Petrol leak yamaha aerox
Carlerskine97
PostPosted: 19:22 - 07 Aug 2014    Post subject: Petrol leak yamaha aerox Reply with quote
Hi I have a yamaha aerox 50cc on an 08 plate it has started to leak petrol when I cut of the engine just wondering if anyone has any idea what it could be?
Thanks carl
c_dug
PostPosted: 19:34 - 07 Aug 2014    Post subject: Reply with quote
Could be a number of things, can you tell where it is leaking from?
Carlerskine97
PostPosted: 22:25 - 07 Aug 2014    Post subject: Reply with quote
Yeah it's leaking down from the carb overflow
Carl yamaha aerox
c_dug
PostPosted: 22:28 - 07 Aug 2014    Post subject: Reply with quote
I'm no expert, far from it, but the first thing that springs to mind is a float issue, either a worn float jet which isn't sealing up, or perhaps a leak in a float, causing it to... err... sink!
I'd wait for confirmation from somebody more knowledgeable before stripping anything down.
Assuming it is that, is will be a fairly cheap fix.
Carlerskine97
PostPosted: 07:42 - 08 Aug 2014    Post subject: Reply with quote
Ok I appreciate your help thanks
Carl yamaha aerox
Nope.
PostPosted: 09:43 - 08 Aug 2014    Post subject: Reply with quote
Hi,
Firstly this should be posted in the workshop, not in general bike chat. Please read the forum titles!
Secondly it sounds like your float is sticking. Try tapping the float bowl quite hard with the end of a screwdriver and see if it stops leaking.
You'll probably need to strip your carburettor down and clean out the float bowl/needle valve area and check for any excess wear on those parts and the rubber o-rings. Sometimes you can't see the wear and the parts are generally cheap enough that it just makes sense to replace them anyway.
The last post was made 12 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 46.33 Kb
