Exhaust and downpipe packing
koolio
PostPosted: 17:01 - 10 Aug 2014    Post subject: Exhaust and downpipe packing Reply with quote
This is my first time doing this so would like to get it right, hopefully you guys could help..
I've got a set of old CB450 downpipes and I've paired them with a set of Harley sportster exhausts which have clamps. Both used.
They fit perfectly.
Question is do I need to put packing or a gasket between the down pipes and exhaust? Just where do I get this and what size am I meant to get?
Would be appreciated and sorry for the noob question, never touched exhaust systems before...
PostPosted: 17:12 - 10 Aug 2014    Post subject: Reply with quote
What's the diameter of both, and what do you mean by "packing".
koolio
PostPosted: 17:26 - 10 Aug 2014    Post subject: Reply with quote
I don't mean the gasket at the head between the cylinder and the down pipe.
I'm just wondering if there shouldn't be a gasket between the downpipe and exhaust. I've seen it referred to as a gasket or packing (I don't mean the packing inside the exhaust).
Downpipe is 42.8mm
Exhaust unclamped is 44.5mm
PostPosted: 17:32 - 10 Aug 2014    Post subject: Reply with quote
Some bikes use a gasket, some do not. Clamp it up, see if it leaks.
koolio
PostPosted: 17:43 - 10 Aug 2014    Post subject: Reply with quote
If it leaks any ideas of what to do? This is a CB450 downpipe with a harley sportster exhaust, so not stock..
PostPosted: 18:00 - 10 Aug 2014    Post subject: Reply with quote
While some bikes have a kind of tube gasket between pieces (FZR600 for example) the chances of finding one to suit are probably limited.
The thickness of any 'gasket' in this case is about 0.8mm. If you slot the outer the it would clamp down easily (possibly with some kind of sealant). Failing that possibly knock up a thin wall copper tube of the appropiate dimensions
koolio
PostPosted: 19:27 - 10 Aug 2014    Post subject: Reply with quote
Thanks guys I may go with an original CB450 muffler gasket and see if it fits..
koolio
PostPosted: 12:41 - 12 Aug 2014    Post subject: Reply with quote
Bad news the exhaust does not clamp onto the downpipe on its own and the graphite gasket for the CB450 is far too thick to accept the exhaust.
Anyone any ideas how to get around this? Can a graphite gasket be machined down?
gavcarter
PostPosted: 12:57 - 12 Aug 2014    Post subject: Reply with quote
You can pick them apart layer by layer, ive had to to do it before. Just use a sharp blade to open the layers up one at a time and peel it off, test fit and repeat.
When its about the right size cake it in exhaust paste and clamp it down, the paste will block up the smaller holes left by the rough surface after peeling the top layers off
koolio
PostPosted: 13:03 - 12 Aug 2014    Post subject: Reply with quote
Thanks maybe I just need exhaust paste, I'm talking about roughly a 1mm gap between the exhaust and downpipe?
gavcarter
PostPosted: 13:16 - 12 Aug 2014    Post subject: Reply with quote
Paste tends to go dry and crumbly but its worth a try - It will more than likely hold up for a good amount of time if you left it to "air dry".
If you fire it up when the paste is wet - it will likely blow out all over the place.
If the paste fails use cheap bathroom sealant! wilkos own tends to work well. No seriously, it dries rock hard but actually adheres the two pipes aswell - it can take some prodding and poking to separate them again but it will seal the gap no probs.
A third option is to use a strip of 1mm metal as a gasket with a light coating of paste on either side.
koolio
PostPosted: 13:26 - 12 Aug 2014    Post subject: Reply with quote
Ok this is great help..
Will the bathroom sealant withstand the heat?
If I got the graphite to a good fit surely clamping that down would suffice or would I still need the sealant?
gavcarter
PostPosted: 13:34 - 12 Aug 2014    Post subject: Reply with quote
Would more than likely suffice I would give it thin coat of paste before fitting just to help get an air tight seal.
Yes, it seems to I have used it a few times as a "quick fix" and ended up being there a good year or two as it didn't fail.
Im sure i've read of a few others using it aswell
koolio
PostPosted: 13:44 - 12 Aug 2014    Post subject: Reply with quote
gav thank you a lot.
I can see the graphite rings now trouble is I would literally need to halve the graphite gasket to get it to fit, I hope it holds up..
gavcarter
PostPosted: 13:48 - 12 Aug 2014    Post subject: Reply with quote
It should do, it only has to provide something to get crushed in the gap.
A bit of exhaust paste will take car of the tiny gaps left, and it makes it easier to get the pipes in with the paste on
PostPosted: 18:21 - 12 Aug 2014    Post subject: Reply with quote
If you have access to a lathe you can probably machine up a tube spacer to go between them.
As to sealant, flue sealant is a high temp silicone sealant and should be fairly easy to source.
The last post was made 11 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 87.69 Kb
