| Meshuggah |
 Meshuggah Scooby Slapper
| gavbriggs |
 gavbriggs Crazy Courier
| Meshuggah |
| Rogerborg |
 Rogerborg nimbA
 Posted: 19:12 - 28 Aug 2014 Post subject: |
When not under load.
Borrow a battery and see if that sorts it? Jump leads to the connectors if you can't get it near enough.
A flat battery wrecked the electrics on my car, it's not something I'd dick around with any more. ____________________ Biking is 1/20th as dangerous as horse riding.
| Meshuggah |
| Thorn |
 Thorn Banned
| Meshuggah |
| lihp |
 lihp World Chat Champion
 Posted: 19:37 - 28 Aug 2014 Post subject: |
Not with lead acid batteries like the one linked. Grab a motobatt, they come charged and sealed. Just swap them over and done. ____________________ covent.gardens: lihp is my most favourite member ever |
| gavbriggs |
| Meshuggah |
| Meshuggah |
 Posted: 20:11 - 28 Aug 2014 Post subject: |
 Posted: 20:13 - 28 Aug 2014 Post subject: |
If it started for 2 days after a charge-up but then didn't I'd check the charging voltage at 5k revs. Might be the battery is ok but the charging system isn't. ____________________ a.k.a 'Geri'
| janner_10 |
 janner_10 World Chat Champion
 Posted: 21:08 - 28 Aug 2014 Post subject: |
Get out of the habit fast of trawling Ebay for cheap shit for your bike - Get the best parts you can afford, dont autmatically go for the cheapeast.
Google Wemoto for some decent online deals that get delivered quick. ____________________ Yamaha FZS600 (Now gone to heaven) > CBR600F4i (SOLD) > '99 YZF-R1 |
| Meshuggah |
| Eddie Hitler |
 Eddie Hitler World Chat Champion
| Eddie Hitler |
 Posted: 18:44 - 30 Aug 2014 Post subject: |
| Meshuggah |
| Sload |
 Sload World Chat Champion
| Meshuggah |
| Meshuggah |
 Posted: 20:04 - 14 Sep 2014 Post subject: |
I installed the new battery, the new spark plugs and everything looked fine for few days. Then I felt the battrey was getting weaker. I wasn't sure 100% but I had that feeling. Today the bike wouldn't start again. bloody random.
Click, engine light on, nothing.
Click, start.
click, engine light on. nothing. Put in first gear, rock it back and forth, release clutch (fuel pump engages again), clutch in, bike starts.
Sometimes same as above bike won't start.
Took battery out. charged for few hours. it seems to be starting all the times now.
Will see tomorrow morning what the fuck happens when I have to go to work early.
If I check for battery leak, negative cable out. multimeter set to amps. negative multimeter probe attached to negative battery, and positive probe to the negative disconnected lead from the battery, the reading is 0.25 /0.26. If I remove the back up fuse then the drain is 0. Problem is in the manual the back up fuse is suppose to be used only for the clock and odometer but If i remove mine the whole bike does not power up. at all. no screen no nothing.
is it normal or do I have a parasitic drain? I have no alarms, just a power commander.
 ____________________ Triumph Tiger 800 2012 |
| Jim Mc |
 Jim Mc Nearly there...
| Meshuggah |
| Taught2BCauti... |
 Posted: 07:49 - 15 Sep 2014 Post subject: |
Try disconnecting the alternator - there's usually 3 yellow wires coming from the casing that you can trace to a connector - and check again for current drain.
If your reg/rec is starting to go faulty, current can leak back into the alternator windings which would account for a 250ma drain.
In some cases, you can actually feel the alternator cover getting slightly warm after the bike has been parked overnight. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| MattEMulsion |
 MattEMulsion World Chat Champion
| P.addy |
 P.addy Red Rocket
The last post was made 12 years, 35 days ago. Instead of replying here, would creating a new thread be more useful? |
