KMX 125 rear shocker upgrade
robando
PostPosted: 09:24 - 25 Aug 2014    Post subject: KMX 125 rear shocker upgrade Reply with quote
Hi all,
I have a KMX 125 (1987). The rear shock is tired (like most KMX this age) and I want to, if possible, upgrade to a stiffer shocker that will be better for off road use.
What rear shockers will fit my KMX? ie. KX, CR etc...
Thanks in advance...
dangerousdave
PostPosted: 12:57 - 25 Aug 2014    Post subject: Reply with quote
Best available shock for the KMX 125 is the Wilbers fully adjustable one. Yours for £460 with a 14 day wait. This shock is made specifically for the KMX 125. Also allows adjustment of the ride height, as well as compression and rebound damping adjustment.
The other shock is the Hagon. This is made to fit the Kmx 125. Retail for around £220 now. Has basic preload and rebound damping adjustment. This is more of a simple replacement for the OEM Kawasaki shock. I haven't heard any feedback on the quality, but it is rebuildable. Hagon will overhaul them for £100 when the time comes.
The OEM Kawasaki part wasn't built to be rebuilt, like most OEM shocks. I believe some of the suspension specialists can rebuild the later type shocks (separate reservoir versions). If you are considering having your shock rebuilt then check they can actually rebuild it first.
I looked into using a kx shock but there are a couple of fundamental problems. First is that the kx shock has a much larger diameter, and often a "piggyback" style reservoir, which means it does not physically fit with the kmx airbox in place. Secondly, the KMX uses a different shock mount to all the KX shocks I have come across, although this can be amended relatively easily for those handy with a welder, or a job for a welding shop.
Hope this helps.
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
robando
PostPosted: 09:31 - 26 Aug 2014    Post subject: Reply with quote
Hi dangerousdave,
The Wilbers shock at £460 is beyond my budget and considering I only paid £1000 for the bike I can't justify paying that much.
The Hagon shock is nearer to my budget at £220 but I can't find for less than £299.
Have you seen one for sale at £220?
I did intend to spend £120 max but I suppose that won't be realistic. I thought I could maybe buy a second hand shock in reasonable condition off a different bike that would provide stiffer suspension.
Thanks for the help so far Thumbs Up
The last post was made 11 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.65 - MySQL Queries: 13 - Page Size: 36 Kb
