Dauville/Divvy... Boringly sensible commuter help!
ginny
PostPosted: 16:47 - 19 Aug 2014    Post subject: Dauville/Divvy... Boringly sensible commuter help! Reply with quote
Ive just finished uni and have been fortunate enough to get a job completely unrelated! Downside being a commute into south London everyday (from Hertfordshire)
I know the most eminently sensible option is a season ticket for the train and tube - BUT - there is a strong possibility some of my job training will be dotted about closer to home - potentially Bishops Stortford/ Cheshunt.
If thats the case, its not likely to be cost effective to get a season ticket, and I might be better to cut my losses and get back on a bike. Even if it were London everyday, running costs of a shaft drive save me 2 grand a year Vs season ticket, i'd be loosing the opportunity for a 30 min chill/book read each way though.
Previous bike- Half faired Honda Hornet 600. Don't need anything more powerful than that (less is fine!), got fed up of being blown about,cold and wet on the hornet, want something more touring oriented but don't need G-force speed. I'd like something with better weather protection, economy and preferably shaft drive (1000+ miles a month). All the while, something that can filter would be handy for M25/london timesaving. Basically I want it all, and for not a lot of money Razz
Deauville and Divvy 900's seem to be the order of the day... but they aren't fully faired (lower cowl available for dullsville) maybe a NTV - have no knowledge of BMWs, but have heard issues about reliability. Needs to be a real mile muncher. Maybe even an early Pan, are they too wide to filter?
Budget for bike alone, £2000-£3000
stevo as b4
PostPosted: 17:00 - 19 Aug 2014    Post subject: Reply with quote
All I'd say is IMO it would be best for you to start your job and training and then see how you get on both using the train/tube first.
Then get yourself a bike and see how you like doing the journey by bike, how it is for parking, how much time it saves you, and how well you manage in terms of carrying your stuff around, as well as getting an idea of fuel/running costs.
It does not need to be a proper full on tourer/shaftie just to see if you like doing the journey by bike, and if the time savings and running costs stack up, as well as if you have secure parking, and somewhere to store you bike gear/get changed as required.
If it works out then you could look at maximising your savings by getting a more suited shaft drive machine. But to shell out 2-3large on a bike when you don't know if it's the best option yet is daft IMO. A £700 ER5 for a month or so would get you knowing if the commute by bike idea is worth it to you and if it's what you want long term?
PostPosted: 17:04 - 19 Aug 2014    Post subject: Reply with quote
I was in a very similar situation recently and went for the Deauville. I went for the older model, the 650, as it is a proven reliable work horse.
Mine came with heated grips, top box, extra wide pannier lids (as spares), leg and hand wind deflectors and the larger touring screen for £1700. It will sit at 70 mph very happily, 80 is fine but a little noisier but it's got decent wind protection and the built in panniers are handy but not massive if you don't have the extra wide panniers.
With 95% motorway riding I'm getting 60+ mpg.
Sure it's no sports bike, but for getting to and from work, for me it's ideal as it really doesn't encourage you into (very) illegal speeds like a more powerful bike could do.
Itchy
PostPosted: 17:08 - 19 Aug 2014    Post subject: Reply with quote
Steelie CBR?
Chain isn't that hard to look after.
But NT650V is a proven reliable workhorse, belly pan doesn't matter as the downpipes are stainless and the engine finish isn't too shabby either.
Shaft drive, integrated luggage, good MPG and weather protection.
XJ900s the older ones have a rep for poor MPG
mgh0
PostPosted: 17:18 - 19 Aug 2014    Post subject: Reply with quote
I commute on a Diversion 900, good weather protection, all day comfy and I get around 48-52mpg, lots of luggage options too.
"Courage is not defined by those who fought and did not fall, it is defined by those who fell and rose to fight again." Adrienne Rich.
gbrand42
PostPosted: 17:36 - 19 Aug 2014    Post subject: Reply with quote
I've got the 700 version of the Deauville and its happy at a steady 90 on my private test track, mpg is probably a bit worse than the 650. I'm getting about 55mpg. Comfort is fine, I can easily do 150 miles before my backside protests. I had a slight issue with vibration through the bars but this has been totally cured with some Grip Puppies. I haven't had any experience of other big bikes, but this one does the job for commuting and leisure with minimal fuss.
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
c_dug
PostPosted: 18:01 - 19 Aug 2014    Post subject: Reply with quote
I have the divvy 900, I do a similar commute. It does the job very well.
Still if I had to buy again I would probably have the dullsville.
parkmoy
PostPosted: 18:10 - 19 Aug 2014    Post subject: Reply with quote
Another vote for the Deauville 700. I had one and whilst I didn't do any commuting I toured extensively on the continent and it was super comfortable. Mine was restricted but would still sit happily at 90 -100 on autobahns and hit 110 when pushed.
De-restricted performance I have no idea I sold mine restricted, never felt the need to change it. No sports bike but a great workhorse.
ginny
PostPosted: 18:45 - 19 Aug 2014    Post subject: Reply with quote
Thanks for the quick replies, glad to see some positive info for both an options. Stevo, as you suggest I will wait untill I've started, changing/storage facilities will be the crux of the problem, definitely have secure storage or I wouldn't contemplate bringing a bike into the area.
Done plenty of commuting by bike this last year so have avoid idea of hassles like kitting up/gear storage, not to mention I'll be wearing a suit and tie everyday. Guess I will just keep my eye on autotrader etc and bide my time!
BenR
PostPosted: 19:01 - 19 Aug 2014    Post subject: Reply with quote
I'll probably get a load of flack for this but have you also considered a maxi scooter? I have an aprilia atlantic sprint 500 which I use for commuting to Camberely from Hertfordshire everyday. Costs sod all to run really even with buying expensive tyres.
wristjob
PostPosted: 19:12 - 19 Aug 2014    Post subject: Reply with quote
its true if all you want is an into town bike then its hard to argue against a big scoot.
good storage,plenty fast enough for town and motorway,good weather protection(for a bike).
PostPosted: 20:11 - 19 Aug 2014    Post subject: Reply with quote
I have some mild seller's regrets about getting shot of my Burgman 400.
As an all seasons commuter they do take some beating.
Sorry.
Aspire
PostPosted: 22:01 - 19 Aug 2014    Post subject: Reply with quote
Trophy 1200.
Cheap £1.5-1.8k will get you one with full luggage etc
Good weather protection
Nice torquey engine
Relatively stiff suspension (for a tourer) so handles well for a big bike.
Fuel Gauge
Dad had a divvy 9 & the trophy is his now IMO the trophy is a better bike in almost every department.
Irezumi aka Reuben
Carrot Top
PostPosted: 22:10 - 19 Aug 2014    Post subject: Reply with quote
If you get a Deauville go for a 650 and save some cash.
Any extra power is negated by the increase in weight on the 700, quite noticeable through London. I found the old one much better due to being lower (I'm a short arse). 700 has slightly better weather protection so you will need the extended/higher screen on the 650. Both keep you pretty well protected, lack of lower fairing no an issue really.
My only concern about super scoots is smaller wheel size and getting caught/more bounced around by potholes. This depends if your route is through central or around M25. Which depends on your your South London Location?
London Bridge or Croydon etc?
Pictorgraphicalfantastical
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Tiff
PostPosted: 00:01 - 20 Aug 2014    Post subject: Reply with quote
Kwak GTR1000? bit of grunt,shaft drive, full fairing,luggage and well under a grand..
1996 Kawasaki GPZ1100s,1996 VFR750,1980 BMW R80,1982 Kwak Z250B,1992 ZZR1100C,1996 BMW K1100LT,1994 Kwak ZZR600E,1993 BMW R1100RS,1992 ZZR 600D,1988 BMW K100LT,1998 Aprilia Pegaso 650,1994 Suzuki RF900,1991 Yamaha XJ600, 1988 Honda Dominator,1992 Kwak KMX125,1987 Yamaha RD50MX,1984 Honda MBX50.1984 Honda Superdream 125
Shaft
PostPosted: 00:13 - 20 Aug 2014    Post subject: Reply with quote
Not highly rated when they were new, so they sold about 12 of them and parts are a struggle now, which is a consideration when you're doing a 1000 miles a month.
WD Forte
PostPosted: 15:27 - 20 Aug 2014    Post subject: Reply with quote
I checked out a 400 burgervan down here for mate
before he came down to buy/collect it.
I though it was great fun and a good middle distance commuter.
I chatted to a guy with the 650 version who admitted he and his missus
spent more weekends on that than his 1100 sports bike.
Another mate had a Yamaha Majesty 250 which seemed to tick all the boxes
in term of his needs, but sadly he couldn't get over a sense of embarrasment
that it was a scooter/not a proper bike and sold it.
bikers smell of wee
ginny
PostPosted: 22:01 - 20 Aug 2014    Post subject: Reply with quote
Just worked out my take home pay, and dropping £4k a year on train travel is pretty galling.
Route is almost direct North to South through london, from A1000 or A41, assuming that would be quickest. Ive no experience of commuting in London, but plenty of M4/M25/town filtering.
Roger, I was almost hoping you'd pop up suggesting the Burgman. Whilst at a very vein level, it seems like a step down, I literally only want transport for practicalities sake; maxi scooter looks like an intelligent option. How do you think it would fare with filtering compared to the average bike? Also, how is maintenance and engine life etc- how does what I assume is belt drive compare to shaft/chain? real world MPG?
I'm tempted to organise a preliminary test ride, shame there aren't any local Suzuki dealers. I think i'll give the Honda silverwing a try, dip my toe as it were.
WD Forte
PostPosted: 22:29 - 20 Aug 2014    Post subject: Reply with quote
I'm sure Roger will give you many details on actual owership but
having ridden my mates AN400 a few times It felt so light
(having just got off a K100 mind you, them's heavy buggers)
and was easy to fling about, so filtering would be easy.
Silverwing eh?
A couple of years back I was chatting to Russian guy called Peter on the M6/Frankley services with one.
He'd left Moscow for Turkey then meandered through Europe and was on his way to Newcastle
to get a ferry to Norway then eventually back to Moscow,
so I reckon they'll clock up a few miles without getting too
wanty/needy.
bikers smell of wee
hmmmnz
PostPosted: 22:45 - 20 Aug 2014    Post subject: Reply with quote
mz250 with enclosed chain and big arse ugly fairing
https://i4.photobucket.com/albums/y148/1961littledave/MZ250-2.jpg
that enclosed chain is awesome, my mz had 50k km on the clock with the original chain, got oiled once a year
the humans are dead
I kick arse for the lord
WD Forte
PostPosted: 22:51 - 20 Aug 2014    Post subject: Reply with quote
A classic hack the ETZ
I'm still using the fork gaiters and windscreen from one I had
on my CX
bikers smell of wee
ginny
PostPosted: 22:53 - 20 Aug 2014    Post subject: Reply with quote
Not sure i've got the retro swag/years under my belt to pull that off!
PostPosted: 07:37 - 21 Aug 2014    Post subject: Reply with quote
It's fine. It's 180kg+ but (IMO) feels lighter because it's low down.
For filtering, the bars and mirrors are the widest part like on any bike, and they're about average. Narrower than the stock ones on my GS. The chap I bought it from had shortened the mirror stalks down for serious filtrage.
Sharp enough away from the lights, and will hold a (real) 70mph without fuss. I loved the linked brakes, it felt like chucking an anchor out the back.
The turning circle is OK. Not amazing (nakeds FTW) but I was rarely stuck for a route.
I only ran it through one winter, so I can't really speak to that.
Oil and filter change is easy enough. Air filter is a wash-and-re-use job.
I will say that paying for work to be done on it could run expensive if the plastics have to come off. Having to remove the exhaust to get the rear wheel off, and the rear wheel off to get at the inboard rear brake, is a chore. I snapped a stud, cue hours of drilling and swearing. Penetrating oil on the nuts as soon as you get it, or just split them off.
It's a hybrid drive, belt then shaft final. They're not known for giving trouble as far as I can see. The recommended replacement interval on the belt is 14,500 miles or 4 years, but owners report them going for far longer. Mine was at 24,000+ miles on what I suspect was the original belt and rode fine (it came with loads of receipts, none of them for a belt).
There are a lot of inspect / lubricate / adjust minor service items, which I suspect may get neglected.
ginny wrote:
real world MPG?
70, pretty much constant regardless of the riding. Tank range is 200 miles in theory, but the fuel gauge will wimp out long before that. I took it to 180 before blinking.
Look at the 2007 (K7 model year) onwards, which shouldn't burn oil. It's a known issue on the older ones.
Storage space and weather protection is excellent. Add heated grips and/or muffs and you're golden. Tucano Termoscud and you're platinum.
The downside is the small wheels which can get a bit crashy and weavy. Oh, and it's very dull, which is why I chopped it in for a bike that's worse in almost all measurable ways. Wink
WD Forte
PostPosted: 12:10 - 21 Aug 2014    Post subject: Reply with quote
Bigger wheels..... yet scootish.......
Hmm....
What some folk like to call the 'Porta Crapper' comes to mind
PC800
https://carslist-db.com/pics/honda/honda-pc-800/honda-pc-800-05.jpg
bikers smell of wee
The last post was made 11 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 133.26 Kb
