checking disk run-out
Sid_The_Sloth
PostPosted: 00:44 - 31 Jul 2014    Post subject: checking disk run-out Reply with quote
My MOT for the Fazer is up soon, the front disks are pretty worn and need replacing. I've also noticed that at low speed with light braking I can feel the front end sort of bouncing on the suspension, as if the brakes are grabbing and letting go. So I'm assuming slightly warped disks.
I'm going to see a doner bike tomorrow, is there any way I can check the run-out without a gauge? Guessing it'd just be to roll the wheel when off the ground to see if it only rubs in 1 spot? Is there a more accurate way?
2013 Honda Shadow VT750C2B Black Spirit, 1994 CBR600 f2
TUG
PostPosted: 02:33 - 31 Jul 2014    Post subject: Re: checking disk run-out Reply with quote
Gauge or tap and a toothpick will help your judgement. Thumbs Up
Tape the toothpick to the fork leg and spin the wheel that's the best you can do.
Haz ER-5, innit!
Fizzer Thou
PostPosted: 09:25 - 31 Jul 2014    Post subject: Reply with quote
A cheaper/easier way is to take along a black white board marker pen. Draw a wavey mark around the swept area of each disc and roll the bike forwards a full rotation of the wheel.If any part of the wavey line is not removed,it shows the disc is warped.
Always have a 'Plan B'
TUG
PostPosted: 09:31 - 31 Jul 2014    Post subject: Reply with quote
Ahhh sweet, thanks for the tip!
Haz ER-5, innit!
The last post was made 12 years, 84 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 40.11 Kb
