braking issus
Random13
PostPosted: 20:42 - 29 Jul 2014    Post subject: braking issus Reply with quote
good evening,
my disc brakes do get hot I think more often these day ( no surprise , hot weather) but also the disc color has changed form garyish to more like a red/grey color which i think happens when it is hot but seems to stay that color even after it cools down .
couple of basic questions,
1.do i need to clean the brake disc as a maintenance ? in another word does road dirts and brake pad material stick to the disc making the contact between the pad and disc less thus less friction resulting in worse braking performance ?
2. my brake pads have started to make a squeeking sound , is that due to the copper grease on back of the plates drying out or sign or a more serious problem ?
3. the brake seems to be worse when the bike is cold and riding in the morning and as I brake few times it gets better . it sort of feels that the pistons are pushed back out when braking when the disc is cold so I have to brake harder to get the same performance of when the disc is hot after a 1/2 mile of riding .
4. when do you change your pad? when it gets down to having nothing ( the metal bit Smile ) ? does the braking performance gets worse with less pad or brake pad wear?
here is a picture of my pads which I am not sure how much it has got left as the brand new ones seems to be very thing so hard to say how much it has got left ,
https://i59.tinypic.com/5xk6kn.jpg
many thanks for your help
PostPosted: 20:50 - 29 Jul 2014    Post subject: Reply with quote
I'd probably order another set now.
I'd also strip and clean those calipers, if they are getting proper hot, I'd expect some form of movement is now restricted and dragging the pads on the disk without having the brakes on.
Bunny Lingus
PostPosted: 21:07 - 29 Jul 2014    Post subject: Reply with quote
Sounds like it definitely needs a coat of looking at. Can't view the pic but some brake pads have a vertical scored line running through the friction material. Change the pads when the friction material wears to, or pref just before the score mark. What bike is it? Had an old Guzzi that sported discs that would rust before your very eyes after only one day of non use. Red dust everywhere, forks, wheels, alternator cover, you name it...
Bunny Lingus & The Flipside Faggots
PostPosted: 21:23 - 29 Jul 2014    Post subject: Reply with quote
Looks like quite a bit still left on those pads.
Disks generally don't need cleaning off. Unless someone has got oil on them.
The squeak is probably the pads.
Some pads work better when warm. The worry would be if the pads are dragging on the dis (ie, caliper sticking so they drag)
However what pads are currently in the caliper? The slightly odd brake performance reminds me a bit of how the Bandits brakes behaved with some Armstrong pads in there (they were great when new and lasted for ever, but after about the normal expected life of a set of pads the performance tailed off badly).
Random13
PostPosted: 17:55 - 30 Jul 2014    Post subject: Reply with quote
I changed the piston seals recently so don't think it is sticking .
I guess to verify , I lift the front move the wheel and there should be no drag ,right ?
re cleaning caliper do you mean to simply disassemble and clean with washing liquid?
what would you use to clean the disc ?
thanks
PostPosted: 18:06 - 30 Jul 2014    Post subject: Reply with quote
To clean the caliper (if required), get some brake cleaner (5L non aerosol can is pretty cheap) and a toothbrush. Caliper off, pads out and give the pistons a good clean (pump them out a touch). Then push the pistons back in, pads back in , caliper back on and pump the lever a bit. If they drag after that then they need a proper strip down (ie, pistons out and clean behind the seals).
You should be able to spin the wheel and have no real drag. The pads will lightly touch the surface and you will hear that, but they shouldn't be noticeably slowing the wheel unless you have the lever pulled.
TUG
PostPosted: 18:35 - 30 Jul 2014    Post subject: Reply with quote
thanks
If you changed the seals, why? How recently? Those pistons are caked in dirt by the look of that picture. When you changed the seals did you scrape out the corrosion which would of caused the change in seals in the first place? Need a bit more info, but I'm going to hazard a guess that the brake is somewhat seized and the disc will warp through the heat being produced on it.
Haz ER-5, innit!
Random13
PostPosted: 21:43 - 04 Aug 2014    Post subject: Reply with quote
hi all,
I did clean the discs by simply wiping a toilet tissue over it and some gray material which I guess is the brake pad that has melted on it did come off after which the performance of the brake was way better.
now after further inspection I think the disc is scratched as if someone has scratched it with knife perfectly in a round shape which suggest that the brake pad has done it .
by how can it do that when it has a plenty of pad left ?
I am changing it now but very curious .
re rebuilding it , I did change the seals and cleaned the piston as much as I could. It was not rusted but did just do a service on it .
is EBC pad the best out there?
The last post was made 12 years, 77 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 58.36 Kb
