Drying motorcycle kit
natefz6
PostPosted: 14:44 - 26 Aug 2014    Post subject: Drying motorcycle kit Reply with quote
So I am sure this topic has been done to death but I did do a quick search and found some stuff relating to gloves. but..
Yesterday I got pretty caught out in the rain and got fully piss soaked. Since returning I have had my textiles under a blowy heater in a room with an extractor fan pretty much all night and all day an the things still are not dry. Its like they have some sort of magic water storage in them, I could have cured the drought in California with the amount of water in them.
My jacket is just about wearable after being on the towel rail on a low setting but my trousers are still very damp as are my gloves.
I am thinking that they may be getting a bit old and thats why they absorbed so much. They are goretex and I was not wet but the water was literally pouring off me when I got in.
One thing I am thinking for my new house is getting a towel rail with a hook above it in the down stairs loo to dry my kit. My experience today/yesterday indicates that might not be enough.
Any one have some voodoo magic method they use to dry things faster? or gadgets I love a good gadget (as long as it works).
"no I didn't steal it that's just the way I ride"
Andy_Pagin
PostPosted: 15:08 - 26 Aug 2014    Post subject: Reply with quote
I just hang my kit from a picture rail over a radiator overnight if it gets really sodden. Usually does the trick.*
* Radiator needs to be turned on full blast.
weasley
PostPosted: 15:12 - 26 Aug 2014    Post subject: Reply with quote
Jacket and trousers: try to make sure they are as open as possible.
Gloves and boots: stuff them with newspaper, right down into the fingers.
MarkJ
PostPosted: 15:21 - 26 Aug 2014    Post subject: Reply with quote
If you've got one, use an airing cupboard Thumbs Up I hang my sopping wet kit in there and it's dry by morning.
However if I forget, so long as the next day is dry I wear the damp kit and the ride dries it all out.
Jefr0
PostPosted: 16:15 - 26 Aug 2014    Post subject: Reply with quote
Is your goretex kit still repelling the rain or soaking it in?
Mine lost it's repelling magic lately (3 years old) so I went the Nikwax route, washed and then treated.
It revitalises the goretex 'membranes' in the jacket/trousers.
Well, I only did mine at the weekend. Took a couple days to dry from completely submerged in the sink with the nikwax stuff.
Today I noticed my trousers were repelling very well but my jacket not as much.
I been reading up lately on it. You need to clean them as they clog up the material with dirt and road grime and stop repelling. Once clean then they just need revitalising and 'should' work again. I'm testing mine at the moment.
For this winter I'm looking at buying another set of goretex clothing for times where they're a bit wet to be putting on in the morning but hopefully this nikwax stuff will do the job instead!
Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95)
TheArchitect
PostPosted: 16:32 - 26 Aug 2014    Post subject: Reply with quote
I just hang my gear in the bathroom overnight with the window open. Always dries out fully even after the worst of downpours. Remember to remove the inner linings and hang them separately to get maximum air through the kit.
Perhaps invest in cheap over jacket and trousers for the worst days. My set fold up into a tiny ball so it doesn't take up too much space in the rucksack. Will save you from getting completely drenched.
With gloves I just stuff them down the back of a radiator overnight, usually sorts it out.
GSXR 600 K6 - Stolen
MT09 - Almost stolen
barrkel
PostPosted: 16:43 - 26 Aug 2014    Post subject: Reply with quote
Get quality kit that doesn't soak up water - e.g. goretex proshell. Hang up, it'll be dry in ~4 hours of room temperature, or leave in a heap in the floor in the corner (as I usually do my trousers), it might take 10 hours.
waffles
PostPosted: 18:14 - 26 Aug 2014    Post subject: Reply with quote
This. Also make sure that you hang stuff up so that it can drip properly, see if you can find something like this that goes over the top of a door (shower door works too) so that you give stuff enough room to air through. Stick newspaper or a tray underneath if its particularly drippy.
totalllama82
PostPosted: 18:35 - 26 Aug 2014    Post subject: Reply with quote
I hang mine up in an airing cupboard with the boiler at home. Generally use my waterproof 1pc suit though so it tends just to be my gloves and boots.
Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F
natefz6
PostPosted: 19:18 - 26 Aug 2014    Post subject: Reply with quote
This is Daniese goretex a bit like this one linky but an older version with the matching trousers.
They have the inner Goretex membrane that still works for about 40 mins. Its just the outside that soaks it up but then you get that damp feeling. I will try the Nikwax and see if that helps it repel the water a bit more. If not I will start looking at a new textile outfit, at least then I will have two to alternate if it rains all week like this week Smile.
finniee
PostPosted: 23:17 - 26 Aug 2014    Post subject: Reply with quote
I'v ended up just dumping my textiles in the bath wringing them out, opened the bathroom window and closing the door and putting the heating up a few degrees for 2/3 hours then on the radiator for an hour or so usually does the trick.
Was drenched and the heating wasn't working so wringed out trousers and jacket and sat with a hair dryer drying them.
Lupo
PostPosted: 02:47 - 27 Aug 2014    Post subject: Reply with quote
-External fabric with water-resistance treatment
Taken from the link, if that applies to your jacket, then it shouldn't soak water, washing and use, will degrade it over time, as water-resistance treatment does not have the longevity of a Goretex membrane. Try squeezing as much water out as you can as that will help a lot with the drying.
A por ellos, que son pocos y cobardes.
Moo.
PostPosted: 09:53 - 31 Aug 2014    Post subject: Reply with quote
I use a klim goretex pro jacket, the stuff is brilliant!! Doesn't soak anything up in a downpour and within half hour of being sat in a cafe its pretty much dry! The same couldn't be said about my cheapo waterproof over trousers with let water through the crotch and soaked into my kevlars, which trying to dry while camping in a tent.. Is nigh on impossible. And bloody cold after 180 miles of freezing alp passes..
A2 Passed 18/6/10
ADSrox0r
PostPosted: 10:00 - 31 Aug 2014    Post subject: Reply with quote
If i get properly caught out i tend to hang my clobber on a clothes horse next to the dehumidifier on full blast. Usually sorts it out over night.
The last post was made 11 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.84 - MySQL Queries: 13 - Page Size: 82.58 Kb
