Duff battery - need some confirmation
Eddie Hitler
PostPosted: 14:53 - 18 Aug 2014    Post subject: Duff battery - need some confirmation Reply with quote
Left my bike standing for a few days last week. When I came to start it, it didn't have enough juice to go. Push started fine, although I couldn't use the lights. If I did, there wasn't enough current going to the coils so it spluttered to death.
Fast forward to today, I charged the battery fully over 3 days. Whacked it back into the bike thinking it would be fine. Got as far as Thetford and it choked out on the new bypass. As usual, I was able to jump start it and get the 50 miles home.
Am I correct in thinking the stator is fine? Would the reg/rec be fried but allow me to use the bike with a dead battery? The battery itself is well over a year old, so could just be fucked.
Aff
PostPosted: 14:56 - 18 Aug 2014    Post subject: Re: Duff batter - need some confirmation Reply with quote
Aww, I thought my years of experience working in a Chippy as a teen were about to pay off.
In regards to the battery, get a multimeter on it and see if your reg rec is working.
Electric Bike Project
Eddie Hitler
PostPosted: 14:58 - 18 Aug 2014    Post subject: Re: Duff batter - need some confirmation Reply with quote
I got in a cheeky edit before your post. Razz .
Have my multimeter handy right now. I suppose a duff reg/rec would still allow me to use the bike with no charge in the battery, supplying enough to run the ignition?
gavcarter
PostPosted: 14:59 - 18 Aug 2014    Post subject: Reply with quote
Battery is probably dead but i would get a multimeter and check stator and rec reg too
Aff
PostPosted: 15:01 - 18 Aug 2014    Post subject: Re: Duff batter - need some confirmation Reply with quote
Reg/rec deals with charging the battery.
If your battery has charge the bike will work until it runs out.
The reg/rec could be undercharging or your alternator could be dead.
Have a look at this:
gavcarter
PostPosted: 15:02 - 18 Aug 2014    Post subject: Reply with quote
If reg rec fails totally then no once battery is dead again bike wont sustain itself. At present it sounds as though its sustaining the bike but not recharging battery
Aff
PostPosted: 15:04 - 18 Aug 2014    Post subject: Reply with quote
I read it as the bike cut out whilst running. I would say the battery aint charging.
iooi
PostPosted: 15:06 - 18 Aug 2014    Post subject: Re: Duff battery - need some confirmation Reply with quote
This does not make sense.
Unless you stopped and turned the engine off. Then tried to stat it again.
Eddie Hitler
PostPosted: 15:19 - 18 Aug 2014    Post subject: Re: Duff battery - need some confirmation Reply with quote
Eh?..
I charged the battery, put it back in the bike and it fired up immediately, no issues at all. After 40 miles, the battery drained as it mustn't have been getting any charge (checking the reg/rec as we speak).
I was able to bump start it after it cut out, then continue using the bike. It would cut out if I stopped, but absolutely fine when moving, hence my thinking the stator is fine. I was confused as I thought the reg/rec must have been fine if I was able to use the bike with a dead battery. Looks like I'll be checking everything.
I had been using the bike daily with no problems for months before parking it up then finding a dead battery. Bit confused, how would the stator/reg rec fuck up when not in use?
Aff
PostPosted: 15:28 - 18 Aug 2014    Post subject: Re: Duff battery - need some confirmation Reply with quote
Eh?..
OK reading this properly, now it does sound more like a duff batter.
I missed the part where you started it again.
Eddie Hitler
PostPosted: 15:34 - 18 Aug 2014    Post subject: Re: Duff battery - need some confirmation Reply with quote
I rode another 50 miles on the dead batter to get myself home. Ran fine. Because the batter was dead, even using the indicators would use current from the stator and cause the engine to stall.
Just to confirm.. I'm correct in thinking the stator is fine? Most likely the R/R.
Aff
PostPosted: 15:44 - 18 Aug 2014    Post subject: Re: Duff battery - need some confirmation Reply with quote
If the reg/rec and stator are working as normal but the batter wont accept charge that will give you the symptoms your are experiencing.
Easy enough to check, just follow that pdf.
iooi
PostPosted: 15:47 - 18 Aug 2014    Post subject: Re: Duff battery - need some confirmation Reply with quote
Pins wrote:
Eh?..
Still not answered the question.
If you did not stop the engine.
Then why would bump starting the bike make any difference.
Battery would still be in the same state.
Think about it. You are riding and the bike cuts out due to a duff battery. How is bump starting it going to get it a further 50 miles ? As all you have done is restarted the engine.
Eddie Hitler
PostPosted: 15:53 - 18 Aug 2014    Post subject: Re: Duff battery - need some confirmation Reply with quote
No idea what the fuck you're on about.
Pretty sure the reg/rec is fubar. Reading above 850 on the diode test.
Aff
If the batter wasn't accepting charge but the rest of the charging system was working OK, then it would run once you get the engine spinning.
Would also want to cut out if you got the revs a bit low, batter is still trying to eat all the powar, lights on, ignition, etc. All whilst the alternator is working in its least efficient range.
Eddie Hitler
PostPosted: 15:57 - 18 Aug 2014    Post subject: Reply with quote
Scratch that. Reg/rec is fine.
Wull
PostPosted: 17:14 - 18 Aug 2014    Post subject: Reply with quote
Hahaha.......
What's the charge rate across the battery with the bike running?
"Scooters are for men who want to ride motorcycles but prefer to feel the wind on their vaginas"
Wull
PostPosted: 17:21 - 18 Aug 2014    Post subject: Reply with quote
Once you know the charge rate you can take it from there,if its a tad low then you want to test the output from the alternator.
Eddie Hitler
PostPosted: 09:46 - 21 Aug 2014    Post subject: Reply with quote
Culprit ended up being a dodgy crimp on the connector block to the R/R. Tested everything else with positive results so was scratching my head for a little bit. Sorted it for now but will be recrimping it properly next week.
The PDF was a great help Aff Thumbs Up .
The last post was made 11 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 106.45 Kb
