| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| yen_powell |
 yen_powell World Chat Champion
| wr6133 |
 wr6133 World Chat Champion
| gbrand42 |
 gbrand42 Could Be A Chat Bot
 Posted: 11:08 - 27 Jul 2014 Post subject: |
I had this on mine, clean the slider pin, lubricate with your lube of choice (something high temp & rubber-friendly) I use silicon grease personally. And the usual check that the piston is clean & free to move. Make sure the rubber boot on the slider is not damaged in any way. New pads and jobs a good un. Oh and back wheel has to come off to remove caliper. ____________________ Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European |
| Llama-Farmer |
 Llama-Farmer World Chat Champion
| Beehive Bedlam |
 Posted: 15:05 - 27 Jul 2014 Post subject: |
Changed them this morning a ride to Grassington see my lonely lover has worn them in nicely.
I couldn't separate the bracket from the calliper to lubricated the sliding pin though it is seized solid after an hour I gave up and put the wheel back on which is always a cow.
I believe something else is also missing from the calliper but can not identify it ignore the bent retainer clip it does the job.
https://oi58.tinypic.com/xys6h.jpg |
| TUG |
 TUG World Chat Champion
| gbrand42 |
| Kickstart |
 Kickstart The Oracle
| gbrand42 |
 Posted: 19:11 - 27 Jul 2014 Post subject: |
I think you might be missing the rubber boot on the slider pin, which would explain the sticking caliper. New boot and a damn good clean up of the pin with some lubrication required I think. Thats if it hasn't already corroded up tight to the point of no return.
And a valve cap for that tyre too. And as you have already spotted, the pad spring is fubar.
On a positive note, the pads look good and the piston is not bad. ____________________ Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European |
| Beehive Bedlam |
 Posted: 19:51 - 27 Jul 2014 Post subject: |
Correct Keith well done that is why it munched through the last set so fast yet the front are less than half way to the wear markers I replaced them at the same time front and rear a couple of months ago.
The boot seal does indeed appear to be missing gband42 part number; thirteen is this tiny expensive bit of rubber really going to get the slider pin to move? Because brute force certainly didn't.
I'd be so lucky to find the boot seal and retaining pin on ebay If I went down that road I bet a gold pig I will have to pay Honda's premium price tag that comes to a total of £8.89 for both parts plus £5.50 shipping.
I will leave it for now and keep an eye out for a replacement calliper as the piston has seen better days anyway it isn't blinding to the point of being an annoyance every MPH matters and I'd tell straight away. I think it is just half a brake which doesn't bother me either because it is a slow 125 engine braking is massive and finally it's the rear brake. |
| TUG |
 Posted: 19:59 - 27 Jul 2014 Post subject: |
You don't get it do you, you really fucking don't understand the basics of maintenance! If you leave that caliper like it is then it will warp your disc, then you will need to spend money on getting a new one of those too and if the heat generated is strong enough to get to the bearings, it will slowly fuck those up too.
Stop being a stupid cunt, book it into a workshop because we all fucking know it's beyond you to do the simple job of lubing up that slide and replace the boot which prevents it from seizing in the first place.  ____________________ Haz ER-5, innit! |
| Beehive Bedlam |
| gbrand42 |
 Posted: 20:35 - 27 Jul 2014 Post subject: |
Is it worth having a look at that CBR caliper you have got to see if the slider and rubber seal is the same? You never know your luck, and if they are in good condition might save you a bob or 2.
If the caliper is seized on the slider, try a shit load of plus-gas over night to see if it can penetrate. Don't take a lump hammer to it. ____________________ Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European |
| Beehive Bedlam |
| _Iain_ |
 _Iain_ Banned
| Beehive Bedlam |
| _Iain_ |
 _Iain_ Banned
| Beehive Bedlam |
| TUG |
| mattsmith95 |
 mattsmith95 Traffic Copper
| Ballpien |
 Ballpien Trackday Trickster
| bikertomm |
 bikertomm World Chat Champion
| gbrand42 |
| gbrand42 |
The last post was made 11 years, 264 days ago. Instead of replying here, would creating a new thread be more useful? |
