pulse adrenaline rebuild with gs125 engine
impulsive
PostPosted: 09:56 - 10 Aug 2014    Post subject: pulse adrenaline rebuild with gs125 engine Reply with quote
this is my first bike an first attempt at doing anything related to work on my bike so take it easy on me, was over on chinamotoforum but no one ever replies over there (rarely)
i have just started the journey on rebuilding my adrenaline, i have a gs125 engine here for it and lots of other new add ons, i have only sprayed the frame so far as i need to get hold of a better swinging arm this week, i am hoping to have this project done within 2-3 weeks and am hoping you guys will be able to help me get it running :riding: again!
so i wire brushed the frame and gave it a good coat of jenolite
https://i1278.photobucket.com/albums/y501/coryjohn2/1466141_10201852429053786_676094260639372702_n_zps4140c0d2.jpg
https://i1278.photobucket.com/albums/y501/coryjohn2/1622031_10201852427813755_7252241270097981901_n_zps97d9b31e.jpg
after a few coats of red oxide primer and a bit of flourescent green paint
https://i1278.photobucket.com/albums/y501/coryjohn2/1654295_10201852429933808_3974664729230069727_n_zpse455546b.jpg
finished of with a few more layers of flourescent green and 2k laquer
https://i1278.photobucket.com/albums/y501/coryjohn2/d6d40acd-42d5-47be-b3d2-309e6dbe0fea_zpsd3eb5348.jpg
its currently curing by radiator in my living room, going to service the gs125 engine and paint it matt black while i wait for new swinging arm to arrive in post! :scooter:
need to scrub the paint off my floor now in garden, should of used newspaper but as my name suggests i am impulsive Very Happy
impulsive
PostPosted: 09:58 - 10 Aug 2014    Post subject: Reply with quote
just taking the engine apart now what you think of clutch look ok? https://s30.postimg.org/65y6xpymp/10257813_10201898880815051_4189202502502268807_n.jpg
also removed the oil filter got new one here
https://s1.postimg.org/acerwa1zj/10154237_10201898877694973_1373268646258612980_n.jpg
and when i removed oil nut plug on bottom a nut and spring fell out also? will be taking other side off soon enough now!
https://s30.postimg.org/i8zdqx18x/1512385_10201898876774950_1764241472220709517_n.jpg
impulsive
PostPosted: 10:01 - 10 Aug 2014    Post subject: Reply with quote
been spraying the tank
https://s28.postimg.org/eat1vgke5/DSCF0130.jpg
https://s27.postimg.org/es3uu00c3/DSCF0135.jpg
sprayed a few coats of 2k lacquer over the new swinging arm i bought Smile
impulsive
PostPosted: 10:02 - 10 Aug 2014    Post subject: Reply with quote
got the 2 heads off the engine almost identical, can I use the one from my pulse that doesn't have a speedo drive on the Suzuki engine?
https://s27.postimg.org/63pnysmr7/DSCF0247.jpg
impulsive
PostPosted: 10:04 - 10 Aug 2014    Post subject: Reply with quote
been busy and the garage I mean the living room is looking a mess Very Happy
https://i1118.photobucket.com/albums/k605/meanman2/bike/DSCF0258.jpg
https://i1118.photobucket.com/albums/k605/meanman2/bike/DSCF0256.jpg
https://i1118.photobucket.com/albums/k605/meanman2/bike/DSCF0255.jpg
https://i1118.photobucket.com/albums/k605/meanman2/bike/DSCF0254.jpg
https://i1118.photobucket.com/albums/k605/meanman2/bike/DSCF0253.jpg
not sure what this is (the next 2 pics) dropped out of the engine from the lil nut next to the mesh oil thing?
https://i1118.photobucket.com/albums/k605/meanman2/bike/DSCF0265.jpg
https://i1118.photobucket.com/albums/k605/meanman2/bike/DSCF0264.jpg
https://i1118.photobucket.com/albums/k605/meanman2/bike/DSCF0262.jpg
impulsive
PostPosted: 11:08 - 10 Aug 2014    Post subject: Reply with quote
any idea of what throttle sleeve I could buy to replace this one?
https://i1118.photobucket.com/albums/k605/meanman2/DSCF0267.jpg
SQL
PostPosted: 11:34 - 10 Aug 2014    Post subject: Reply with quote
Get a 1/4 turn throttle assembly
piazza
PostPosted: 13:19 - 10 Aug 2014    Post subject: Reply with quote
Check your parts here. https://www.cmsnl.com/suzuki-gs125_model13402/
Nice work btw, looking good! Thumbs Up
Fisty: The uncle that touched you up as a child and told you not to tell anyone. That's BCF that is.
qarka
PostPosted: 14:14 - 10 Aug 2014    Post subject: Reply with quote
I wouldn't put the chinese head on the Suzuki engine! One of these was my first bike, great to learn maintainence on since it kept falling to bits. Looking pretty good so far. Thumbs Up
I got a straight through pipe and larger carb from Xianxian Racing or something, don't think they are still around. Took me a while to get it tuned up so if you go down that route prepare for a lot of fiddling/jet changes. I still see mine blatting about sometimes when I go back to my hometown Laughing
You might find this thread interesting.
impulsive
PostPosted: 15:44 - 10 Aug 2014    Post subject: Reply with quote
cheers guys also im not using the Chinese head just the rocker cover as it had a speedo inserted through it, still cant figure out what that spring thing is from, will take the Chinese engine apart to see if I can find where it goes in the engine, unless anyone has any idea? Idea
piazza
PostPosted: 11:14 - 11 Aug 2014    Post subject: Reply with quote
Is the spring and bolt for the camchain tensioner perchance? the c90 has 2 similiar bolts that could be confused...
impulsive
PostPosted: 12:29 - 11 Aug 2014    Post subject: Reply with quote
its not a bolt it don't have any threads on it, also have taken the cam tensioner out to have a look and its whole in tact Sad
impulsive
PostPosted: 00:54 - 12 Aug 2014    Post subject: Reply with quote
found out the metal bit and spring is meant to go in the little hole before the sump nut doh!
https://i1118.photobucket.com/albums/k605/meanman2/DSCF0270.jpg
Bunny Lingus
PostPosted: 03:42 - 12 Aug 2014    Post subject: Reply with quote
Nice paint distribution & build up Thumbs Up I'm willing to bet you ain't using rattle cans Laughing Your clutch looks fine but the action will depend on how much meat you have on the plates. I agree with Quarka re: the head but the rocker cover should be fine - if the cap fits, wear it... Good work fella Thumbs Up
Bunny Lingus & The Flipside Faggots
impulsive
PostPosted: 12:07 - 17 Aug 2014    Post subject: Reply with quote
bough new plastics and stickerbombed
https://i1118.photobucket.com/albums/k605/meanman2/DSCF0291.jpg
https://i1118.photobucket.com/albums/k605/meanman2/DSCF0290.jpg
https://i1118.photobucket.com/albums/k605/meanman2/DSCF0289.jpg
https://i1118.photobucket.com/albums/k605/meanman2/DSCF0288.jpg
https://i1118.photobucket.com/albums/k605/meanman2/DSCF0287.jpg
impulsive
PostPosted: 01:21 - 21 Aug 2014    Post subject: Reply with quote
new molkt carb and ramair filter, think it is a 30 instead of a 22mm standard carb
https://i1118.photobucket.com/albums/k605/meanman2/e67b927e-5221-49d3-91d3-d6334a34c262.jpg
been trying to get the wiring done, im still confused about a few wires but will see where im at in the next few days
https://i1118.photobucket.com/albums/k605/meanman2/a680645c-df5b-4cde-9175-16f03a41b486.jpg
does anybody know which wire I should join here, trying to fit a different taillight to my rear end
https://i1118.photobucket.com/albums/k605/meanman2/161fe8d2-6f3a-4eb3-90b0-ecf845756f53.jpg
nowhere.elysium
The Pork Lord
PostPosted: 08:38 - 21 Aug 2014    Post subject: Reply with quote
IIRC, it's the plug with the three wires that are the ones to the tail light. I believe that the green/yellow wire is the common earth, although I can't remember which one's the brake switch line.
There's every chance that the bike won't run very well with that carb/filter setup. When I had mine, it was perfectly happy with a pod on the stock carb - a wider-bore carb does not directly translate to more power.
PostPosted: 09:22 - 21 Aug 2014    Post subject: Reply with quote
I used a 26mm on a 16hp 140cc engine, that carb is indeed slightly too big.
stevo as b4
PostPosted: 19:07 - 21 Aug 2014    Post subject: Reply with quote
Project is looking good though, and nice to see someone spending lots of time and money on a 125, and the level of finish so far has impressed me, (even though sticker bombing makes me sick with rage)
There's been a bit of this kind of thing on here lately, like the Guy with the CBR125, where people have been doing some good stuff with 125's and really decent quality of work, which is something you don't expect on 125's due to their reputation/owner profile.
trevor saxe-coburg-gotha
PostPosted: 20:43 - 21 Aug 2014    Post subject: Reply with quote
qft
KLR600
PostPosted: 22:02 - 21 Aug 2014    Post subject: Reply with quote
I do like a good sticker bomb, I did half of my front mudguard to cover a massive crack. Stylish yet functional Laughing
<Take Cool Photos!>
smegballs
PostPosted: 06:16 - 22 Aug 2014    Post subject: Reply with quote
I think with the stickers: if its stuff from products you've actually bought, which build up over time then it's acceptable. It's a bit ghey to just buy stickers and whack them on like that tho.
Similar idea to the idea a rat-bike should naturally develop, not be deliberately made from a bike in ok nick.
evoboy
PostPosted: 10:20 - 22 Aug 2014    Post subject: Reply with quote
Running a 28mm on a 50cc, because the 21mm was far too small.
Sush. Laughing
APT Motorcycles
PostPosted: 10:23 - 22 Aug 2014    Post subject: Reply with quote
Sush. Laughing
What 50?
This is a chinky 125, use your fucking noggin.
The last post was made 12 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.76 - MySQL Queries: 13 - Page Size: 132.86 Kb
