Name that fitting type
nowhere.elysium
The Pork Lord
PostPosted: 17:46 - 25 Jul 2014    Post subject: Name that fitting type Reply with quote
Anyone know the name of this hose fitting type?
https://tws.dk-server.co.uk/item139785-8.jpg
PostPosted: 08:16 - 26 Jul 2014    Post subject: Reply with quote
Vincent wrote:
If I had to try and describe it to someone, I'd call it an "oil hose flange"....but they may then look at me as if I'm an alien Whistle
A hate the word "flange" Puke
The Artist
PostPosted: 08:38 - 26 Jul 2014    Post subject: Reply with quote
Image doesn't work for me.
PostPosted: 09:22 - 26 Jul 2014    Post subject: Reply with quote
Vincent wrote:
Right click and "view image" works.
Not for me.
Even tried sticking it in tor encase it was a routing issue. Also tried to see if google could do anything with it - nowt from either.
Aff
PostPosted: 09:25 - 26 Jul 2014    Post subject: Reply with quote
https://i.imgur.com/3dAn8mY.jpg
Electric Bike Project
PostPosted: 09:42 - 26 Jul 2014    Post subject: Reply with quote
I'd concur with the 'flange' then - and a quick google shows similar items coming up with that. Unfortunately not with other useful words that could be tried.
The Artist
PostPosted: 09:51 - 26 Jul 2014    Post subject: Reply with quote
It is definitely a flange but a specific name would be hard.
Oil cooler hose flange? Basically it could be any iteration of flange/hose/oil that the manufacturer decided.
It is also swaged onto the hose itself.
Hetzer
PostPosted: 17:54 - 26 Jul 2014    Post subject: Reply with quote
It's a 'flat ovoid thingy connector'.
Suntan Sid
PostPosted: 17:55 - 26 Jul 2014    Post subject: Reply with quote
The nearest I can find, "oil fitting adapter", check out the website below!
https://www.mpsracing.com/products/MPS/OilFit.asp
https://www.mpsracing.com/images/products/MPS/BigPics_MPS/OilFittingAdpt.jpg
nowhere.elysium
The Pork Lord
PostPosted: 17:56 - 26 Jul 2014    Post subject: Reply with quote
OK. Main reason I ask is that I'm going to have to make up a set of oil cooler lines, and that's the fitting at one end of them. I guess I'll just take the original ones to Pirtek and see if they've got them.
Kinda surprised that the image didn't work for some of you: came up just fine on my PC, as well as on my phone over 3G.
:edit: Sod paying £16 per flange!
PostPosted: 18:35 - 26 Jul 2014    Post subject: Re: Name that fitting type Reply with quote
Bizzaraely, it started working fine as soon as Aff had uploaded it to imgur.
Could be DK have something anti-image-theft thing that stops you seeing the pic properly if you haven't got it from the web page it's supposed to be in, as plenty do have.
But that doesn't explain why it started working. Maybe there was just an issue with their servers for a bit.
stevo as b4
PostPosted: 22:33 - 26 Jul 2014    Post subject: Reply with quote
Whatever you'd call it, it looks like it would make a nice turbo oil drain hose into the sump! Smile
Shaft
PostPosted: 00:44 - 27 Jul 2014    Post subject: Reply with quote
Pirtek will make them, but if you thought 16 quid for an end fitting was expensive, lay something soft on the floor before you ask them what they charge, you'll probably faint!
The last time I got them to make up something for me, it was a PAS pipe for an old Isuzu Trooper, which was supposed to be available, but went indefinitely back order - list price £150 (which was farking extortionate anyway) Pirtek price £230, using the original solid parts of the line.
I did get a free pair of (very cheap) sunnies from them though Cool
PostPosted: 10:50 - 27 Jul 2014    Post subject: Re: Name that fitting type Reply with quote
Time to add a CNC milling setup to your toy-collection?
nowhere.elysium
The Pork Lord
PostPosted: 10:54 - 27 Jul 2014    Post subject: Reply with quote
I was coming to that conclusion, G Laughing
Fisty
PostPosted: 11:56 - 27 Jul 2014    Post subject: Reply with quote
It's called an an ORF (o ring faced) flange.
Fatter and faster than Fret
Robby
Dirty Old Man
PostPosted: 18:39 - 27 Jul 2014    Post subject: Reply with quote
Which bike is it for? I assume the NC24 could do away with the oil cooler entirely. No need for an oil cooler on a bike that doesn't work, and it won't help cool the bike when you chuck a match in the tank.
nowhere.elysium
The Pork Lord
PostPosted: 18:51 - 27 Jul 2014    Post subject: Reply with quote
It is for the NC24, and I'm still hopeful that it'll work.
The primary reason that I'm unsure if it can be done away with is that the oil pump is different to the other NC13 engine-based bikes - it's got a beefier pump unit than the 30 or the 21, and I don't know if the constitutes required oil routing, or if it merely happens to be included. The diagram's not the clearest in the world - when it gets to the point where it describes the oil pickup for the cooler, it's a very confused image indeed.
https://farm4.staticflickr.com/3876/14759295142_6914d0ae8c_o.jpg
I included the phonetic translations just a point of interest. They may be wrong, but I'm nowhere near fluent in Japanese. Hell, I wouldn't even class as successfully incompetent in Japanese.
PostPosted: 23:01 - 27 Jul 2014    Post subject: Reply with quote
I had a look through ebay etc before posting, always fancied one, but sadly now isn't the time.
If you do get one, I could probably do with a bracket making for the SM wheels for the 200 Wink. (Though I suspect I'll do as well functionality wise with a bit of plate steel and a welder/angle grinder!)
The last post was made 11 years, 219 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 122.37 Kb
