(Car Problem) - Intermittent Cutting out
von1papen
PostPosted: 12:32 - 13 Aug 2014    Post subject: (Car Problem) - Intermittent Cutting out Reply with quote
Dear BCF,
Car - 1.2 Corsa C (2003)
Originally when bought it would cut out around 3/4 seconds after starting. You could rev plenty whilst it ran for those few seconds, so I doubted it was a fueling issue.
I replaced the crank sensor as I knew this was a known fault. This seemed to fix the issue, no more cutting out. (around May)
Yesterday the car started doing the same thing, I replaced the crank sensor again (being £8 I thought it was worth a punt and I'd heard the pattern ones could fail).
Didn't help at all, car still cuts itself out after afew seconds.
There are no dash warning lights on either.
I would note that this has started just as the mornings have got a lot colder. Don't know if it is temperature related?
Does anyone know of any more common faults?
Thanks,
von1papen
Honda CG125<Honda CM200< Kwak GT750 (SOLD) < BMW R65
Bunny Lingus
PostPosted: 14:33 - 13 Aug 2014    Post subject: Reply with quote
Learned to drive in one of those. Was really annoying 'cos it cut out several times during my lessons. The instructor kept swapping the ignition key which used to get us going so try your spare? Other than that it'll be the usual shit - sensor or coil pack.
Bunny Lingus & The Flipside Faggots
unitynotsocri... This post is not being displayed because the poster is banned. Unhide this post / all posts.
von1papen
PostPosted: 21:45 - 13 Aug 2014    Post subject: Reply with quote
The thing being is it never cut out whilst driving, and it is a very deliberate, exact same time cut out right after starting the car.
My thoughts are that the ECU is deliberately cutting off the fuel supply because it isn't getting information from some sensor or another, so it turns the engine off to prevent damage.
Or it may be a key chip/immobiliser problem, I may suck it up and pay for it to get plugged in and have the ECU read. Wwill probably save time and money in the long run. Crying or Very sad
DMCpro
PostPosted: 22:14 - 13 Aug 2014    Post subject: Reply with quote
Possibly cam sensor normally both cam and crank sensors are changed when one of them is suspected to be at fault
Honda CB-1, TS125X
VW Golf Estate
von1papen
PostPosted: 07:28 - 14 Aug 2014    Post subject: Reply with quote
I'll go and pick up a cam sensor, sounds about right.
If the ECU didn't know what position the cams were at it would shut down to stop catastrophic damage.
bugeye_bob
PostPosted: 07:45 - 14 Aug 2014    Post subject: Reply with quote
could it be the IACV dirty and sticking ?
Aff
PostPosted: 09:07 - 14 Aug 2014    Post subject: Reply with quote
Immobliser?
You got a different key you can try?
I had an Audi that would do exactly this every now and then. Start for 1-2 secs then cut out. ECU was full of "Immobiliser Triggered" codes. New key fixed it.
Electric Bike Project
dydey90
PostPosted: 09:43 - 14 Aug 2014    Post subject: Reply with quote
Is the Corsa C UK forum still running?
If you do go on that forum and see any posts from a similar username to mine from about five years ago, it certainly wasn't me.
von1papen
PostPosted: 09:59 - 14 Aug 2014    Post subject: Reply with quote
Unfortunately I don't have a spare key, the key that came with it is knackered and the remote doesn't work.
Can you have a new one copied off a dodgy one? I wouldn't want to pay £100 odd quid if the new one would be as bad as the old. Or is this possible?
The last post was made 11 years, 140 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 63.05 Kb
