CBR6 steering response question
Paul2129
PostPosted: 11:25 - 10 Aug 2014    Post subject: CBR6 steering response question Reply with quote
Ok, the bike is a 1996 CBR600 FT, the last model with a steel frame, might be also known as an F4. I've had the bike almost 18 years from new, and I have about 80,000 miles experience on bikes.
The bike he been used less in the last few years, and also recently I had Pirelli Road Sport 3's fitted front and rear, this is the tyre with some unusual technology and lots of cuts (sipes?) on the front tyre, it created seperate blocks of tread, and the tyres are quite soft.
Also, just to point out that the tyres have no noticeable wear, the shape is still as was manufactured, no flat spot in the middle, and the pressure is fine. The bike has never had any head bearings, and has been subject to standing around in the garage for months on end. There is no noticeable notch in the steering when moved around on a smooth floor, the same with rider or not, and nothing can be noticed when tipping the wheel in the air using the centre stand.
The issue I notice is that of feelin like the tyre is flat. In traffic, at walkin pace, it (can) feel like the tyre is flat, it wants to 'stick' in a straight line. The same can happen when going straight and tipping into a corner, turning right at lights for example, or tipping into a roundabout, it was so bad the other night that it affected balance, and it generally makes the bike feel like it won't steer properly.
An experienced rider, one who has almost the same bike, and he didn't notice anything, but he rides much faster than me and is less critical.
Would people suggest that a new set of head bearings be fitted first ? Then clearly I could change the tyre next should the problem still persist
Please post if you've ever experienced anything like this.
PostPosted: 11:26 - 10 Aug 2014    Post subject: Reply with quote
Suspension knackered?
Bendy
Mrs Sensible
PostPosted: 11:47 - 10 Aug 2014    Post subject: Re: CBR6 steering response question Reply with quote
It's an F3 if you feel like being American.
What tyre pressures are you running?
I'm presuming you feel the problem is with the front end, from the head bearings references, but you don't actually specify. What sort of state is the rear suspension in? What is the mileage on it? Does the problem manifest itself equally to the left and to the right?
With no notchiness and presumably no clunking under braking, head bearings wouldn't be the first thing in my mind. Duff pressures or a tired shock (plus a healthy dose of convincing yourself it's doing something weird, which explains your mate not minding it) would be my first thoughts.
Paul2129
PostPosted: 12:04 - 10 Aug 2014    Post subject: Reply with quote
Thanks for the replies. Ok, we're talking slow speed here, I would doubt that at 7mph in traffic, or turning at traffic lights that the suspension is contributing to the issue. True that the suspension is 18 years old, front and rear having some 55,000 miles use, but truthfully, riders of newer bikes have ridden mine expecting it to ride like a saggy old bike, their unprompted comment that it's still crisp, with little dive under braking.
My previous tyres were Michelin Macadam's, I think not as soft as these Road 3's, maybe I'm noticing a sticky compound doesn't like initial turn-in as much ?
Pressures are 36/42 fr/rear
Paul2129
PostPosted: 12:06 - 10 Aug 2014    Post subject: Reply with quote
As to if the problem is the same left/right, I must admit, roundabouts and right turns at lights are where I've noticed it more. I'll check next time I'm out and report back
Marmaduke
PostPosted: 14:27 - 10 Aug 2014    Post subject: Reply with quote
I had a serious problem turning right when I first got the multistrada. I had the front tyre changed and chain replaced.
So it was either a dodgy front tyre or misaligned rear as it was perfect afterwards.
Maybe a small chance the forks were twisted in the yokes but I doubt it as it was never mentioned by the mechanic.
Current: '03 Tuono RSV1000, '05 Van Van, '91 Zephyr 550
Previous: Multistrada 620,Bandit 600,Kawsaki ER-5, BMW K-75
baggylastard
PostPosted: 17:32 - 10 Aug 2014    Post subject: Reply with quote
I've got PR3s on a 1998 and I think they feel a little strange and a tad slow, but mine does need a good going over soon as I can take it off the road.
wristjob
PostPosted: 18:28 - 10 Aug 2014    Post subject: Reply with quote
if your pr3's are stamped pirelli i think they may be some cheap knockoff Smile
baggylastard
PostPosted: 19:12 - 10 Aug 2014    Post subject: Reply with quote
You may be right, ignore me. I can't read.
chickenstrip
PostPosted: 19:20 - 10 Aug 2014    Post subject: Reply with quote
If you've confirmed the steering bearings are ok, and others who ride it say the suspension feels ok, then I'd be inclined to think it's a tyre that just doesn't suit you. Very subjective things, some people will rate a tyre very highly, and others will slag off the same and can't get on with them.
Maybe try a cheap, part worn jobbie and see what the difference is?
mysterious_rider
PostPosted: 19:36 - 10 Aug 2014    Post subject: Reply with quote
had similar thing, was a worn front tyre at fault. Didn't look too bad mind, but it was. Also make sure you are running the correct psi front +rear.
KAWASAKIIIII
gavcarter
PostPosted: 19:43 - 10 Aug 2014    Post subject: Re: CBR6 steering response question Reply with quote
Just incase it helps, I have a 97 which is the FV and that is a steel frame - may help with parts etc....
If you work your way through everything and cant find anything wrong, look at the swing arm bearings and rear suspension linkage.
Any side to side play will be masked when you drop into a corner and the bike weights it off to one side and it stays there. Where as slow up-right you'll be able to feel it shift around.
Not sure how much that affects the feeling on front end but can cause some pretty weird symptoms.
The last post was made 12 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 73.46 Kb
