how to i put decals on?
CaNsA
PostPosted: 12:32 - 07 Aug 2014    Post subject: Reply with quote
https://i.imgur.com/8TVh5gq.jpg
CaNsA
PostPosted: 12:40 - 07 Aug 2014    Post subject: Reply with quote
clean surface
remove white sheet
place clear sheet with decal on surface
press
remove clear sheet slowly
you fucking idiot.
CaNsA
PostPosted: 12:44 - 07 Aug 2014    Post subject: Reply with quote
PaulFzs wrote:
smd craig suck it hard
How would i do that?
Do i remove the penis from the pants 1st?
temeluchus
PostPosted: 12:46 - 07 Aug 2014    Post subject: Reply with quote
inb4 baww on bikernobs
PostPosted: 12:52 - 07 Aug 2014    Post subject: Reply with quote
Not what craig said. Razz
Clean where the decal is going. Wet the surface that you're going to apply it to, a water mister thing is good for this. Take the backing paper off and wet that the back of the decal, again using the water mister thing. Put the decal in place, position is correctly, use something like a credit card to get all the water and any air bubbles out from behind the decal and then remove the plastic sheet that's over the front. You want to do this at quite a sharp angle and you need to be careful that the decals doesn't lift away from the surface it's going onto.
CaNsA
PostPosted: 12:55 - 07 Aug 2014    Post subject: Reply with quote
My multi-piece BCF decals went on using the method i posted above, no bubbles or creasing or tearing.
You don't float them in a saucer of warm water until they lift away from the backing, and apply them with tweezers? That's what I did with the last lot of decals I applied. Swastikas, I think they were.
daemonoid
PostPosted: 13:08 - 07 Aug 2014    Post subject: Reply with quote
CaNsA wrote:
clean surface
remove white sheet
press
you fucking idiot.
And a proper pro leaves slightly soapy water on the bike to allow repositioning and then uses a flat edge to force the water out. (The bigger the sticker the more important this step is).
current: ducati monster 750
PostPosted: 16:46 - 07 Aug 2014    Post subject: Reply with quote
I thought it was warm milk and the rest you feed to the kittens.
PostPosted: 17:01 - 07 Aug 2014    Post subject: Reply with quote
Problem with milk is that you can't see them when they sink.
Bunny Lingus
PostPosted: 23:16 - 10 Aug 2014    Post subject: Reply with quote
https://www.youtube.com/watch?v=rC03c9rUzDs
Bunny Lingus & The Flipside Faggots
deadwolf
PostPosted: 03:46 - 11 Aug 2014    Post subject: Reply with quote
Never tried the soapy water method. I use a hairdryer (especially when applying decals on curved or uneven surfaces) to heat and slightly stretch the decals so that they fit the curve properly. Especially helpful for helmets.
Motorsapien Art
ws4936
PostPosted: 11:11 - 11 Aug 2014    Post subject: Reply with quote
Airfix.
If everything seems under control, you're just not going fast enough.
The last post was made 12 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 102.39 Kb
