Replace fuel tap with straight hose connector
alexanderfitu
PostPosted: 09:05 - 11 Aug 2014    Post subject: Replace fuel tap with straight hose connector Reply with quote
Hi all
I have a big leak on the fuel tap of My XJ600 diesel bike.
Im sure the main reason is that the rubber in the seals isnt compatible with Veg oil (most isnt) and its disintegrated, leaking fuel all over my primary belts Sad
It seems as though nobody makes a repair kit either, so I would like to replace it with a staight 8mm hose connector.
Any ideas on how to go about it, I could try and undo the tape assembly and see if there is a way to seal off the tap sections, but the leaking issue would still be there.
Irn-Bru
PostPosted: 09:29 - 11 Aug 2014    Post subject: Reply with quote
Diesel bike? Question
alexanderfitu
PostPosted: 09:46 - 11 Aug 2014    Post subject: Reply with quote
https://fotifixes.com/2013/08/19/xj-600-diesel-bike/
I need to start putting that link in my signature Smile
Start from the bottom of this link for build log:
https://fotifixes.com/category/automotive/motorbikes/diesel-xj600/page/2/
PostPosted: 09:47 - 11 Aug 2014    Post subject: Reply with quote
There are numerous XJ600 fuel tap repair kits listed on ebay.
I would imagine most modern seals will now be made to be ethanol proof which is more likely to be oil compatible too.
There are a lot of XJ600s out there but most of the taps I've found by googling seem to attach to the tank via a flange.
So, to fit a hose-tail you'd need to replicate this flange. I'd suggest the easiest way would be by drilling three holes in a rectangular block of aluminium. Use the original tap as a template for the hole positions (maybe need to slightly countersink the inside of the two screw holes where they meet the tank if there is a raised area there).
The middle hole can be drilled and tapped to accept a hose-tail.
I would suggest a 1/4" BSPT male to 5/16" ID Hose fitting. That means you'd need to make your middle hole 7/16" (11.2mm) and tap it using a 1/4bspt tap.
The taper thread is self-sealing. I'd use a thick gasket under the block cut out of either cardboard, viton rubber or (going modern and ratty at the same time) a silicone baking sheet.
alexanderfitu
PostPosted: 10:06 - 11 Aug 2014    Post subject: Reply with quote
Hm not a bad idea. All of those listed where for Diversion 92> mines a pre diversion 91, im not sure if the taps are different. Couldnt find anything that would say they are the same.
I like that idea, I think its the best. Try and replicate the flange with a thick enough piece of Ali, I will take the tap off again tomorrow and see what the hole looks like. Maybe be easy enough?
The other option is to gut the tap and just seal it off completely, then use a seperate tap further down for when I need to remove the tank.
PostPosted: 11:41 - 11 Aug 2014    Post subject: Reply with quote
_Iain_ wrote:
Quick thought though.
Why do you even need a fuel tap on an engine that doesn't have a carburettor?
I mean if it runs out of fuel the injectors will just airlock and cause headache anyway, so a reserve is pretty much useless. The vaccum petcock side of things is again, useless as the whole thing would work on an injector pump that won't be moving any fuel unless it's rotating - there's nothing there to flood, no floats etc.
Seems like costly arseache to find and fit a largely pointless component unless I'm missing something?
I referr you to the title of the thread...
Robby
Dirty Old Man
PostPosted: 11:49 - 11 Aug 2014    Post subject: Reply with quote
Assuming the part that fails is the diaphragm in the vacuum tap, just replace it with a normal gravity- fed fuel tap. No rubber parts, and you get to still have main tank and reserve. Also means you can easily turn the fuel off when you remove the tank from the bike.
gavbriggs
PostPosted: 21:33 - 11 Aug 2014    Post subject: Reply with quote
I have no idea if it will work but you can get a fitting that basically puts a spigot in things such as a header tank for the central heating, maybe you could use one?
Recent bikes: Varadero 125 - Mod 2 3/2/14 - Bandit 1200 SK4
PostPosted: 22:13 - 11 Aug 2014    Post subject: Reply with quote
Fuel tap rebuild kit here:-
https://www.nrp-carbs.co.uk/shop/index.php?route=product/product&path=42&product_id=3474
Found a few pics online and it looks like a fairly normal Yamaha fuel tap (looks like the one on my FZ750 I think). Suspect quite a lot of other Yamahas have taps that could also be used on it.
alexanderfitu
PostPosted: 07:28 - 12 Aug 2014    Post subject: Reply with quote
Many thanks Keith, I phone them yesterday and ordered a rebiuld kit from them.
I had a closer look, seems to just be leaking between the tank and the tap seal. Hopefully its just that! Thanks all.
Robby
Dirty Old Man
PostPosted: 07:42 - 12 Aug 2014    Post subject: Reply with quote
The tap seals to the tank with a little rubber gasket or O-ring. If the veg oil or diesel is eating this seal, try making a silicone one out of silicone pipe.
alexanderfitu
PostPosted: 08:13 - 12 Aug 2014    Post subject: Reply with quote
Have a replacement on its way made from Viton which should be Veg resistant.
The last post was made 11 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 82.98 Kb
