Interfacing with mobile phone screens
smegballs
PostPosted: 19:22 - 20 Aug 2014    Post subject: Interfacing with mobile phone screens Reply with quote
I've seen on ebay small screens from blackberries and the like can be had for a fiver or so. So it would seem a pretty good source of small screens for little fun projects (say a diy speedo/tacho/boost gauge etc etc).
Anyone know how you'd even begin to go about interfacing with them? Or are they pretty much out of reach behind a mountain of proprietary firmware?
PostPosted: 19:47 - 20 Aug 2014    Post subject: Reply with quote
Here's a taster :-
https://homepage.ntlworld.com/c.lewis19/nokia.htm
Charlie
PostPosted: 21:45 - 20 Aug 2014    Post subject: Reply with quote
Use to have an old Sony Ericsson W960i that I've been meaning to do the same with but never got round to it. Then it got stolen Sad
I guess it depends on how easy you can get a datasheet for it... But you could make it more fun by reversing engineering the screen first to understand/gain control. Tag onto the bus and do capture and try to decode it? Or read the firmware image off the phone and reverse the screen driver?
rideslikean00...
PostPosted: 21:53 - 20 Aug 2014    Post subject: Reply with quote
Seems like a lot of work reverse engineering what was basically designed as closed source tech. Personally I feel the easier yet ironically somewhat more elaborate solution would be to use a Raspberry Pi with some small generic LCD and have a lot more control over what you can do. Since both Pi and LCD would be low power (the Pi is USB standard 500ma via 5V, IIRC) it presumably wouldn't be too hard to have a bike power them directly.
All guesswork though, I'm shite with electronics when it comes to that side of it, but there's a handful on here who could run with the idea.
Previous/Current Bikes
2013 Yamaha YBR-125ED -> 1997 Yamaha YZF-1000R Thunderace -> 2009 Yamaha XJ-6 Diversion -> 2007 Yamaha FZ6 Fazer S2
daemonoid
PostPosted: 12:08 - 21 Aug 2014    Post subject: Reply with quote
I can't imagine the interface is that revolutionary from a data perspective. The more modern a display, the more generic the input as they'll be pattern parts assembled to designer specs. Probably...
If you're good electrically and software wise then maybe for the enjoyment of the project it's worth a go. Otherwise there's much easier ways to go about it... Not least - buy an old android phone and do everything in code - you can get a bluetooth OBD-II that will give you all the input.
current: ducati monster 750
Im-a-Ridah
PostPosted: 14:50 - 21 Aug 2014    Post subject: Re: Interfacing with mobile phone screens Reply with quote
Find something with better documentation or it will end up taking you forever. Not much point saving £5 on a screen and spending an extra week getting the thing working.
PostPosted: 14:55 - 21 Aug 2014    Post subject: Reply with quote
Arduino/PICAxe and an I2C display would be a cheap starting point that's well documented.
The last post was made 12 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 53.48 Kb
