Bugger, blew my brake light
 Topic moved: from General Bike Chat to The Workshop by Korn (17 Jan 2005 - 10:22)
Demonic69
The Pink Rhino
PostPosted: 15:11 - 16 Jan 2005    Post subject: Bugger, blew my brake light Reply with quote
And the Blade's due for an MOT. The bulbs are fine, I blew the fuse, which I replaced but I still cannot get the light working from the front or back brake.
Any ideas?
Ta
Back on a Blade. Just feels so right.
JonB
Afraid of Mileage
PostPosted: 15:12 - 16 Jan 2005    Post subject: Reply with quote
Sure the connector is OK? maybe just need to tighten the bulb a bit more towards the connector. Smile
Demonic69
The Pink Rhino
PostPosted: 15:14 - 16 Jan 2005    Post subject: Reply with quote
Yeah, the rear light works fine, just the brake filament doesn't
PostPosted: 15:16 - 16 Jan 2005    Post subject: Reply with quote
Does the fuse blow again, or does it just not work?
Fuses often aren't that fast acting, so it may be that another (dodgy) bit of the wiring got taken out in the process.
If you've got a multimeter, try and trace the wiring until you find a bit that stops working.
Demonic69
The Pink Rhino
PostPosted: 15:19 - 16 Jan 2005    Post subject: Reply with quote
It was me faffing with a buzzer that blew the fuse. Everything bar the brake light works Sad
Annabella
Like a person, only smaller
PostPosted: 15:37 - 16 Jan 2005    Post subject: Reply with quote
Check all the wires and look for any loose/dry joints I guess.
Any connectors, give them a good clean with a small metal file, and use lots of WD.. Tis all I can think of.
Avast! Pirates ahoy!
I did Cadwell! Very Happy
mr jamez
PostPosted: 17:29 - 16 Jan 2005    Post subject: Reply with quote
Have you checked the switch? no idea what the one on your bike is like, but mine was full of mud and the contacts were heavily corroded. Easy to take apart and clean up anyway.
Milo
PostPosted: 22:54 - 16 Jan 2005    Post subject: Reply with quote
Must've been braking too hard... Laughing
Shaft drives rule. Razz
PsychoHippy
Jammy Git
PostPosted: 03:22 - 17 Jan 2005    Post subject: Reply with quote
I know this may sound stupid, what with it being a new bulb, but are you sure the bulb itself is not knackered? Question
I spend all my money on bikes and beer, the rest I simply waste!
Demonic69
The Pink Rhino
PostPosted: 08:24 - 17 Jan 2005    Post subject: Reply with quote
It's not a new bulb matey, but both bulbs are fine on the running light fillament, just not the brake one and they don;t look broken Sad
Adam_P
PostPosted: 10:15 - 17 Jan 2005    Post subject: Reply with quote
Looking and being are different though!! Laughing
I bought a brake light bulb for my MT50 years ago from the garage up the road, got it back and fitted it and it did the same as yours is doing. Checked it and the bloody braking filament broken.
Got another, sorted! Thumbs Up
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
Finglonga
PostPosted: 16:10 - 17 Jan 2005    Post subject: Reply with quote
Wot adam said , if you have one whip the bulb out and put a 9 volt (pp3) battery across the terminals on the bulb it will light the filament up if its o.k. If you have a test meter use that. Thumbs Up
Andy Sez....
F.Y.Y.F.F.
Finglonga
PostPosted: 14:05 - 19 Jan 2005    Post subject: Reply with quote
Well?????????????? Question Question Question Question Question Question Question What was it?
Andy Sez....
F.Y.Y.F.F.
Demonic69
The Pink Rhino
PostPosted: 16:49 - 19 Jan 2005    Post subject: Reply with quote
Dunno. Replaced the bulb and it's still not working Sad
PostPosted: 18:00 - 19 Jan 2005    Post subject: Reply with quote
Time for the multimeter?
By the description I would guess that you might have fried the wiring to the brake light, but also check that there is not a fuse hidden in the circuit somewhere.
Where are you at the moment?
Finglonga
PostPosted: 21:14 - 19 Jan 2005    Post subject: Reply with quote
If you find the loom that appears out of the light cluster follow it back to the fuse box and check it has not rubbed through on the frame causing a short or a connector hasn't come undone. Also its worth re-checking the fuse to make sure it's O.K.
Andy Sez....
F.Y.Y.F.F.
Demonic69
The Pink Rhino
PostPosted: 16:32 - 20 Jan 2005    Post subject: Reply with quote
The fuse is fine, I'll try the wiring. I'm at the pub Keith Very Happy
The last post was made 21 years, 25 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.16 - MySQL Queries: 16 - Page Size: 92.32 Kb
