| stevo as b4 |
 Posted: 11:12 - 03 Aug 2014 Post subject: wheel alignment an easy way? |
Popping the rear wheel back into my KMX with the new tyre on, I realised there are no alignment marks on the swing arm (probably been power coated over).
Anyway, I measured the distance between the axle spindle and the end of the swing arm both sides, and it seemed to be about the same. But the swing arm is not perfectly symmetrical on both sides, and the new wider rear tyre, is closer to the RHS than the left. I have a feeling I might be a fraction out with the alignment, but can't really tell by eye.
I know about the two pieces of string method and using a long straight edge to mark the ground in line with the rear wheel, and measure the distance to either side of the front wheel etc.
But I atm have a bad back, am feeling sorry for myself, and I can't do the alignment check with the bike on a stand, as it doesn't sit perfectly level on the frame rails under the motor.
Tl:dr, Until I can get a mate to come round and hold the bike upright and level while I mess around with straight edges and tape measures, am I stuck, or is there a trick I can use?
Have thought about bolting a bit of 3x2 to the garage wall and then strapping the bike to it using a spirit level, but I'm over thinking things I think, and I also thought that wheel alignment via making the adjusters exactly the same length, still does not take into account if the frame, swingarm, or forks where all 100% straight and in line with each other? |
| gavcarter |
 gavcarter Could Be A Chat Bot
 Posted: 11:24 - 03 Aug 2014 Post subject: |
measure from swingarm pivot bolt to rear axle, the swingarm pivots will be perfectly 90 degrees to the frame ( provided the frame is not bent so it is a good reliable point to use). This will remove any confusion from un-symmetrical swingarm sides
Measure Centre to Centre, dont put the tape up against either side of the nut or bolt as chances are the other side will be different size |
| G |
 G The Voice of Reason
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| Wull |
 Wull Crazy Courier
| jjdugen |
 jjdugen World Chat Champion
| Pete. |
 Pete. Super Spammer
| Nobby the Bastard |
| G |
| jjdugen |
The last post was made 12 years, 74 days ago. Instead of replying here, would creating a new thread be more useful? |
