| Gazz |
 Gazz World Chat Champion
| TUG |
 TUG World Chat Champion
| stinkwheel |
 Posted: 22:10 - 23 Jul 2014 Post subject: |
Cuts out with a flat battery?
Five miles is a very short distance to go from fully charged to too flat to run the bike. IS the battery flat after the 5 miles? Or has the bike simply cut out for another reason?
If the battery is flat. I reckon you must be looking for nearly a full short. Something must be hoovering amps (or the battery is duff) to flatten it that quick. Is anything connected direct the battery without a fuse?
I suppose two ways I'd fault find this.
1) Get a wiring diagram and go over the various circuits with an ammeter until you find the one that's red hot (a clamp meter would speed this process up massively).
2) Unplug everything but the main and ignition fuses and see if the problem goes away. Plug the remainder back in one at a time until the problem comes back then work out what that fuse supplies.. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Gazz |
| Gazz |
| pdg |
 pdg World Chat Champion
| Kickstart |
 Kickstart The Oracle
 Posted: 23:40 - 23 Jul 2014 Post subject: |
5 miles is probably at most 20 minutes running. Say a 10ah battery so to kill it would need in the region of a 30amp drain it. That would melt most wires on the bike. Starter motor drawing power due to a dodgy starter relay would be my guess.
But get the bike running and stick a volt meter over the battery. Check the voltage goes up with revs.
| Nexus Icon |
 Nexus Icon World Chat Champion
| pdg |
| Gazz |
 Posted: 07:01 - 24 Jul 2014 Post subject: |
| Nexus Icon wrote: | Does it cut out instantly or are there spluttering and misfiring type issues before it finally dies?
I only ask as it sounds more like the classic blocked tank breather problem than something electric, i.e. Runs for five miles, vacuum forms in tank as breather blocked, fuel stops flowing, bike stops, pressure slowly equalises over a few minutes, bike starts again and the circle repeats.
Unless you're confident it's electrical try opening the fuel cap the next time it cuts out and see if there's a rush of air noise. It would them start immediately. |
The rev counter stops working, then you can feel it slowly dying. If you keep the throttle in the same position, it can be nursed for half a mile or so, but if you increase or decrease the throttle at all, it just dies on the spot. |
| Gazz |
| Pete. |
 Pete. Super Spammer
| doggone |
 doggone World Chat Champion
| iooi |
 iooi Super Spammer
 Posted: 13:07 - 24 Jul 2014 Post subject: |
Start bike. Disconnect starter cable and ride.
If its still running after 5 miles, then solenoid could be sticking so still cranking starter. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| P.addy |
 P.addy Red Rocket
| Nexus Icon |
| P.addy |
 P.addy Red Rocket
 Posted: 14:32 - 24 Jul 2014 Post subject: |
| Gazz wrote: | The rev counter stops working, then you can feel it slowly dying. If you keep the throttle in the same position, it can be nursed for half a mile or so, but if you increase or decrease the throttle at all, it just dies on the spot. |
Check regulator by checking voltage across battery. If its 12v or thereabouts, check your regulator connector. If it looks toasty, replace it, while its off, check the stator. Should have 3 wires coming to the reg/rec. Multimeter on AC, check all 3, they should be within a few volts of eachother. Then check for continuity between 1+3, 2+3 and 1+2, should be infinity or nothing.
If it reads anything other than that, you may want a stator. Likely the reg/rec though. |
| Gazz |
| Pete. |
 Pete. Super Spammer
 Posted: 21:17 - 24 Jul 2014 Post subject: |
It's not charging, but that doesn't mean that the alternator is dead. The charging system has two main components, the alternator and the regulator/rectifier.
The alternator produces AC power and the reg/rec changes it to a regulated DC for charging the battery. You can check the alternator output by un-plugging it and running the engine. First inspect the terminals for signs of over-heating. At around 5k you should be getting about 60V AC between any two of the three wires. Check all three combination of pairs.
If the alternator is producing voltage in that region then your fault probably lies with the reg/rec or with the wiring. Locate the rectifier and un-plug it from the loom. Inspect the terminals. If they show signs of being over-heated it might just be a case of poor connection. If they look ok then it's likely the reg/rec is dead, but run the engine and put your meter across the red and black output in the multi-plug just to check. At 5k you should be getting more than 14V. ____________________ a.k.a 'Geri'
| Gazz |
| Kickstart |
| Gazz |
| Kickstart |
The last post was made 11 years, 247 days ago. Instead of replying here, would creating a new thread be more useful? |
