Anti-Theft: Locks/ Chains / Explosives
Snop Doog
PostPosted: 22:45 - 29 Jul 2014    Post subject: Anti-Theft: Locks/ Chains / Explosives Reply with quote
Hi all,
I don't have a bike yet, but my first one will likely be an old CG125. I have my gear, now I'm thinking about security. I would like to keep this simple: What locks/chains/proximity mines would guys recommend that insurance companies like and will deter thieves?
Thanks in advance! Very Happy
PostPosted: 00:02 - 30 Jul 2014    Post subject: Reply with quote
Almax/pragmasis are still the best I believe, throw on a Cyclone V2 alarm off of ebay and something you can chain the bike to and I think you'll be alright.
ws4936
PostPosted: 00:15 - 30 Jul 2014    Post subject: Reply with quote
Chain, anchor, noisy dog, all good.
Don't declare them to the insurance tho - it's a con.
You get a discount if it qualifies, but then if you pop in quickly for a pack of fags, and your bike is nicked, likelihood is it would have been nicked without the chain and lock that you declared would be on, so they won't pay out, they'll make it a provisor. Also - insurance may go up as you've fallen for the trap of notifying them that you live in a scummy area and your bike needs extra security.
In short, buy them - but don't declare them. Try 2 quotes online, you'll probably find no security is cheaper. But secure them obviously.
If everything seems under control, you're just not going fast enough.
Northern Monkey
PostPosted: 09:52 - 30 Jul 2014    Post subject: Reply with quote
Cost's me £5 more because I don't declare any of the security on my bike. Well worth the fiver incase my bike gets nicked on the day I forgot to put the almax on
DrSnoosnoo
PostPosted: 09:59 - 30 Jul 2014    Post subject: Reply with quote
My CG quote tripled if an almax was declared
Wonko The Sane
PostPosted: 10:05 - 30 Jul 2014    Post subject: Reply with quote
On my varadero a datatag was a requirement, did declare it on the ZZR but don't think I declared it this year.
Amber Phoenix
PostPosted: 10:19 - 30 Jul 2014    Post subject: Reply with quote
I wrote a pretty lengthy article on my blog about this. Have a gander at these bike security tips. You might think some of it is a bit over kill for a 125, but statistically they're pretty high up on the list of stolen bikes - usually kids wanting to have a muck about, use them for a smash and grab or aid stealing a bigger more expensive bike.
Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007
Andy_Pagin
PostPosted: 17:32 - 30 Jul 2014    Post subject: Reply with quote
I use an Almax Series III 1.5 metre with a Squire SS65C padlock, which is about the heaviest duty gear you can actually carry around. But it is seriously heavy and bulky. Definitely worth having for overnight at home, providing you've got a hefty ground anchor, and it's worth the expense since it'll probably last a lifetime.
Snop Doog
PostPosted: 17:34 - 30 Jul 2014    Post subject: Reply with quote
@Manatee: Would a Pragmasis 11mm chain do the trick? I'm not experienced with chains as I use an Abus D lock (which I'll also use on my future motorcycle because why not) and a kryptonits flexible cable thing for my mountain bike. As for that alarm system, I can't find it on eBay...
@ws4936: Understood! Security will be kept secret from my future insurer.
@Northern Monkey & snoosnoo: So not declaring anything added £5 but then declaring it tripled the quote... That's very strange, more of a reason for me to compare 2 quotes.
@Arfa: Thanks for that, I'll read over it now.
Northern Monkey
PostPosted: 18:38 - 30 Jul 2014    Post subject: Reply with quote
Depends where you are leaving it, but 11mm isn't really up to the job.
Snop Doog
PostPosted: 20:25 - 30 Jul 2014    Post subject: Reply with quote
Hmm, ok. I don't know where to look Sad
-Matt-
PostPosted: 02:05 - 31 Jul 2014    Post subject: Reply with quote
Good chains - Almax/Pragmasis.
They're expensive, but assuming you continue biking, get bigger/more expensive bikes look at it as a long term investment as a good chain and lock should 'last a life time' essentially if you look after it and don't leave the bike in ridiculously dodgy areas.
Regardless of what chain you buy - its as strong as what its attached to - leaving it loose around the wheel will result in it and the expensive chain being dragged into a van.
If you have sturdy street fixings like lamposts etc to attach to you're okay with a good chain generally. If you have nothing to attach to - i'd look at a good ground anchor. Ideally something you can cement in, but thats not always an option so get something with raul bolts you can securely fix to the ground, and ideally resin over the top to reduce it being tampered with. Mammoth do some relatively cheap but quite decent quality anchors.
If you have a garage, i'd focus more on the garage security than chains/anchors. I've used decent garage-defenders and never had the garage broken into even in very dodgy areas where i'm sure it was known there was a bike inside. I did have the chain/anchors inside too, but they never were needed and were essentially a waste of money at the time. Plus bare in mind if someone gets into a garage, shuts the door down behind them - even a good chain an anchor won't take all that long to get through in a closed garage with some powertools.
https://www.ebay.co.uk/itm/BLACK-garage-door-defender-lock-HEAVY-DUTY-SECURITY-SYSTEM-other-colours-/250929287122?pt=UK_HaG_Lock_Safes_GL&hash=item3a6c8d0fd2
Good garage defender - top bridge stops lock tampering unless they're picking pro's.
https://www.almax-security-chains.co.uk/All-Products/c-1-73/
Good chains - the difference between 3 and 4 series is about a minute or so extra time if attacked with powertools I believe - realistically if they have the time and effort to go at it with powertools in the first place you're probably going to lose the bike so you might as well get a 3 and save some money.
https://www.ebay.co.uk/itm/Mammoth-Security-Bolt-In-Motorcycle-Ground-Anchor-Sold-Secure-Approved-/131224449502?pt=UK_Motorcycle_Parts&hash=item1e8d9631de
Good ground anchor - double bridge and anti tamper bolts - again resin is worth using over the bolts in regardless.
Bare in mind for the ground anchor and garage defender you need a decent drill and a good day to fit them properly, so factor that into costs, even if it is renting a drill/drill bits if you can't borrow one.
Realistically - an old CG125 isn't going to be prime pickings for a lot of bike thieves - if its all you're going to get/keep for a long time I wouldnt probably spend all of the above money to secure it, as it could easily end up costing half the bikes value. Keep it parked in as secure an area as you can, chain it with something that isn't some abysmal bicycle lock and you will probably be okay. But its always going to be a gamble ultimately. Also as WS mentioned - forget insurance savings, they rarely happen, and it can often even have the opposite effect declaring 'security'.
covent.gardens
World Clap Champion
PostPosted: 06:40 - 31 Jul 2014    Post subject: Reply with quote
Good security = increasing the time it takes them to steal (make it hard for them) whilst at the same time reducing the time they have to steal (e.g. alarm blaring/detection). As a rule I never rely on the chain alone, eg I will chain it up near to a CCTV camera or window where I can see it. Good chain is good, but don't rely on that alone.
devojunior
PostPosted: 12:22 - 31 Jul 2014    Post subject: Reply with quote
https://www.henrykrank.com/index.php?main_page=product_info&cPath=1_44_47&products_id=2964
PostPosted: 12:31 - 31 Jul 2014    Post subject: Reply with quote
11mm? Nah, go for 16mm or 19mm.
You're never going to make it unstealable, if someone wants it enough then it'll be gone.
gorillaonabik...
PostPosted: 14:41 - 31 Jul 2014    Post subject: Reply with quote
I go with a gorillalock at home and must get an Almax for 'general' stuff (e.g. girlfriend's place).
https://www.thesundaytimes.co.uk/sto/ingear/2_Wheels/Motorbikes/article561066.ece
If a determined thief wants it, then they will get it but it has a foot-long metal post thingy underneath which is cemented into the drive. It has already stopped a 'casual' thief so seems to be good enough.
If a pro wants your bike, they will have it but it's good enough for me and what I really like is that it is as easy to park in my driveway as a car. Specifically, I ride in and the bike is automatically locked.
FZR400 (blown engine), ZXR750 (blown engine), ZX6R (accident), CBR600 which had engine issues after which I learned to change gear..., CBR900, CBR924 (stolen), CB600, CB1300 (everything blew up), BMW K1300GT (written off, hit from rear while stationary), Bandit 1250 for a couple of months, Triumph Sprint ST 1050 (nicked) and somewhere in there, I wrote off a Ducati 748 at Cadwell.
Northern Monkey
PostPosted: 14:45 - 31 Jul 2014    Post subject: Reply with quote
Here - https://www.almax-security-chains.co.uk/product.asp?strPageHistory=category&numSearchStartRecord=0&strParents=73&CAT_ID=73&P_ID=123&btnProduct=More+Details
Snop Doog
PostPosted: 23:01 - 01 Aug 2014    Post subject: Reply with quote
Thanks so much for the information guys! I'll save up for an Almax III. I hope the 0.7M one is enough. I don't think I'll be able to get a ground anchor because of the size of my front garden. I may be able to use a neighbours garage as it isn't in use, I don't know if I'll be able to put a ground anchor, or any other device like it in there though. Seeing as it's a CG that I'll be buying I may be able to wheel it through my house into my garden. If that's not an option then there's a tree with a decent width across the road from my house that I guess I could chain the bike to. I have an Abus Granit X-Plus 54 D-Lock that I'd use to put in between the wheel and the rear should. I doubt it would make a difference but as long as it's more security I'm happy. I'm also going to buy the Cyclone V2 alarm.
-Matt-
PostPosted: 23:13 - 01 Aug 2014    Post subject: Reply with quote
You might get away with an 0.7M using a CG. On something like a sportsbike, or even mid-sized bike with a larger rear wheel you would have to park it almost on top of a ground anchor to get it comfortably around the wheel and anchor - so may be worth spending a little more for the 1.5m if you're planning to upgrade to anything bigger in the future, or the chain may end up being useless at that point. Gives you more flexibility if you do ever take it anywhere too that needs a little extra-stretch to get it around street-fixings etc.
As an extra/alternative to a Cyclone you can get a fair few cheap alarmed disclocks to, but they can be a bit over/under sensitive sometimes and usually don't have customisable sensitivity like the Cyclones. Benefit is it won't drain the bikes battery if you're leaving it sat for a long period in winter potentially like the Cyclone can.
Snop Doog
PostPosted: 00:05 - 02 Aug 2014    Post subject: Reply with quote
Hmm, going for the 1.5M would definitely be sensible. One reason why I haven't mentioned disc locks is because I'll most likely be buying a CG that's pre 2004, so it'll have drum brakes... Hmm, but I do think an alarmed disc lock would be a better option for me as I wouldn't like to experience those battery problems.
Oh, and where do you recommend buying alarmed disc locks from?
Thanks for the advice Very Happy
-Matt-
PostPosted: 00:30 - 02 Aug 2014    Post subject: Reply with quote
Alarmed disc locks wise I can't advise much - the couple i've had have been cheapies off ebay - didn't have much issues with the those ones thankfully, although I know a few people who have found the cheaper options to be utterly useless due to either going off all the time with the slightest bit of wind, or just requiring a sledgehammer to set them off Laughing its hit n' miss really.
A good option would be these from what i've seen
https://www.ebay.co.uk/itm/OXFORD-BOSS-ALARM-MOTORCYCLE-MOTORBIKE-DISC-LOCK-/300408660765?pt=UK_Motorcycle_Parts&hash=item45f1c0631d
Not at all cheap though - personally i'd much rather put [worst case I expect] half of the cost of that into finding a cheap one that works even if it does mean buying a few different ones.
Fair point about the lack of discs, my CG knowledge is some what lacking it seems Razz I would say though I never intended mine to lock the discs up, as most bikes can be dragged very easily if not chained to something regardless of disc locks. I used mine as a cheap alternative to an alarm - for movement sensing and hopefully detering anyone who starts fiddling with the bike. In which case you could fit the lock to a lot of locations on the bike as long as the motion sensor actually activates as its intended to Thumbs Up
As a general thing too, a vented cover isn't a bad idea - protects the bike from the elements a bit, keeps it slightly out of view, and can give you some idea if its being snooped out as if someone is going around looking for potential targets in the area, they'll often pick the cover off and be on their way to return at a later date - which at least gives you some warning its perhaps being eyed up.
As I said beore though though - its a CG at the end of the day - Don't overspend on security, unless its stuff you're sure you'll get use out of long term like a good Almax chain which can be considered an investment. The serious bike thieves won't bother cracking through tons of security to get a fairly budget CG when they can put that time into trying to nick a high value bike nearby.
Snop Doog
PostPosted: 02:50 - 03 Aug 2014    Post subject: Reply with quote
Thanks for the info Thumbs Up Ah man, that price... Maybe for my A2 bike... But yeah, I have an eye on the Almax, a bike cover wouldn't hurt as an early warning system as well as its purpose, and I'll put that D-Lock in between the rear shock and the rear wheel because I have it now so why not.
Pie-Roe
PostPosted: 12:13 - 03 Aug 2014    Post subject: Reply with quote
There's been 125s and 400s nicked from places where I've parked my blackbird, rf9s and x11s. Little bikes are what opportunist thieves go for.
Dave70
PostPosted: 12:36 - 03 Aug 2014    Post subject: Reply with quote
I have a cheapish disc alarm (Can't remember the make off hand) and it did the job when someone broke my steering lock in an attempt to thieve it. Although, they obviously weren't too bright seeing as they didn't notice it beforehand.
After that I went out and bought an Oxford Boss disc alarm, which is pretty decent but, the alarm could be louder (the cheap one I mentioned is actually louder by a fair bit) and it does sometimes go off for no reason. I also have an Oxford chain and although they're not the best, it is pretty chunky and is an added visual deterrent. If I was buying a chain now though, I'd go for an Almax.
So basically my bike is now stored in the back alley (we have locked alley gates here) with two disc alarms on (front and rear), a chain through the back wheel and a Stormex cover on.
It's a bit of a pain putting it all on and taking it all off again every ride (not like the IOM where you could leave it parked in the street with the keys in the ignition and it'd still be there the next day) but, it's what you have to do.
They first tried nicking my bike about 3 months ago and hopefully all that security appears to have paid off as they haven't tried again, so far. **touch wood**
I have also considered installing a ground anchor and Almax chain but, money's a bit tight at the mo. If you can afford it though, I'd recommend doing so.
kramdra
PostPosted: 13:33 - 03 Aug 2014    Post subject: Reply with quote
My advice, avoid the CG, especially if its a front drum brake model. Designed for india, they are shite and in my opinion dangerous (drum brakes, swimarm mounted passenger pegs Shocked).
I dont think they exist, but what you *want* is a 125 with factory fitted immobiliser, like Honda's HISS. When I asked at honda, nope, they are not fitting that technology on 2013, £5000 125cc machines Laughing That may have changed, tho I believe yam make better 125's?
Security.. pikeys has little interest in bikes with a factory fitted immobiliser. A pro has no interest in a tatty older bike that has little resale value. My bike, a tatty CBR6 with immob is perfectly safe from thievery. Ive left it on the road in some shitty areas for 4 years and never used a lock Laughing
The last post was made 12 years, 51 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 144.88 Kb
