Indicator Problem
scorpio1006
PostPosted: 17:00 - 03 Apr 2002    Post subject: Indicator Problem Reply with quote
Crying or Very sad
Hi all iv just got some mini indicators for the Front and Reer the problem is that i have fitted the two front ones and they work fine fats but they work when i tried to conect the reer ones they would not flash i just got this strange sound so i put the original ones back on the reer with the new ones and they work fine both the front and back ones are the same watage what could be the problem
my bike is not an import by the way
thanx
Dan
PostPosted: 23:27 - 03 Apr 2002    Post subject: indys Reply with quote
i had the same problem when i replaced my indicators, you need to change your realay to a 23w just get it from the bike shope easy enough to do. If you take your seat of and its at the back on the bike behind the tray thing and infront of the lights
cheers
dan
tanner
Guest
PostPosted: 09:30 - 05 Apr 2002    Post subject: Reply with quote
i had the same problem the wattage on the bulbs is wrong take the bulbs out of the original indicators and put them in your mini indicators the bulbs will fit hope that helps
Scooby
Scrappy Doo
PostPosted: 10:59 - 05 Apr 2002    Post subject: problem solved Reply with quote
What my mate did on his Aprilia was on his mini indicators, stripped all the insides out (wires, connections, etc) and the standard Aprilia indicators have similar insides and with a bit of time (an hour or so) and a bit of superglue, managed to fit the standard Aprilia connections, bulbs, etc into his mini indicators, without using a 23W relay.
This only works if you just want mini indicators and not brighter bulbs tho remember. Also, be confident in what you're doing otherwise you'll f*ck up the mini indicators and your standard ones in the 'conversion' process. Laughing
Dan
PostPosted: 23:48 - 06 Apr 2002    Post subject: 1 Reply with quote
so much easyer and much less hasslel jst to get relay
Viper
Get off my bloody bike!
PostPosted: 00:47 - 07 Apr 2002    Post subject: Reply with quote
Scorpio...
I have just had the same problem.
It can be easily solved by simply finding a lower wattage bulb for the unit.
I have got 4 replacement indicators, the front are the original 23w bulbs, and the rears i swapped for 5w bulbs. (£1.49 from halfords!)
Cheap solution and works fine! Laughing
TJ NSR
PostPosted: 17:56 - 07 Apr 2002    Post subject: VIper Reply with quote
Viper im glad to see that my information helped u, it also works fine for me!!!
TiN
Pocket Tin
PostPosted: 18:17 - 07 Apr 2002    Post subject: Reply with quote
Hey Viper, what indicators have you installed?...the mini Motrax ones?...I'm kinda torn between replacing all 4 with mini ones, or buying another pair of the front (honda) ones and putting them on the back...
Tin
Viper
PostPosted: 12:54 - 08 Apr 2002    Post subject: Reply with quote
I bought the VERY cheap £10 replacement pack, with the three different choices of lense cover in. (M&P)
They work great. Havent broken yet!!!
Cheers TJ ! Wink
The last post was made 24 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 58.06 Kb
