Gaskets?
TomC
PostPosted: 20:51 - 16 Jan 2005    Post subject: Gaskets? Reply with quote
Hello, im the process of rebuilding my Derbi Senda, going to change the piston rings, do i need to buy a full gasket set for it or just a head gasket?? Unsure as i havent built one before.
PostPosted: 21:08 - 16 Jan 2005    Post subject: Reply with quote
You need a 'top end gasket set'. This will contain a head gasket, base gasket, carb manifold gasket, exhaust gasket and any water pipe o-rings you may need to remove if it is liquid cooled.
TomC
PostPosted: 21:15 - 16 Jan 2005    Post subject: Reply with quote
https://www.bike-spares.co.uk/acatalog/senda_00_02.html
Thats the site, are all of them included in the full gasket set??
The only ones i can see on your list seperately are the head and base gasket, water pump gasket?
Thanks for reply.
PostPosted: 21:23 - 16 Jan 2005    Post subject: Reply with quote
The full set will have everything you need, there will be some left over. You shouldn't need a waterpump gasket (which will be in the full kit anyway). Give them a call, I would be surprised if they don't offer a top-end gasket set (for rebuilding the top-end like you are doing) although the head and base gaskets make up over half the cost of the full kit.
The ones I listed in my previous post are what you should need to do the job.
Most of them are made of paper which you could make yourself, the head and exhaust gaskets aren't.
TomC
PostPosted: 21:34 - 16 Jan 2005    Post subject: Reply with quote
Ok wil give them a bell tomorrow, cheers Thumbs Up
cagiva gezzer
PostPosted: 00:22 - 17 Jan 2005    Post subject: Reply with quote
All you need is the base and head gasket on a derbi. Its direct crankcase induction, so there is no need to touch the carb. There isn't a exhaust gasket.
Wish i had that site when i had mine!
TomC
PostPosted: 08:22 - 17 Jan 2005    Post subject: Reply with quote
Ahh smashing thanks gezzer Smile
The last post was made 21 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 51.1 Kb
