Respraying my bike with Rattle Cans
Phil D
PostPosted: 15:15 - 30 Jul 2014    Post subject: Respraying my bike with Rattle Cans Reply with quote
After I've sorted out a few more issues with my newest steed I'm probably going to respray the tank, front mudguard and rear cowl in black. The tank is a bit beat up from various drops from the previous owner (cheers mate!) the worst of which is below:
https://s9.postimg.org/sgmkmg9wf/image.jpg
Although there are a few others and a small bit of surface rust.
As there are small bits of surface rust do I need to strip it back to bare metal or can I just sand back the affected areas and do some spot rustproofing/etch priming/filling?
Im looking at either a matte or satin black paint job with a matte clear coat. Im sure the standard acrylic based halford rattle cans will do for the plastics but for the tank is there any sort of rattle can paint that will give some resistance to petrol?
Any recommendations for brands of stuff to use?
Efes123
PostPosted: 15:19 - 30 Jul 2014    Post subject: Reply with quote
Depends on how good you want it to look. For the best result, sand it right back. But if you spend time on a few coats you might get a way with just sanding the affected area. I've used both of these:
https://www.ebay.co.uk/itm/2-X-PETROL-RESISTANT-LACQUER-PAINT-SPRAY-500ML-HIGH-GLOSS-laquer-aerosol-/360740458378?pt=UK_DIY_Material_Paint_Varnish_MJ&hash=item53fdce8f8a
and
https://www.ebay.co.uk/itm/HYCOTE-PETROL-RESISTANT-CLEAR-LACQUER-SPRAY-PAINT-/140890011886?pt=UK_Body_Shop_Supplies_Paint&hash=item20cdb2f8ee
And they are both pretty good
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
Phil D
PostPosted: 20:30 - 30 Jul 2014    Post subject: Reply with quote
and
From what i've read matt black is the easiest paint to get a decent looking finish with as its very forgiving. Doesn't seem anything that comes out of a rattle can is going to be resistant to any sort of petrol splashes so i may just do away with the lacquer all together so i can touch up when necessary!
TUG
PostPosted: 21:11 - 30 Jul 2014    Post subject: Reply with quote
Nothing says I've crashed it and I'm cheap more than matt black! Also you can't clean it properly petrol will eat through it like a fat kid and a chocolate cake. I was going to rattle can my ER-5 but because of reasons, I'm just going to send the panels off to be sprayed in Yam pearl white and save myself the hassle, there is a place by me that is relatively cheap so why the fuck not. Laughing
Jokes aside, whats wrong with having the ding filled in, then etching primer 2 coats, then spray away, smooth off with wet and dry then lacquer, smooth that off for a nice shine, I'm led to believe this is the correct way, however I may (and probably) be incorrect.
Haz ER-5, innit!
matto
PostPosted: 21:28 - 30 Jul 2014    Post subject: Reply with quote
I used satin black Plasti-kote paint for my Pegaso. Haven't had any problem with the odd drip of fuel and the paint went on lovely and smooth.
MartZ0r
PostPosted: 21:36 - 30 Jul 2014    Post subject: Reply with quote
if your worried about petrol etc you ideally want some 2k clear coat you can get these in cans too, look up Spraymax. has an activator in the bottom of the can for the hardener. Good stuff i used it on my last two bikes.
Phil D
PostPosted: 21:37 - 30 Jul 2014    Post subject: Reply with quote
Yeah its cheap and cheerful but i've seen this bike on another forum and want to do something similar Very Happy
https://s16.postimg.org/f5ji8i4ad/IMAGE_108.jpg
Interesting.. you got any pics?[/img]
0l0dom0l0
PostPosted: 22:11 - 30 Jul 2014    Post subject: Reply with quote
I'd sand back the rust to bare metal and the rest of the paint back so all the dents and scrapes are out. Then fill all the bumps and scratches and re sand. Then prime and you'll probably find some more pin holes so do the same again.
You might as well go for something that will look half decent when done. Even a gloss black would be good, although gloss paint is a bit of a nightmare. Really you want to spray the paint then sand it back to get a key and lacquer with a petrol proof lacquer. Once lacquered to get a good finish you need to cut back and polish.
Not using a lacquer is just a waste of time. If you've done all the prep the hassle of painting, the lacquer is the easy bit in terms of the time it takes. If you do it properly you shouldn't need to touch it up.
Otherwise if you don't, you'll forever be 'touching it up'.
Painting is one of those things you do once and do properly. After you've sanded, prepped and attempted to paint something once you'll understand why. It takes forever and is just easier to do properly once.
Shaft
PostPosted: 22:13 - 30 Jul 2014    Post subject: Reply with quote
I don't know what you've been reading, but the only good thing about black is it's coverage (you can pretty easily bury any colour under it) but I guarantee any proper painter wouldn't describe it as unforgiving.
It shows imperfections more readily than any other colour, so you had better be sure your preparation is perfect, because anything that isn't will stick out like a sore thumb.
Similarly, any bits of dust or crap that settle after painting will look like boulders and if your painting technique isn't the best, you will know all about it.
Some of that isn't a problem with a gloss finish, because you can dump it on and take care of it afterwards with flatting and polishing, but of course you can't polish matte paint, so if you bugger it up, you're starting again.
So actually, matte black is probably the worst colour you could choose, if you want it to look really good (incidentally, my painter who has been doing it for 35 years, won't do matte black repaints, because it's too much aggro).
matto
PostPosted: 18:34 - 31 Jul 2014    Post subject: Reply with quote
Sorry I haven't and it's currently tucked away at the back of the garage awaiting a little work.
Intruder_Andy
PostPosted: 18:48 - 31 Jul 2014    Post subject: Reply with quote
My r attle can paint job
Before
https://i779.photobucket.com/albums/yy72/photo_w87/Mobile%20Uploads/IMAG0198.jpg
After
https://i779.photobucket.com/albums/yy72/photo_w87/Mobile%20Uploads/20140723_073831.jpg
Petrol will cause havoc with Halford tins (I know) and their lacquer is wank. Wouldn't resist a heavy shower let alone fuel but good results can be achieved however it is costly and time consuming.
Andy
The last post was made 12 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 74.26 Kb
