Oil leak from clutch pull rod (R1 5PW engine)
T0MMY
PostPosted: 21:28 - 31 Jul 2014    Post subject: Oil leak from clutch pull rod (R1 5PW engine) Reply with quote
I've got a persistent oil leak from the clutch pull rod on my 5PW engine. I've changed the seal twice now (new one each time) and it's still doing it. The rod doesn't appear to be damaged or scored so I'm at a bit of a loss as to what more I can do? Anyone encountered this before?
ZX6R + CBR600RR
Carvel
PostPosted: 21:38 - 31 Jul 2014    Post subject: Reply with quote
Probably bent.
T0MMY
PostPosted: 22:12 - 31 Jul 2014    Post subject: Reply with quote
Carvel wrote:
Probably bent.
Well there's no need for that Mad
Don't think it is bent though...checked it when I had it out for the second new seal.
ZX6R + CBR600RR
bodger
PostPosted: 08:47 - 01 Aug 2014    Post subject: Reply with quote
Just a thought, Crankcase pressure high?
Check crankcase venting ok
PostPosted: 08:49 - 01 Aug 2014    Post subject: Reply with quote
I'm sure it goes in a specific way, and I know you aren't a retard... but are you sure you are putting it in the correct way Laughing
T0MMY
PostPosted: 18:18 - 01 Aug 2014    Post subject: Reply with quote
Crankcase pressure...hadn't thought of that. It has an oil catch can which never has any oil in it despite it needing to be overfilled slightly (to stop oil starvation as the engine is in a car) so I'm not sure it would be that though as I would have thought I'd be seeing more oil pushed out the breathers?
Well to be fair I am a bit of a retard, but it's definitely in the right way Laughing
ZX6R + CBR600RR
The last post was made 12 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 46.42 Kb
