldn't make a difference on most bikes. The octane rating will be sufficient to avoid engine damage or not. The exception is the tiny number of bikes that have a knock sensor to feed back to the ecu to adjust timing and even then the difference is tiny.
More cars have knock sensors, but again the difference is tiny (couple of percent or so). However the big exception is cars with turbos where they can up the boost to take advantage of higher octane petrol. Then the difference is noticeable.
CaNsA
PostPosted: 19:50 - 25 Jul 2014    Post subject: Reply with quote
https://www.google.co.uk/search?q=site%3Abikechatforums.com+"super+unleaded"
About 1,900 results
FlightRisk
PostPosted: 20:00 - 25 Jul 2014    Post subject: Reply with quote
In a bandit!? Ha!
No, it will make no difference at all. Except maybe the very slight weight reduction to the contents of your wallet will infinitesimally decrease your 0-60 time.
Run on what the manufacturer recommends.
c-m
PostPosted: 20:49 - 25 Jul 2014    Post subject: Reply with quote
Murco tell me that their Super Unleaded doesn't contain any ethanol
grr666
PostPosted: 21:38 - 25 Jul 2014    Post subject: Reply with quote
I use Super in my car by manufacturers recommendation, it will run
on regular but loses significant bhp (about 30-45 depending on fuel quality)
My wifes little eco city car starts better from cold in winter on Super so
we run that all year round as MPG is also improved enough on her commute
(2 extra days round trip commute on the same tankful) to cover the extra cost.
My chainsaw (I have 2 wood burning stoves to keep running in winter) runs on super and 2 stroke
for the same reasons, 3 pulls on the cord and it's
going compared to about 10 pulls on regular and 2stroke, runs less smoky too...
I now use it in the bike as well as I'm in the habit of putting super in everything else but can't say I have noticed any benefit so far Very Happy
Slacker24seve...
PostPosted: 21:43 - 25 Jul 2014    Post subject: Reply with quote
Real dyno or arse dyno?
What car?
Banger rallies are ace
PostPosted: 21:49 - 25 Jul 2014    Post subject: Reply with quote
For an experiment I tried running the MX5 on vpower / optimax / whatever it is now for a month.
Made no difference to fuel consumption. Did possibly run a bit smoother but couldn't notice any difference in performance (not that I expected any).
smithyithy
PostPosted: 21:52 - 25 Jul 2014    Post subject: Reply with quote
Very interested to know what car it is that loses 30-45bhp on lower (regular) octane fuel..
I know the top-spec Evo from a few years back was mapped to run on minimum 98 octane to make it's 400bhp, so would probably run a bit crap on 95, but I can't think of another car..?
gavbriggs
PostPosted: 21:59 - 25 Jul 2014    Post subject: Reply with quote
^^^ that might help! I'd pay a bit extra for that!
Recent bikes: Varadero 125 - Mod 2 3/2/14 - Bandit 1200 SK4
grr666
PostPosted: 22:30 - 25 Jul 2014    Post subject: Reply with quote
What car?
2009 Audi S3 but I believe there are some fast Fords and others which have the same problem
and need higher octane fuel to get the best of the mapping. You can get a
reflash with a map to suit regular unleaded and a separate map for performance fuels (APR Remap)
but I've had mapped cars before and it's usually a quick way to make
other components fail before their time in my experience.
Not dyno'd as the last car I had on a rolling road ate it's DMF a week after a full throttle
run in 5th gear. That was a diesel but the torque curve was peaky.
Found a printout from that
[img]https://i832.photobucket.com/albums/zz250/grrthefearless/Brisky%20shots/e-copy-Exchange-REGFREERRChart.jpg[/img]
In the Audi it's more or less a straight line curve but don't want to pay for a clutch/dmf
again to find out exact figures again, it cost me nearly 700 quid last time.
It's a surprisingly fast car for nearly a 1500kg motor though. It really pulls
like a train and even when it's down on power will still be putting out about 220bhp which isn't bad
for a 3 door hatch, it likes Shell or BP ultimate the best.
I have to say though it's a sterile drive and as a car it's too capable.
Too easy to drive it fast and doesn't feel challenging until you are in
3 figures territory. I have spent a BOMB maintaining it over the time I've
had it but I do hope to sell it on soon. There's no finance on it I
bought it for cash so I'm expecting around 15k when it goes.
It's in terrific condition, long list of options etc etc and low miles,
I'm looking at Volvo C30 T5 next and maybe a newer van with the change
as my old Kangoo has seen better days and I need that for work.
smithyithy
PostPosted: 22:43 - 25 Jul 2014    Post subject: Reply with quote
2.0 TFSI.. I'm quite active on the VAG forums and I've never heard of that before, unless it was remapped specifically to run on high-octane, which would be very odd as all Revo and Custom Code maps are done for regular petrol. Strange..
If it's true I'd probably put it down more to the actual fuel than the octane rating.. I've had crap tanks in the past that made the car run a bit sluggish, albeit that was an older, smaller engine..
grr666
PostPosted: 23:06 - 25 Jul 2014    Post subject: Reply with quote
smithyithy wrote:
2.0 TFSI..
Yes, kind of but an uprated version using a different turbo and intercooler setup. Kind of a factory modded variant of that engine.
They use a similar type in the Cupra R Leons as well but they aren't
as nice inside and I like my creature comforts.
Stage 1 should see over 300bhp but once you add in an uprated clutch
and all the other expense it's just not worth it.
I don't get half the thrills in the car as I do on the bike so I'm done with
blowing stacks of dosh on modding and upgrades to squeeze extra few
ponies out of cars. I could have bought a fireblade with what I spent
on my last car modding it.
Furrybiker
PostPosted: 23:14 - 25 Jul 2014    Post subject: Reply with quote
I have a SEAT Toledo V5, the handbook says 170bhp on super unleaded and "reduced power" on ordinary. Well it does get more miles to a tank and seems to run smoother.
Not sure if it really produces more power.
grr666
PostPosted: 00:13 - 26 Jul 2014    Post subject: Reply with quote
(Last post on this as it's not really bike chat so off topic. )
I have a friend that owns a large performance car workshop who is also a revo agent,
he does data logging as part of his remap service. He is also my general mechanic.
I don't work on my own vehicles as much as I used to, I have a business to run
myself and and it does okay so I pay someone else to keep my little fleet tip top
He has told me he's seen as much as 60bhp difference on some cars he works on and 30-45bhp
is the approx figure he came up with about my car, this also is variable depending on season
as in winter tuned turbo cars make more power because the air is denser so no figure can be 100% accurate.
So, in all honesty my evidence is anecdotal at best, but from someone I consider an expert.
This guy really knows his onions and is a very, very clever guy a VAG Master Tech
who started out on his own and is doing very well now with a large successful workshop of
his own and a further 8 or so techs he employs inc 3 MOT testers.
I've put a LOT of money in his till over the years, I always have about 4 vehicles on
the go and he works on all of them regardless of marque, but is a VAG specialist really.
He has a mental fast Stage 2+ Mark 5 Edition 30 GTi it's bonkers!!Shocked
I have run VAG cars for years but I'm a builder by trade so there comes a point where
my knowledge gets flaky on the whole car thing, it's all moved on quicker than I have.
But I was often found under a car in my younger days but now they are too complicated.
It seems so wrong that you can fix them with a laptop now rather than a spanner Laughing
Back to unleaded fuel, In my S3 I got caught out once and had to refuel at a rural station
that didn't sell anything but regular, just before I had to use a motorway for 70 or so miles.
Bear in mind I can get this car down to 5mpg if thrashing it according to the dash so when
it needs petrol it really needs it. After £30 of unleaded on the motorway I could certainly
feel a noticeable hesitancy up in the 120+ zone that just isn't there normally on super,
it usually pulls hard all the way up to the limiter(On track of course).
I concede these cars have an adaptive ECU which can iron out some flatspots over time
and it may well have improved over 100 miles or so, or after a battery disconnect, but
I suppose that's where the extra ponies do their thing, up in the higher speeds.
In normal everyday driving you'd be hard pressed to notice, I just wanted to see
if there was a difference when flogging it after using regular fuel and there definitely was
but I never had a laptop plugged into vagcom to get figures etc.
I later mentioned the occurrence to my mechanic and he told me the ballpark figure he
reckoned I was losing by not using super. If I had no confidence in him I'd employ another
mechanic, so I take that as gospel.
At the end of the day a car with 100bhp can do 120 on a long enough straight,
getting there quickly is what the BHP is for.
But bikes are where it's at for me now, looking to do some track days on 2 wheels next year
at Castle Combe which is my local circuit and one I'm familiar with from doing track days
through a couple of other car forums I use. But I haven't had this much fun with my clothes
on for years. Turning 40 just over a year ago hasn't slowed me down one bit.
Am loving being back on a bike and am keen to do more of it and maybe buy a couple
of old school bikes from back in my day (1988 ish) as hobby/projects.
I'm done with cars, I spent a lot on that Audi and only a quarter of that sum on my bike
yet smiles per mile the bike wins every time.
Bunny Lingus
PostPosted: 00:54 - 26 Jul 2014    Post subject: Reply with quote
I only really notice the difference in little bikes. The free public dyno at Muswell Hill is the best test track in north London. I can nearly get to the top on me Cub... The defence rests y'honour!
Bunny Lingus & The Flipside Faggots
Llama-Farmer
PostPosted: 00:56 - 26 Jul 2014    Post subject: Reply with quote
Both the bike and the cars run smoother on super unleaded. There seems to be a slight power and mpg increase, I think this is due to the detergents in the fuel, cleaning all the internals over time and therefore more efficient combustion than previously.
A secondary effect of the fuel rather than primary effect.
The difference is MASSIVE in the Subaru Legacy though, which is a twin turbo.
Regular unleaded in NZ is 91 RON, "super" is 95 RON, but BP Ultimate is 98 and it runs on that all the time.
It was a JDM Japanese import which was mapped to run on 100 in Japan, then remapped to run 95 in NZ but it much prefers 98. It'll run on 91 but it runs in almost a limp mode... ignition timing is massively advanced and boost is restricted, instead of 270ish bhp it's more like 190bhp
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
The last post was made 11 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 135.26 Kb
